The TMBRR Build- Tribute to the Treefall
Discussion in '2.5 Gen Builds (2014-2021)' started by Apohl17, Feb 12, 2025.
  1. Feb 12, 2025 at 6:43 PM
    Apohl17
    Apohl17 [OP] New Member
    AJ
    2020 Tundra 1794 Crewmax 4WD
    Thanks for tuning in!
    Current picture:
    Feb 12th, 2025 clocks 10 days since I picked up my new Tundra (90k on the clock) and I'm excited to document my build not only for my personal reasons, but in the hope it sparks some ideas for other Tundra owners down the road.
    I flew down to Texas as some Midwesterners do for our vehicles - to find a clean vehicle that our lovely salt brine hasn't touched yet. After a couple months, I found the one.
    From a mile away, it looks clean, stock, like any 2020 1794 would...PXL_20250202_204159239.jpg PXL_20250202_215825308.jpg
    But when you factor in this is what the truck looked like a year ago... You can see where this thread is going to get interesting.:kona:
  2. Feb 12, 2025 at 6:45 PM
    Apohl17
    AJ
    Before anyone comments, let's just say, it's pretty nice knowing that the vehicle you drive isn't perfect.
    But there's a threshold.
    Corndog123 likes this.
  3. Feb 12, 2025 at 6:47 PM
    Apohl17
    AJ
    The previous owner had the truck repaired "enough". He drove it for 60k miles in it's current configuration with a couple current issues:
    1. 4wd not operational
    2. Little bit of roof leakage
    3. Rear power window broken
    4. No FM antenna
  4. Feb 12, 2025 at 6:49 PM
    Apohl17
    AJ
    Let's just say, 3 of those 4 things were on the chopping block for me to sort out ASAP. Here in WI, we have wintery slop dang near a third of the year. So, getting 4wd up and running and the cab sealed up were high priority.
  5. Feb 12, 2025 at 6:51 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Was the truck a copart auction find?
    Apohl17[OP] likes this.
  6. Feb 12, 2025 at 6:52 PM
    Apohl17
    AJ
    I have some pretty grand visions for the rig. I own a small overland business here in WI and I plan on showcasing this build as a bit of what our shop capabilities are, as well as showing off some of the awesome products our key vendors carry.
  7. Feb 12, 2025 at 6:54 PM
    Apohl17
    AJ
    Nope! Private party. It was "fixed" before I bought it from the previous owner. I'll get into that more soon :ohsnap:
  8. Feb 12, 2025 at 7:02 PM
    Apohl17
    AJ
    First fix: rear window motor.
    Step 1. Buy OE part 69850-0C050 for $290.
    Step 2. Pull rear seats, insulation, sheet metal...
    Step 3. Remove the window motor and regulator.
    Step 4. Reinstall and enjoy the lovely fresh air. And ability to remove headliner out the rear window down the road...
    2014 Black tundra likes this.
  9. Feb 12, 2025 at 7:09 PM
    Apohl17
    AJ
    Mod# 2. The rig was missing a radio knob. So why not prototype and 3d print one? Epoxied a 6.5 creedmoor shell casing into each of them for style points. After all, this will be a hunting and fishing rig!
    PXL_20250209_194436931.jpg PXL_20250209_210758646.jpg PXL_20250209_220143993.jpg PXL_20250209_220525496.jpg
    BlueRibbon4x4 and SAGE63 like this.
  10. Feb 12, 2025 at 7:21 PM
    Apohl17
    AJ
    Obligatory Pure Flow PC5667x cabin air filter install pic - air flow down, not up...
  11. Feb 16, 2025 at 5:29 PM
    Apohl17
    AJ
  12. Feb 16, 2025 at 5:42 PM
    Apohl17
    AJ
    Today also marks the day of installing my SDHQ sliders. Picked them up on the way back from Texas (marketplace find - thanks Chris)
    1. The bed liner (figured I'd change it up from standard powder coat, and see those this stuff holds up)
    2. The hardware and bracketry... Required a bit of modification but well made.
    3. The paint match 1794 badge, for fun...
    4. Now the install... (Note the little galvanized Z bracket for the brake line on the passenger side)
    So far I'm happy with the design. The slight angle and slight kickout is nice, and from my last ones (full plate) I think they will hold up better and be better for touch up purposes.
  13. Feb 17, 2025 at 8:22 PM
    Apohl17
    AJ
    Tossed in a new AFE ProDry S and some rear Husky X-Act liners today... Small steps for mankind!
    I've run these air filters on my last couple 4runners with great success.
    PXL_20250217_202206518.jpg PXL_20250217_202034107.jpg PXL_20250217_200920726.jpg
  14. Feb 23, 2025 at 5:50 PM
    Apohl17
    AJ
    Installed the Falcon Tow/Haul Suspension setup in the Tundra at 93,000mi. Three compression setting on the rear shocks is nice for hauling and towing.
    Re-used the OEM coils to assemble the front struts. Set them to the "Leveled" spring perch and gained me 2" lift in the front after a couple days to settle... Loving the much improved ride.
    Kit came with brackets to extend brake line mounts, as well as new bump stops over the leaf brackets.
    They should hopefully hold up well in our lovely -10 degree weather and salt everywhere.
    PXL_20250219_194228880.jpg PXL_20250219_202922522.jpg PXL_20250219_200949945.jpg PXL_20250221_024639909.jpg
  15. Feb 23, 2025 at 5:53 PM
    Apohl17
    AJ
    Also did a full oil change with 8.5 qts of Amsoil Signature 0W-20 and an EA15K04 filter. Purring like a kitten now.
  16. Feb 24, 2025 at 6:05 PM
    Apohl17
    AJ
    Threw a new front diff in the rig. Off a Sequoia with 65k miles. Before the install, I put an ECGS bushing in on the drive side. Might as well!
    Pulled the bearing with a universal bearing puller and it worked great.
    PXL_20250218_001257913.jpg PXL_20250218_234937964.jpg PXL_20250218_235720294.jpg PXL_20250219_001606019.jpg PXL_20250219_023447616.jpg
  17. Feb 24, 2025 at 6:06 PM
    Apohl17
    AJ
    Installed the Morimoto 3rd Brake Light with rapid flasher module. Fantastic upgrade over OEM.
  18. Feb 24, 2025 at 6:09 PM
    Apohl17
    AJ
    Also installed Morimoto Puddle Lights. Wayyyyyy brighter than stock! Great cheap upgrade.
    PXL_20250218_233426900.jpg PXL_20250218_233521859.jpg PXL_20250218_233621640.jpg PXL_20250218_234200373.jpg PXL_20250218_234210202.jpg
  19. Mar 2, 2025 at 7:10 AM
    Apohl17
    AJ
    Fixed the busted Sharkfin antenna up on the roof.
    OEM PN: 86760-04010.
    Great to have my FM tuner back up and running!
  20. Mar 8, 2025 at 5:18 PM
    Apohl17
    AJ
    Front husky X-Act...super impressed.
  21. Mar 8, 2025 at 5:21 PM
    Apohl17
    AJ
    Tailgate rattled a bit - took a plastic trim plug, cut the tip off so the plastic acted like hooks, and stuck it in the rubber bumper hole the tailgate should register against, on both sides. Rattle fixed!PXL_20250302_163535731.jpg
  22. Mar 8, 2025 at 5:27 PM
    Apohl17
    AJ
    Found a used TRD Pro grille on marketplace that was the wrong color. Removed the valence, gave it a nice new black paint job...
    Painted the Toyota lettering Bronze to match my 1794 badge and sliders...
    And voila:
  23. Mar 12, 2025 at 8:04 PM
    Apohl17
    AJ
    Installed the coachbuilder +2 shackles and carrier bearing drop today. 93500mi on the clock. Wow, what a difference in small bump compliance and "bed bounce". Floats over cracks and bumps in the road and gravel significantly, and gained almost exactly 1.25" rake in the rear.
    I'll do a write-up on this, but some quick action shots of pressing out the leaf bushings was easy with a rental BJ press.
    PXL_20250311_204056591.jpg PXL_20250311_204528443.jpg PXL_20250311_200154474.jpg PXL_20250311_212756238.jpg PXL_20250311_200417284.jpg
  24. Mar 17, 2025 at 12:19 PM
    Apohl17
    AJ
    Installed Morimoto 2 Bangers as ditch lights. 94200mi.
    Ran the Morimoto switched relay harness and used their Stainless steel brackets.
    Ran working through firewall and installed the push button switch under the overhang of the armrest for easy on-off switching. These lights are fantastic for deer illumination with the combo beam. Super easy install!
  25. Mar 18, 2025 at 7:02 PM
    Apohl17
    AJ
    Took the rig out for a little flyfishing today. Really stoked to be where I'm at with the build in such a short time.
  26. Mar 29, 2025 at 2:24 PM
    Apohl17
    AJ
    Upgraded my blower motor today with the LC OEM from Fred Anderson. Made a significant difference and I like never have to think about brushes failing down the road. Would highly recommend.
  27. Mar 29, 2025 at 2:27 PM
    Apohl17
    AJ
    Also, de-chromed the mirrors with OEM caps. Super happy with this. PXL_20250329_191206799.jpg PXL_20250329_191807036.jpg
    Black@Blue19 and J&ATundra like this.
  28. Apr 6, 2025 at 6:50 PM
    Apohl17
    AJ
    Did a drain and fill of the transmission today at 95.5k mi. OEM ATF WS fluid. Drained 4qts, put in 4.5, did the D-N shift procedure until the D light came on, and drained the .5 qts back out. Super smooth. And definitely made a difference in shift quality from the quick test drive I took.
    PXL_20250406_230105640.jpg PXL_20250406_230049203.jpg PXL_20250406_232558081.jpg
  29. Apr 7, 2025 at 7:20 PM
    Apohl17
    AJ
    Installed the RCI front engine skid on the tundra. Super impressed. Have fun CBI, LFD, and Victory in the past and RCI is up there in design and build quality!
    PXL_20250405_012725238.jpg PXL_20250405_005332338.jpg PXL_20250405_005316696.jpg
  30. Apr 7, 2025 at 7:23 PM
    Apohl17
    AJ
    Also tossed on the RCI Steel 38gal fuel tank skid. Bought the TRD fuel straps and after the replacement of those three, it was about the easiest install a man could ask for. Six nuts and washers. Very happy to have some protection on the tank.
    TNThunder likes this.
