  1. Mar 21, 2025 at 7:05 AM
    #9151
    lapoolboy
    lapoolboy New Member
    Meh, probably not. They aren't *that* bad...I just obsess over minor things sometimes....99 out of 100 people wouldn't even notice what I do. It truly is a sickness.
    Malinois38, Raven67 and 75tranzam like this.
  2. Mar 21, 2025 at 7:22 AM
    #9152
    buzzard317
    buzzard317 New Member
    2025 limited iforce max in lunar rock
    Thank you. I’ve owned it for 5 days today. I hate driving without it.
    Dirtsurfer83[QUOTED] likes this.
  3. Mar 21, 2025 at 9:25 AM
    #9153
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    I think your wheels would look dope on a Blueprint as well. They are sick.
  4. Mar 21, 2025 at 11:42 AM
    #9154
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Even with a low tint. Pretty hard to see inside from the outside. No issues see out even at night.
    SilveradoSwap[QUOTED] likes this.
  5. Mar 21, 2025 at 2:55 PM
    #9155
    Libagui
    Libagui New Member
    Librado
    2024 midnight black Toyota Tundra Limited, TRD offroad
    1200 pound of keystone caps and a yard (2800 pounds) of 57 gravel = 4000 pounds.20250321_172115.jpg
  6. Mar 22, 2025 at 7:31 AM
    #9156
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Color matched mirror caps, need to have them wrapped with ppf before installing. IMG_7738.jpg
  7. Mar 22, 2025 at 4:05 PM
    #9157
    23 Platinum
    23 Platinum 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    Got all the glass in my truck ceramic tinted today. Windshield, panoramic roof, everything. That way I can stay cool all day Screenshot_20250322_160130_Gallery.jpg
    RealTruck, ngoshawk, cartage1 and 5 others like this.
  8. Mar 22, 2025 at 7:04 PM
    #9158
    Frank_TRD23
    Frank
    Now seeing that for some reason made me think of Robocop.
  9. Mar 22, 2025 at 7:09 PM
    #9159
    kirkb
    kirkb Offending Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    What was the cost?
    23 Platinum[QUOTED] likes this.
  10. Mar 22, 2025 at 7:56 PM
    #9160
    SilveradoSwap
    Never seen it
  11. Mar 22, 2025 at 8:34 PM
    #9161
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    Your truck would look sweet with the wheels I have for sale :thumbsup:
  12. Mar 22, 2025 at 8:42 PM
    #9162
    60centenergy
    60centenergy New Member?
    Zack
    Greenville, SC
    2024 Lunar Rock SR5 Tundra TRD Sport
    23 Platinum likes this.
  13. Mar 22, 2025 at 8:49 PM
    #9163
    23 Platinum
    California
    X-pel was $600
    kirkb[QUOTED] likes this.
  14. Mar 22, 2025 at 8:50 PM
    #9164
    23 Platinum
    California
    I just sold my black ones and bought these 1794 ones. I do not like dark wheels
    ElJefe77 likes this.
  15. Mar 22, 2025 at 9:08 PM
    #9165
    Frank_TRD23
    Frank
    I did the Xpel plus front windshield and roof was $750. I still want to get the front windshield protection film on the outside.
  16. Mar 23, 2025 at 2:31 PM
    #9166
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Carista - Turned off ESE, disabled seat belt chimes, bumped ac to minus 2, key fob open all windows, lane change indicator to 5, and surprisingly enough.., turned the ESE back on. After having it for two years, kind of got used to it.... If anyone is on the West side of Cleveland, happy to help you change anything you like as well.
    Redward 25 and TN Tundra2 like this.
  17. Mar 23, 2025 at 6:14 PM
    #9167
    Dirtsurfer83
    Dirtsurfer83 New Member
    Olalla, WA
    '23 Tundra TRD
    Dobinsons IMS 2/1 Method 703 Toyo RT Trail 35x12.50r17
    Finally bought and installed the DR KDSS B.O.T.C.K. Pretty quick and simple install. Re-centered the axle after the lift. Hoping it gets rid of the bump steer, fingers crossed.
  18. Mar 24, 2025 at 9:00 AM
    #9168
    a71rambler
    a71rambler New Member
    Kitsap County, WA
    '25 Lunar Rock Limited w/TRD OR and Performance Package
    A bunch...
    Added TRD Pro Grill and full Rigid lighting setup with Garmin Powerswitch...
    Before:
    All this going in there...
    RealTruck, Yaboy, Twin2turbo and 14 others like this.
  19. Mar 24, 2025 at 9:14 AM
    #9169
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    How did you set up your Garmin PowerSwitch? TIA
    cartage1 likes this.
  20. Mar 24, 2025 at 9:23 AM
    #9170
    a71rambler
    Kitsap County, WA
    A bunch...
    I took off the plastic trim on the passenger side fender under the hood. Ran all my wiring in that cavity and mounted the Powerswitch under there as well. Had to modify that trim a little bit to get things to fit. Hooked power up to the positive battery post in the passenger side fuse box (I have a hybrid). Grounded it to the common ground on the inside of that fender. Also added a grounding bus bar to ground my accessories to. I also found an empty ignition hot fuse slot in that same fuse box and ran a control wire to the powerswitch so the raptor lights come on with ignition.
    Does that answer your question?
    cartage1 and ramnj[QUOTED] like this.
  21. Mar 24, 2025 at 10:27 AM
    #9171
    R1Style_
    R1Style_ New Member
    ON Canada
    2025 Tundra TRD Rally
    Can you post a pic of the empty ignition fuse slot?
    I used a fuse tap to an existing one but i'd rather use an empty one if i have the same spot available.
    Thanks!
  22. Mar 24, 2025 at 10:37 AM
    #9172
    a71rambler
    Kitsap County, WA
    A bunch...
  23. Mar 24, 2025 at 1:10 PM
    #9173
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Washed and discovered flaking clear coat on one headlight
  24. Mar 24, 2025 at 1:40 PM
    #9174
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    I have flaking clear on my headlights too. 2022 SR5...
  25. Mar 24, 2025 at 1:41 PM
    #9175
    eddiefromcali
    Eddie
    100% Stock
    Texted my service rep...let's see what she thinks
  26. Mar 24, 2025 at 1:43 PM
    #9176
    az 3rdGen
    Arizona
    Let me know how that works out... I haven't raised the issue with my dealer yet. If you get a replacement, I'll ask for a new pair lol
    eddiefromcali[QUOTED] likes this.
  27. Mar 24, 2025 at 2:02 PM
    #9177
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Yes it did. Thank you. I just picked up the front mustache from the body shop that I had color matched and going to put it all together. Will post pics as soon as I have it all assembled.
    Tundrastruck91 and astrength22 like this.
  28. Mar 24, 2025 at 2:03 PM
    #9178
    559Tundralona
    559Tundralona New Member
    Alex
    Fresno
    2023 Ice Cap Tundra Limited TRD OR Hybrid
    Diamondback switchback Eibach Pro-Lift Rays Gram Lights 57DR-X 17x8.5 +0 YotaLEDS grille lights Tufskinz overlays
    Finally got around to installing all my suspension goodies and wheels/tires, and gave her a much needed rinse over the weekend.
    Eibach pro truck kit
    JBA control arms
    Icon bump stops
    Dr KDSS BOTCK
    Gram Lights 57drX 17x8.5 +0
    Falken Wildpeaks 35x11.50
    HeyMcFly, ytank1, 23 Platinum and 9 others like this.
  29. Mar 24, 2025 at 3:06 PM
    #9179
    Retroboy1989
    Northern Utah
    Bought 1 month of carista
    Killed the seatbelt Ding
    Temperature Dial -2° C
    Smart Key Location in Front or Back Seat (instead of "anywhere in the car?")
    Lane Change Auto Flasher to 4
    I tried turning off the "come home" lights, but the settings wouldnt take.
    My truck doesn't have ESE, anything In should do before my subscription dies?
  30. Mar 24, 2025 at 3:14 PM
    #9180
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Rolling down all windows with unlock button hold!
    cartage1 and Narco like this.
