  1. Mar 23, 2025 at 12:54 PM
    Neo
    Neo New Member
    Alabama
    That's a sweet shop and lift! Were you intending to share the firearm photos with zero explanation?
  2. Mar 23, 2025 at 1:43 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    Oh I mentioned it a lil bit... I took a few breaks to cerakote them at the shop. Dual post "what have you done to your tundra today" and "what have you do e with your SBR today"
  3. Mar 23, 2025 at 3:20 PM
    mcmilla.project
    mcmilla.project New Member
    2005 Toyota Tundra
    Filthyphil and FiatRunner like this.
  4. Mar 23, 2025 at 3:40 PM
    ultraman29
    ultraman29 New Member
    Katy Tx
    2021 White TRD sports
    It’s about time to have this.
  5. Mar 23, 2025 at 3:41 PM
    Sweet 2nd gen
    Sirfive, bmf4069, Voss and 2 others like this.
  6. Mar 23, 2025 at 6:39 PM
    bfunke
    bfunke Tundra Curmudgeon
    Changed oil in my 2000 AC and my Suburban this afternoon. Last oil change noticed a couple spoonfuls of oil under the filter/cooler. Figured I would try some AT-205 which @shifty` recommended before tackling the figure 8 gasket with last oil fill. I was a bit skeptical about AT-205 but this time my skid plate was bone dry. Thanks again @shifty`
    bmf4069, shifty`, Voss and 1 other person like this.
  7. Mar 23, 2025 at 6:48 PM
    MacFixes
    MacFixes New Member
    mac
    2000 Tundra Limited TRD
    Across around 5 hours and my entire rear axle falling off my jack i finally got my entire bilstein 5100 lift with the 3” in the front and 1.5 add a leaf. along with my new wheels. I’ll take a better pic in the morning
  8. Mar 23, 2025 at 9:14 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    How did you get 3" with Billy's up front?
  9. Mar 23, 2025 at 9:35 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I'd assume OEM springs with billies set to top notches (stiff AF, had this on my Tacomas) or 3" lift springs paired with billies
  10. Mar 23, 2025 at 9:50 PM
    ToyotaDude
    ToyotaDude Member
    Thought they only went to 2.5" with the stock springs?
  11. Mar 23, 2025 at 9:58 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I'm not sure. TBH
    I think on first gen Tacoma they went to either 2.5" or 2.75"
    I know it was a popular mod to use the first gen Tundra billies on first gen Tacoma for more lift.
  12. Mar 24, 2025 at 12:16 AM
    ToyotaDude
    ToyotaDude Member
    Checked old measurements and looks like AC did likely get 2.75" off top notch with OEM springs....
  13. Mar 24, 2025 at 5:28 AM
    I got about 2.25” on the fourth notch with TRD springs on my AC
    mcharfauros likes this.
  14. Mar 24, 2025 at 6:42 AM
    I hate to be "that guy", and I know we all hate reading the instructions, but Bilstein explicitly says to avoid the 4th notch with stock springs on the AC/4WD, which must mean you should really avoid using the top notch.
    Look, I know @KNABORES reports no major issues with running on 4th notch. But I think you'd probably hafta not give a fuck about your truck running on the 5th notch. I can't imagine that's what @MacFixes did, but I've seen a lot of other equally careless shit on this forum, especially from the younger crowd, so who knows... :rofl:
  15. Mar 24, 2025 at 7:41 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Digging back into recent archives...
    Hey, I have a couple questions. Are you able to reach the grease zerks on the shackles with those new hangers? And how tall are the Archive Garage bumpstops (assuming that's what you've got with your u-bolt flip kit)? I just put new leaf springs and Total Chaos shackles on my truck. I also have Sumo Springs, but I'll be adding air bags in the next couple weeks. With air bags, I don't need the Sumo Springs, but my stock bumpstops are gone. It may or may not be a smart move, but I'm considering just sawing the Sumo Springs down to a stock bumpstop height, or maybe just slightly taller. But I'm not sure of the right height.
    Truck is on a slant and whatever settling is going to happen with the new HD leaf pack hasn't happened yet, but here's how it sits.
  16. Mar 24, 2025 at 7:46 AM
    I have the TC shackles and no you can’t really get to the grease zerk, I ended up getting a 90 degree zerk to replace the straight that came with them.
  17. Mar 24, 2025 at 7:47 AM
    MT-Tundra
    Montana
    Yeah it didn't really look like it...
  18. Mar 24, 2025 at 9:08 AM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    Food poisoning got me late Saturday....felt like death through this morning....struggling today. I did get a pic of the new mirrors. No more vibrating glass and the Raptor lined caps turned out pretty ok. I'll pop my color matched caps off the old mirrors...but probably keep these for the time being.
  19. Mar 24, 2025 at 9:42 AM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Looks good. For the raptor lined side mirror caps, did you apply with the mirror caps attached to the entire side mirror assembly or did you remove the caps? I've got satin black vinyl wrap that I am planning to apply, but I like how you did this so I'm reconsidering
  20. Mar 24, 2025 at 10:17 AM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    I bought new mirrors from Rockauto and they came with the caps off...so I sprayed them before I snapped them on.
    G_unit3000[QUOTED] likes this.
  21. Mar 24, 2025 at 10:46 AM
    ToyotaDude
    ToyotaDude Member
  22. Mar 24, 2025 at 11:39 AM
    Dirt Ferguson
    Dirt Ferguson New Member
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    Just installed front seat jackers. I feel like I'm driving an actual truck now. Great product. 5 min install. Worth the money.
  23. Mar 24, 2025 at 12:01 PM
    Dakillacore
    Georgia
    Those look great. I like that idea a lot.
    G_unit3000 and Filthyphil like this.
  24. Mar 24, 2025 at 12:20 PM
    MacFixes
    MacFixes New Member
    mac
    imma keep it a buck, i have no idea how high the lift is specifically. i didn’t even jack with the notches. i just assembled it and put it on with how to clip came originally
    Dakillacore likes this.
  25. Mar 24, 2025 at 12:34 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    :D
  26. Mar 24, 2025 at 1:13 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    New calipers. It’s been so windy I didn’t realize how bad it was trying to drive through the brakes. My dumbass also forgot to prep these and went straight to painting LOL.
  27. Mar 24, 2025 at 4:09 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I swear one day when I'm bored (or waiting for the cable guy...) I'm going to start a thread "The Photographer's Feet"
    Voss, whodatschrome, bmf4069 and 6 others like this.
  28. Mar 24, 2025 at 4:17 PM
    @TaquitoBandito
    bmf4069, TaquitoBandito and Azblue like this.
  29. Mar 24, 2025 at 6:01 PM
    TaquitoBandito
    Joel (AKA Bif)
    Dammit Mo. You are supposed to tell me after he does it so I can get him for copyright infringement. :mad:
  30. Mar 24, 2025 at 6:43 PM
    ToyotaDude
    ToyotaDude Member
    Rear door rattle not the usual black tape on the catch fix. Had just located a pen to fabricate covers and found this.
    Looks like the card had popped off at the top corner.
    Reseated these two clips.
    And fit the plastic back round the weatherstrip.
