When did your OEM brake pads finally wear out?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 737fixer, Sep 3, 2022.
  1. Aug 29, 2024 at 11:04 AM
    #61
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    I'm at 96K a with the original brakes and rotors. I had a lot of maintenance completed at 90K and they told me my pads still had just under 50% of the pads left. I keep an eye on them but I don't drive my truck in traffic much or tow anything. Checking them regularly at higher mileage definitely makes sense an you may be pleasantly surprised.
    nobodyintexas[QUOTED] likes this.
  2. Aug 29, 2024 at 1:04 PM
    #62
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    My fronts were at 4mm at 110,000, rears were about half way gone
  3. Aug 29, 2024 at 2:00 PM
    #63
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Around 55,000 miles. Started vibrating around 30,000, but wasn’t too noticeable. However, my pads were worn down.
  4. Aug 30, 2024 at 3:39 AM
    #64
    Bammer
    Monroe, CT
    50k on the fronts, 70k on the backs
  5. Aug 30, 2024 at 3:49 AM
    #65
    CMikeB
    CMikeB New Member
    Mechanic tells me I'll see 100,000 miles on my OEM brakes. My 2010 SR5 has 88,000 now. When I do replace them, I'm totally sure the component quality is the same as it was in 2010!!
  6. Aug 30, 2024 at 11:03 AM
    #66
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    On the front - 2mm outter, 4mm inners. Bought the truck used with 11k on it. New rotors and pads will go on at 45k miles. Rotors are pretty warped
    Rears have 8mm left on them.
  7. Aug 30, 2024 at 11:11 AM
    #67
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    111K on the ODO and still haven't changed them yet. I got the truck at 60K but they did not look new or recently changed, still OEM pads and rotors.. I will be getting OEM when they are due for replacement.
    Sean492 and CMikeB like this.
  8. Aug 30, 2024 at 6:24 PM
    #68
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I finally started getting some screaming from the fronts at 93k, noticeable to me in heavy traffic with the windows down. Fronts were at 2mm and rears were at 8mm.
  9. Sep 2, 2024 at 12:38 PM
    #69
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Just checked my front driver and passenger rotors, sitting at 31mm but these EBC yellow stuff are worn due to a lot of towing these past 5k miles. Have had them so far for about 15k miles.
    What’s the min specs for OEM rotors?
  10. Sep 2, 2024 at 1:53 PM
    #70
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    77,000 for the front and 85,000 for the rear.
  11. Sep 2, 2024 at 5:39 PM
    #71
    TundraBrew
    TundraBrew New Member
    Should be stamped on the rotor somewhere.
  12. Mar 18, 2025 at 6:34 AM
    #72
    JEHTUNDRA
    JEHTUNDRA New Member
    2021 Crewmax SR5 4x4
    I’m at 84,000 on original pads. Still life in them.
    CMikeB likes this.
  13. Mar 18, 2025 at 12:03 PM
    #73
    Sean492
    Sean492 New Member
    Winston Salem, NC
    I'm have 101K on my Tundra. I just got inspected two weeks ago and (I think) they said I'm at 4mm and they all look fine. I drive slow and I don't haul anything so that may help.
  14. Mar 18, 2025 at 12:19 PM
    #74
    FREEK
    FREEK New Member
    Darren
    Olathe, KS
    2019 Tundra Limited Crewmax 4X4
    60,000 to date, checked them over the weekend. Good percentage left!
