  1. Mar 18, 2025 at 1:55 PM
    #9091
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    FINALLY got around to fixing the creaking noise between my stock TRD skid plate and my Talon’s garage cat shield. No more noise!
    PapaDave418 and Yaboy like this.
  2. Mar 18, 2025 at 2:03 PM
    #9092
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Beatsonic dual charger
    RatPanda, Miker24, Zudrick and 8 others like this.
  3. Mar 18, 2025 at 2:33 PM
    #9093
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Swing case after work yesterday:
    Amerex fire extinguisher mounted on The Bracketeer seat bracket after work today:
  4. Mar 18, 2025 at 2:33 PM
    #9094
    Dirtsurfer83
    Dirtsurfer83 New Member
    Olalla, WA
    '23 Tundra TRD
    Dobinsons IMS 2/1 Method 703 Toyo RT Trail 35x12.50r17
    Nice! How long of an install? Getting sick of cords all over my cab
  5. Mar 18, 2025 at 3:16 PM
    #9095
    eddiefromcali
    Eddie
    100% Stock
    took me 30 mins because I couldnt get my damn shift knob off. Fishing the harness down/around the headunit was easy, it just drops down and out the bottom. Everything snaps into place like stock. Oh, and I also had one of those red clips go awol on me when I was taking it off the oem charger...found it under the truck somehow. Im still keeping my ICS mount on the dash, but this will be nice at night when I dont want a bright screen blinding me.
    Dirtsurfer83[QUOTED] and Raven67 like this.
  6. Mar 18, 2025 at 3:44 PM
    #9096
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Ajt designs has a nice video on removing the shifter knob, seems simple enough. I can see how it could be a pain if you dont know about the little piece to push over.
    https://youtu.be/FxildkY2Fkk?si=00VVqPecNTmIDaxy
    I might order that knob, their knobs are built so well, this would be a good compliment to match the radio and drive mode knobs.
    TN Tundra2 likes this.
  7. Mar 18, 2025 at 3:47 PM
    #9097
    SilveradoSwap
    Had swing cases in my Silverado, worth the money imo.
    RealTruck and BlackNBlu[QUOTED] like this.
  8. Mar 18, 2025 at 3:48 PM
    #9098
    SilveradoSwap
    Didnt know this existed, seems like a worthy upgrade, especially when carry passengers with charging needs
    eddiefromcali[QUOTED] likes this.
  9. Mar 18, 2025 at 3:49 PM
    #9099
    eddiefromcali
    Eddie
    100% Stock
    That's what I was following out my pocket screwdriver was too big. Ended up using my spare pocket knife I found in the console.
    I like the knob but am afraid it might get too hot in SoCal summers
    SilveradoSwap[QUOTED] likes this.
  10. Mar 18, 2025 at 4:00 PM
    #9100
    SilveradoSwap
    U make a good point in heat. Ceramic tint would help but you never know.
  11. Mar 18, 2025 at 5:44 PM
    #9101
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Just got the windshield and moonroof ceramic tint done yesterday. Hope it hold back this texas summer heat!!!
    Raven67 and oddhours like this.
  12. Mar 18, 2025 at 6:09 PM
    #9102
    earlwright239
    earlwright239 New Member
    2022 Army Green Tundra SR5 TRD Sport
    Thats all great what you did to the truck. Blah blah blah. What's in red on the lift in the background? I'm a truck, sportscar and old school guy.
    BlackNBlu[QUOTED] likes this.
  13. Mar 18, 2025 at 6:11 PM
    #9103
    Retroboy1989
    Northern Utah
    Yes. Welcome to rear wheel drive.
    How much drilling for the swing case?
    VCheng[QUOTED] likes this.
  14. Mar 18, 2025 at 6:28 PM
    #9104
    bailey bulldog
    bailey bulldog New Member
    Have any pics?
  15. Mar 18, 2025 at 6:57 PM
    #9105
    SilveradoSwap
    What percentage did u get on both?
  16. Mar 18, 2025 at 6:59 PM
    #9106
    Dirtsurfer83
    Olalla, WA
    '23 Tundra TRD
    IMG_8193.jpg IMG_8191.jpg IMG_8190.jpgQuickest “mod” I’ve done. Quick hacksaw, and the GFC is locked
  17. Mar 18, 2025 at 7:18 PM
    #9107
    BlackNBlu
    Rich
    MN
    4 holes for the pivot bracket in the aluminum bulkhead next to the tail light.
    4 holes for the latch in the FRP up by the wheelwell.
    About an hour start to finish. A little tough to access the back side of the holes to install the bolt plate brackets and you have to be careful when removing the tail light.
    Otherwise, pretty straight forward job.
    RealTruck likes this.
  18. Mar 18, 2025 at 7:37 PM
    #9108
    BlackNBlu
    Rich
    MN
    Well, 2 out of 3 but only if you consider 1992 old school.
    The short version:
    '92 GMC Jimmy 2 door, 2WD. (Remember the Typhoon? SUV version of the Syclone pickup? Same body.)
    Custom frame from the firewall on back, new floor, recessed firewall. Engine setback 8". Coil overs, C6 brakes, C6 Grand Sport wheels 19x10F and 20x12R.
    I have a low mile L33 (All aluminum 5.3L truck "LS" motor) that's going to get a mild refresh and twin Wuhan whirly boys. Have most of the hardware.
    Still need to settle on engine management.
    And replace the LT1 style T56 that's in there for mockup with a Tremec T56 Magnum.
    Rear axle is a narrowed Strange 12 bolt originally from a 4th gen. F-body.
    Rear suspension is 2 link with torque arm and a watts link.
    Still needs a lot of work.
    I might finish it before I'm dead.
    earlwright239[QUOTED] likes this.
  19. Mar 18, 2025 at 8:03 PM
    #9109
    Dirtsurfer83
    Olalla, WA
    '23 Tundra TRD
    That’s a pretty quick install! I was assuming it was gonna be at least a 4 beer install, lol. Looks good. I might tackle this one
  20. Mar 18, 2025 at 8:09 PM
    #9110
    lapoolboy
    lapoolboy New Member
    30 minutes *IS* a 4 beer install. :cheers:
  21. Mar 18, 2025 at 8:11 PM
    #9111
    Dirtsurfer83
    Olalla, WA
    '23 Tundra TRD
    :rofl:Touché!
  22. Mar 19, 2025 at 6:34 AM
    #9112
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    I'll confirm it's a pretty quick install. I didn't time myself, but I did struggle with getting the cable to drop down the dash. I underestimated how dark my garage was, and apparently I have a big fat head. I couldn't get my head in there for a good look from the top. When I did my old eyes were so close they couldn't focus. Definitely a worthy mod.
  23. Mar 19, 2025 at 7:58 AM
    #9113
    Frank_TRD23
    Frank
    The front is a 70- blue hue tint color and the top is 20. Side and rear re factory. I'll get some photo up this weekend.
  24. Mar 19, 2025 at 8:00 AM
    #9114
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    need to finish tint! kill that heat
  25. Mar 19, 2025 at 8:02 AM
    #9115
    Frank_TRD23
    Frank
    Yeah, will spread out the cost!!! Had my wife Grand cherokee windshield done couple years ago made an easy decision to always get ceramic tint. Her windshield held back that heat by alot which her doors l, you could feel that heat .
    oddhours[QUOTED] likes this.
  26. Mar 19, 2025 at 8:49 AM
    #9116
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    ARCOVT23, cody.tx, RealTruck and 8 others like this.
  27. Mar 19, 2025 at 12:07 PM
    #9117
    lapoolboy
    Ok guys, calm down with the badass-looking trucks. Keep them stock....I'm supposed to be the only one turning heads dammit!
    Siblue and astrength22 like this.
  28. Mar 19, 2025 at 1:23 PM
    #9118
    Frank_TRD23
    Frank
    Does this site need a truck of the month on their main page???
  29. Mar 19, 2025 at 1:50 PM
    #9119
    lapoolboy
    Yes! Other forums I've been on had a TOTM. Let's do it!
    RealTruck and astrength22 like this.
  30. Mar 19, 2025 at 2:50 PM
    #9120
    eddiefromcali
    Eddie
    100% Stock
    Topped off my coolant levels yesterday because it looked low after the engine swap.
    Doesn't look topped off right now. Weird
