Cam and crankshaft position sensor
Discussion in '2nd Gen Tundras (2007-2013)' started by RJVA, Mar 23, 2025.
  1. Mar 23, 2025 at 12:36 PM
    RJVA
    RJVA [OP] Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    Hi guys,
    Do OEM camshaft or crankshaft position sensors need to be programed or taught after installed on a 4.7?
  2. Mar 23, 2025 at 5:57 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    I don't know about the camshaft position sensor in your truck, but I had camshaft position sensors for Bank 1 and Bank 2 in my 2013 Tundra 5.7L TRD. These codes became "permanent" in the ECU, so they could not be erased by my Blue Driver reader. But in this case the ECU erased the codes by itself. The note i got from the Blue Driver tester was that "only the temporary codes could be erased, not the permanent codes stored in the ECU. I also said that once the ECU does not sense the same codes, the UCU erases them automatically."
    I did replace the 4 sensors, but the problem was not being caused by the sensors themselves, but by the lack of engine oil flow through them. The original sensors (solenoids) are fine, but since I had already replaced them with a new and cheap set of 4 from Amazon, I just stored them with other Tundra's spare parts :)
