Rear differential takes 5.5 quarts to fill up, owners manual disagrees.
Discussion in '1st Gen Tundras (2000-2006)' started by StrawberryBlowpopPrincess, Mar 21, 2025.
  1. Mar 21, 2025 at 7:28 PM
    StrawberryBlowpopPrincess [OP] New Member
    2002 sequoia RWD
    I own a 2002 sequoia RWD sr5/with the tow package (i post here because sequoia forum has no traffic and it’s essentially the same truck )
    i decided to change my rear differential fluid out. I filled it up to the fill hole until fluid started dripping out, that was at 5.5 quarts. Owners manual tells me it should have only taken 3.9 quarts. I looked around at different forums and can’t find anyone that’s in the same situation as me. also the fluid that drained out was 5.5 quarts.This is my first time draining and filling diff as the owner of the truck.
    What’s with this discrepancy, everywhere i look says around 3.9 quarts. Should I be worried?
    also is 75w-90 a good viscosity to use for my specific truck?
    G_unit3000 likes this.
  2. Mar 22, 2025 at 1:46 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    That suggests that the last guy may have overfilled it. With the truck on a level surface, add fluid until it starts to drip out the fill hole. That's how much it takes.
    The Black Mamba and G_unit3000 like this.
  3. Mar 22, 2025 at 2:45 AM
    2002 sequoia RWD
    Please read my whole post. That is exactly what I did. I filled it, yes, on a level service, and yes, until it started to drip out of the fill hole
    my question is why is there so many different answers with how much fluid it should take. Why is there this discrepancy between the 2002 owners manual and how much fluid it actually took. Every repair manual says something different but not a one of them says anything close to 5.5 quarts and I’m positive it’s the original differential.
  4. Mar 22, 2025 at 5:02 AM
    It takes what it takes. Drain hole is on the bottom. Fill hole is on the rear of the housing around halfway up. If you use those two openings, you Gucci. No idea why or how yours takes 5.5qts.
  5. Mar 22, 2025 at 8:15 AM
    x2
    Don't get hung up on the numbers in the manual. There are variations in volumes even inside the manual for your year, depending on what's in the pumpkin (open vs. closed diff), the volume of metal linked to each will be variable. Say someone had a new rear diff cover welded on. Or replaced the axle housing with one from another vehicle. There's any number of reasons. But generally speaking, that top hole should be setup in a way that ensures the diff is adequately coated in lube if you fill until oil comes out of the hole.
  6. Mar 22, 2025 at 9:25 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Do you mind taking a picture of your differential cover? Do you know if that was ever replaced due to rust? I recall someone on here had theirs leak and the shop made a custom looking one that was bigger than OEM/ Dorman one.
  7. Mar 25, 2025 at 7:55 AM
    2002 sequoia RWD
    Theres no way mine would of been replaced due to rust. My truck is 100% rust free (and im very thankful for that, glad to live in a southern state lol) Everything looks original as far as my truck
  8. Mar 25, 2025 at 9:15 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    As other people have said: level surface and fill it until it starts to weep out of the fill hole. It’s a lot worse to overfill diffs than to under fill them a little, so no need to worry about getting every last drop in there…. let it weep out until it stops and then tighten that fill plug.
  9. Mar 25, 2025 at 10:28 AM
    AZBoatHauler
    So.Arizona
    You didn’t have the rear of the truck significantly higher than the front by chance? Thinking gear oil could fill around the pinion if you really had the back up high resulting in overfilling. 1.5 qts seems like a lot to be off spec. Any chance you miscounted and it’s 4.5?
    Not trying to insult you in anyway - just running through possibilities.
  10. Mar 25, 2025 at 10:50 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Put a pan under it and remove the fill plug and let it drip for an hour or so, with thick oil you can get a lot in, even though oil level above the opening. It will drain back to the proper level. All my BMW M/C's have that arrangement on their gearboxes. I pour it in and let the excess drip out. It takes a while to do, especially if it's cold. The final answer is, fill it to the top of the threads. It's just physics, on a level surface, given time it will find the proper level. Don't overthink it.
  11. Mar 26, 2025 at 8:54 AM
    2002 sequoia RWD
    Thanks this is the best advice so far. Will definitely be doing that when i have time
    chunk[QUOTED] likes this.
  12. Mar 26, 2025 at 9:17 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  13. Mar 26, 2025 at 7:16 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    The Double cab and sequoia have a wider rear axle, i remember measuring mine and i think its about 1.5" wider per side or about 3" wider overall. This is from longer tubes on each side of the pumpkin, and also requires longer shafts for these wider rear ends. This wider rear end no doubt is going to take a smidge more oil to fill versus a narrower rear end in the extended cabs.
    I dont think its a quart worth but i could see it being a pint maybe, maybe its two pints who knows.
  14. Mar 27, 2025 at 4:55 AM
    It's about .75" per side, 1.5" total, but we filled mine with roughly 4 quarts after a full drain and cleaning of the housing. 5.5 seems way over.
    Elevatorguy likes this.
  15. Apr 11, 2025 at 6:29 PM
    2002 sequoia RWD
    I took your advice and pulled the fill plug off, on a level surface, and let the truck sit for about an hour. Roughly 1/4 a quart ended up draining out, leaving my rear differential at about 5.25 quarts, if my math is right. I’d say that helped ease my mind a little bit. Still a little weird how I can’t find any information that aligns with my experience, and I scowered the whole internet looking.
    Hopefully someone can chime in about my other question. If 75w-90 is an appropriate viscosity for my truck. (2002 RWD sequoia with the tow package). Although the owners manual called for straight 90, it was next to impossible to find, so I thought the next best thing would be 75w-90. (I mean hey 90 is still in the title, right? I might be wrong with how I think oils work so call me out if im a dumb dumb)
  16. Apr 11, 2025 at 7:15 PM
    chunk
    chunk New Member
    I think the level and viscosity are good. No more worrying about this, is my opinion. .
