Sway and Weight Distribution Hell
Discussion in 'Towing & Hauling' started by Acwilcox2010, Mar 13, 2025.
  1. Mar 13, 2025 at 5:58 PM
    Acwilcox2010
    Acwilcox2010 [OP] New Member
    25’ Tundra TRD
    IMG_0451.png Hello All - Needing some help finding a recommended weight distribution hitch with sway control for my horse trailer.
    The original I purchased will not work due to the platform on the trailer attached to the coupler (it needs bracketed arms to set the distribution attach points on/tighten up).
    Any recommendations for anyone who has towed a trailer with something similar such as this and needing a weight distribution hitch with sway control? Ideally one piece.
    Thanks!
  2. Mar 13, 2025 at 7:21 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
  3. Mar 13, 2025 at 7:47 PM
    Cut through the platform. I've had to do it on a couple trailers. I just drilled two 1/2" holes and then used an angle grinder to take out the center. Brackets went in like a glove.
    rdiddy5 and KNABORES like this.
  4. Mar 13, 2025 at 8:32 PM
    Acwilcox2010
    25’ Tundra TRD
    Great ideas - thought about looking for one to drill through the bracket, was curious to any that folks have used with good success.
    Thanks for the ideas and sending over some links!
  5. Mar 23, 2025 at 9:07 PM
    blenton
    blenton New Member
    This is the way.
