New in truck world
Discussion in 'New Member Introductions' started by bacolod2017, Oct 15, 2017.
  1. Oct 17, 2017 at 5:45 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    yes, you can change the wheels and keep those tires. However, with a 3" lift, I would recommend 295/60/20.
  2. Oct 17, 2017 at 6:10 AM
    bacolod2017
    bacolod2017 [OP] New Member
    2017 tundra sr5
    Ok thanks for tha advise..
  3. Oct 17, 2017 at 6:12 AM
    bacolod2017
    2017 tundra sr5
    You know what size of wheels and offset is better?
  4. Oct 17, 2017 at 6:14 AM
    Check out customoffsets.com
  5. Oct 17, 2017 at 6:42 AM
    Netmonkey
    Georgetown, TX
    based on your preference, go with either an 18x9 or 20x9 wheel. choosing a higher offset will generally reduce the amount of trimming if you go with larger tires (295/60/20, for example). common offsets are +18, +25, and +32. Your current wheels have a +50mm offset. The lower the offset, the farther your tires will stick out from the fender. Select an offset for the look that you want.
  6. Oct 17, 2017 at 7:45 PM
    bacolod2017
    2017 tundra sr5
    Thank you net monkey.. some idea what wheels nice in my magnrtic gray color?
  7. Oct 17, 2017 at 7:51 PM
    bacolod2017
    2017 tundra sr5
    Which one?
  8. Oct 17, 2017 at 8:09 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    For me Moto. Simpler to clean, yes I'm lazy. Nice truck and welcome!
    bacolod2017[OP] likes this.
  9. Oct 17, 2017 at 9:23 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Welcome from GA!
    Like @Patriot noted, a lot of good ideas and great folks on here willing to help.
    'I like that MGM, TSS! :thumbsup:
    Gotta put some bigger shoes on it since you lifted it. ;)
    4x4_Angel likes this.
