  1. Mar 21, 2025 at 1:03 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Happened to look down at the right time
    Don’t worry; I’ll very very very carefully wipe the dash soon
    rdiddy5, Mater, ATV25 and 10 others like this.
  2. Mar 21, 2025 at 1:25 PM
    bigmace
    bigmace New Member
    Oregon
    2021 Silver Tundra Limited / 2019 Black Sequoia SR5
    How do you like those steps. Mine are sitting in the garage still in the box. Hoping to put them on this weekend.
    BR73 likes this.
  3. Mar 21, 2025 at 2:19 PM
    caboj
    caboj New Member
    CA
    2018 Tundra CM TRD OR
    I really like them, very stout, good grip on the surface, sit nice and close to body, tapered at ends so they don’t look too bulky, and no hanging brackets. They ticked all the boxes, I think you’ll be very happy.
    bigmace[QUOTED] likes this.
  4. Mar 21, 2025 at 3:21 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    That looks really nice! :thumbsup:
  5. Mar 21, 2025 at 3:44 PM
    jspec rsx
    jspec rsx New Member
    accuired my late dad's 2014 4.6 sr5 CM a few months ago and have been in the process or brining it back to it's old glory.
    full paint 1 month ago hasn't been washed yet and today painted the bakflip g2 tonneau cover
  6. Mar 21, 2025 at 5:06 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Gathering up the last of the parts to address some lingering left over issues from the previous owner's spacer lift install. Long story short it looks like the truck went through a couple of iterations for lift. Currently has 2" blocks in it but I found a set of Torch helper leafs in the decked tool boxes. I didn't find all the components so I guess they are MIA. The u-bolts look like they have been off a half dozen times at least and have spots where there is no thread. (I found this by accident troubleshooting the steering wheel "migrating" around while driving). That issue turned out to be both u-bolts were loose and the rear axle was shifted. I addressed that by moving the rear axle to where it was supposed to be and double nutting the u-bolts as a quick fix to get me through winter. I have some nice new beefy 5/8” u-bolts that went in today. The axle was out of alignment again. It’s all buttoned up now and looks and feels great! My only concern is the cheap plastic spacers. They have the hole for the locating pin on the leaf side but no pin for the axle side. I will be swapping those for some metal ones with the proper pin and hole. Also swapping over the other shock in the front end to eibach's and will get it in next week for an alignment.
    bulldog93 and BR73 like this.
  7. Mar 21, 2025 at 5:16 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Going to be pushing 100* next week so I swapped in the LC blower motor...
    Easy 15min install :thumbsup:
  8. Mar 21, 2025 at 5:56 PM
    French Avocado
    Utah / Wyo
    Nice table! And different from the kitchen counter.
  9. Mar 21, 2025 at 6:07 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    What did paint did you use and any prep work?
  10. Mar 21, 2025 at 6:45 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  11. Mar 21, 2025 at 7:57 PM
    jspec rsx
    The paint was already oxidized and showing bare aluminum in many areas. I used steel wool, and took a sander 120grit to bring down to bare aluminum as much as I could. Then just used rustoleum automotive primer and paint. To be honest not sure how long it'll last, but hopefully it'll last for quite some time.
    BR73[QUOTED] likes this.
  12. Mar 21, 2025 at 9:00 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    NSFW:
    Finally got around to installing stop tech rotors and pads. Hand slipped on last caliper bolt and dust shield got me good.
  13. Mar 21, 2025 at 9:11 PM
    centex
    centex New Member
    Finished the last 193 miles of the 825 mile trip home. Once again hit 20-30mph head winds. Burned half a tank at 80mph through this but the truck and turbo ran great. Coolant was 198* and trans was 180*. Going to up the boost this weekend.
    Anyone got recommendations on power inverters and cell boosters?
  14. Mar 21, 2025 at 10:25 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    For anyone looking to grab a Badland 3-ton jack, tomorrow HF will have them for $229, which is basically their BF pricing on them.
    sbxx312, equin, Cthulhu and 8 others like this.
  15. Mar 22, 2025 at 4:37 AM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Sorry to hear about your dad. Mine passed in '15 and left his '05 F150 to me. That truck meant way more to me than I was willing to admit. Unfortunately the frame rot on it has already left the entire bottom frame rail gone. Mt uncle and I ended up cleaning it up, putting frame caps on it, and welding. Kept it until the frame broke above the rear wheel in '23.
    I say all that to say this, check that frame thoroughly. Clean off any rust ya can w a grinder, spot paint as needed, and apply a lanolin undercoating product annually. This will keep that bad boy going for many more years
    My goal was to pass his truck and boat to my boy. Obv the truck is gone now, so we'll help him get a truck to go w Papas boat
  16. Mar 22, 2025 at 6:46 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    She’s tinted up. 15% all round. 70% sunroof. Soon 70% on windshield. Currently there’s a crack on the windshield so holding it off til that get fix.
    ceramic ir all round. This will help reduce heat for sure.
  17. Mar 22, 2025 at 8:22 AM
    Tundra family
    Tundra family New Member
    Got it packed up and ready to roll out, gonna spend the next 3 days at the creek. Do a lil yakking, a lil cliff jumpin, drown some worms and get hammered by a fire.
    Legend has it that there is a bus full of people under that bridge. When I was younger I jumped off this all the time. There are parts of this creek that are so deep divers needed specialized gas mixtures to get down there.
  18. Mar 22, 2025 at 8:30 AM
    2014 Black tundra
    2014 tundra sr5
    Black is beautiful. :thumbsup:
  19. Mar 22, 2025 at 8:45 AM
    fj40dave
    fj40dave '16 Tundra CrewMax
    '16 Tundra stock
    Rear view camera on truck & trailer, back-up lights, Firestone air bags.
    Installed new Bilstein's on my '16 Limited this week.
    Searched this forum and found high recommendations for Colton at hotshotoffroad.com and went with it.
    Highly recommended!!!! Great customer service, excellent communication and help with small details!
    I have 141K on the original shocks, they were mushy and the nose sunk when stopping.
    Now, the ride is firm, corners like it's on rails, and the leveling is great.
    Bilstein 6112 & 5160 with 1.3" setting on the front (6112's) by Colton
    equin, Gainer, TNThunder and 16 others like this.
  20. Mar 22, 2025 at 9:05 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    New 3.0s with the additional bypass tubes needs some clearancing done. Also need to rework the lower shock mount for the larger race series rod ends. Dropping the truck off for the trans and headers later today hopefully all dialed in this week so we can put some miles on this and adjust the tubes and settings.
    DPF88130, JackE5.7, equin and 23 others like this.
  21. Mar 22, 2025 at 11:31 AM
    Henry1jg
    MI
    Double checking that I have everything for my front and rear dif and TC fluid changes. Need to go get a 24mm socket and 10mm hex socket.
    Has anyone ever used a drill pump to fill their difs or TC?
    I've seen many vids with ppl using a traditional transfer pump on top of the quart of fluid, but I'm not seeing why this won't work
  22. Mar 22, 2025 at 12:24 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Installed the Coachbuilder ABS and brake brackets in the back. While I was under there I also reworked the hose for my rear diff breather.
  23. Mar 22, 2025 at 12:29 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Switched to platinum mirrors and replaced the fog light fuse so that they work again after the bumper swap.
    getting new shoes on Wednesday - 93k miles has been a good run for these Falkens
    still so many things left for octothorpeteetwoessprep…
  24. Mar 22, 2025 at 1:00 PM
    Dsptundra
    Austin TX Area
    Sticking with Falkens or going with something else?
  25. Mar 22, 2025 at 1:04 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What country were those particular Falken tires made?
  26. Mar 22, 2025 at 1:54 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I understand spring is already here, but maybe for the cold weather later in the year.
    If you get in your truck and your Carmex is too stiff to come out to the tube, just stick it in the A/C vent for a minute.
    Hot air comes out there in when the heat it set to the floor.
    You'll have lip relief in no time...:thumbsup:
  27. Mar 22, 2025 at 2:05 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Who was it saying real men don't drink milkshakes a few pages back?
    sbxx312, OldGuy03 and Tripleconpanna like this.
  28. Mar 22, 2025 at 2:20 PM
    Tundra family
    Drafted a tow truck hauling a cyber truck through town and got a lil range extension. Lol. Best mileage ever:rofl:
  29. Mar 22, 2025 at 2:23 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Weekend spring truck stuff. 2 loads to the dump. Then rinsed the tree pollen off. No sense in actually washing right now, it'll be green again in a day or 2.
    bulldog93 likes this.
  30. Mar 22, 2025 at 3:06 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I don't drink a child's drink so I should walk around with chapped lips?
    I'm not getting the correlation..:confused:
