New buy, Rust check
Discussion in 'New Member Introductions' started by thebighunt, Mar 4, 2025.
  1. Mar 4, 2025 at 6:38 PM
    thebighunt
    thebighunt [OP] New Member
    don
    2000 tundra
    none
    I am new to tundras, this is a 2000 tundra RS5 with 89k miles, i had it on a lift and i want to know if their is anything i should be worried about, i didnt see any rust and i figure its fine but id like advice on any issues yall know about. Thank you!
    Tacoma-Tundra likes this.
  2. Mar 4, 2025 at 7:45 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    That does look pretty good. Where are you located? Rust may not be a big factor where you are.
    BTW, Welcome from LA (Lower Alabama)!
    thebighunt[OP] likes this.
  3. Mar 4, 2025 at 7:52 PM
    thebighunt
    don
    2000 tundra
    none
    this was bought in 2000 in TN, and has never left the area, been local its whole life. TN just started salting roads with the big "cold front" came in 2024. the carfax says that this hasnt had 100 miles on it since 2021. the underside has no salt on it but i also looked into the original deal sheet and it was one of the "coated frames" so it is protected, plus when i replaced the radiator i had to take off so many skid plates, the guy i got it from bought it with ALL THE FEATURES, and added skid plates after market, some are rugged plastic but most are steel. thank you for reaching out and helping, hop for more help!
  4. Mar 5, 2025 at 11:30 AM
    Welcome from NY.
  5. Mar 22, 2025 at 3:10 AM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD DC 4.7 V8 AT 2WD
    Welcome from NC :hattip:
