  1. Mar 17, 2025 at 12:14 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Garage is slowly coming together. Picked up a couple cabinets for extra storage and tabletop space. Elected to not use casters so I could shim and keep both on the same plane
  2. Mar 17, 2025 at 7:34 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    I did not think that roof was doable correctly in 2 days. Hope it goes smooth
  3. Mar 17, 2025 at 7:39 AM
    TaquitoBandito
    Joel (AKA Bif)
    Ours definitely isn’t :oops: Thanks!
    Lifer[QUOTED] likes this.
  4. Mar 17, 2025 at 9:10 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Put up some shelves in my arts & crafts/gun/reloading/guitar room
    Blufin, TaquitoBandito, Lifer and 2 others like this.
  5. Mar 17, 2025 at 2:12 PM
    AZTundra
    Paul
    Phoenix, AZ
    Finally finished (almost) a project that has been ongoing for quite a while. It was delayed a couple times due to the insane AZ heat and my work schedule. Our back patio had drywall on the ceiling which had been repaired a couple of times and continued to crack along the tape lines. Not sure why it would happen every couple of years, but it did. Maybe the change in weather and or humidity? I tore the drywall down and found wood paneling underneath the drywall which was removed also to begin with a clean slate. The old ceiling fan in the center was removed along with hundreds of nails and screws.
    I first painted the trim around the ceiling which had the old colors exposed that were hidden behind the drywall. A new ceiling fan brace was installed in the center along with running electrical for ten 6" recessed lights and I added a power outlet to connect two 6.5" bluetooth powered speakers which required an outlet for power.
    I ordered 16ft long T&G pine boards from a local lumber yard thinking they'd be more straight and easier to work with as opposed to just grabbing some from the local Lowe's or Home Depot. The boards were all sanded down and then coated with Benjamin Moore Woodluxe stain and sealer. I then started to hang the boards ensuring the first row was completely straight. I ended up cutting the boards down from the 16ft length to random lengths for a staggered look. I quickly found out that the boards are not that straight...they bowed inward, outward, up, and down. I ended up cutting a small piece of 2x4 and used an "L" shaped bracket to attach the 2x4 to a ceiling beam. The 2x4 was also screwed into a standard clamp. I was able to screw the bracket into the beam and then use the clamp to push and seat the wood into the previous row. This was a huge help, but very time consuming as I practically needed a clamp every two feet to butt the rows up tight.
    I continued to install a couple of rows each weekend until I got to the point to cut out for the recessed lights, speakers, and fan. I used a hole saw for the lights and then ultimately used a template and jigsaw for the ceiling fan and speakers.
    Just finished the last row on Sunday. All that is left now is to buy and install a new ceiling fan and also get some trim to go around the border which will be painted in the gray house trim, but will do white to match the house on the back row trim.
    The lights have a remote control that you can change the color temp as well as the output level. I think 10 lights may have been overkill. I'm currently running the lights on 2700K color and only 30% light output.
    I'm not a carpenter by any means. This was my first time tackling a T&G install, but I'm pretty pleased with the way it turned out. It did take much longer than I thought to get everything completed. If I could go back in time I'd probably just hire it out to someone else to complete.
    Here are a few pics that I took along the way.
    Wallygator, Yota303, SAGE63 and 24 others like this.
  6. Mar 17, 2025 at 3:05 PM
    Lifer
    Lifer New Member
    Vince
    Good job that looks excellent!
    TaquitoBandito and AZTundra like this.
  7. Mar 17, 2025 at 5:26 PM
    Florida AF
    Logan
    North Florida
    Thank you everyone for the votes on the tree... still no idea, we know pleated woodpeckers were involved, but the shredding is unlike anything we have ever seen before...
    meanwhile.... todays events:
  8. Mar 17, 2025 at 9:49 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    @AZTundra Great work there, it looks fabulous.
    AZTundra likes this.
  9. Mar 17, 2025 at 9:57 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    New mini project is making a guest coat hanger from some scrap butcher block. General design before putting together/sanding/staining/poly:
    drobb, Lifer, TaquitoBandito and 8 others like this.
  10. Mar 18, 2025 at 1:52 AM
    Tundra family
    Tundra family New Member
    http://www.popupparts.com/
    Upcoming project will be to replace the 24 year old lift on my roof. It's been catching in a spot and chewing up the crank.
  11. Mar 18, 2025 at 5:39 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    I think you've mentioned it in here before, but what kind of PUP do you have? I've come across a lot of sites when we were fixing ours up.
    TaquitoBandito likes this.
  12. Mar 18, 2025 at 5:42 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Had to build a quick rolling chair while I'm working on the truck or washing it. Noticing that bending down and crouching on knees is killing my back. So I came up with a cheap solution for now... Maybe later on I'll get fancy and get something from the store.
    PXL_20250317_204208770.jpg PXL_20250317_204221065.jpg PXL_20250317_204212290.jpg
  13. Mar 18, 2025 at 7:05 AM
    Tundra family
    It's an 01 StarCraft star blazer.
    That was hilarious, while searching for specs I saw one for sale and this MF tried to say you can haul it in a Dakota. :rofl:
    Only if you want the Dakota to pop a damn wheelie.
    It's only about a 300 lbs more than the payload on my tundra is all. LOL
  14. Mar 18, 2025 at 7:53 AM
    SnrDisregardo
    Wade
    IL
    So most of the RV/Camper companies use the same parts and products. Here are a couple that might help. We have a '94 Starcraft PUP that I was able to procure a lot of parts from these sites.
    https://www.hannarv.com/?srsltid=AfmBOorlW_Oropd5wiIqPduijff4mVCMI1BbdoBePQCq_sqJYtcrW-an
    https://robertssales.com/
  15. Mar 18, 2025 at 8:03 AM
    Tundra family
    Beautiful, thank you kindly. Random question, how common is it for these campers to have only 3 jacks? This weirdo has 2 corner jacks on the driver's side and one centered on the passenger side. It's weird!!
  16. Mar 18, 2025 at 8:05 AM
    SnrDisregardo
    Wade
    IL
    I'm not overly familiar with the drop in's, but my thought process would think you would need one in each corner.
    popupportal.com is another good resource. Not as good at this site, but some off beat questions get asked.
    Did you get an "owners" manual with it? I use that loosely as they are a general manual that goes across models.
  17. Mar 18, 2025 at 8:14 AM
    Tundra family
    Unfortunately no, it was a junkyard find that I brought back to life. All I have is a this spec sheet.
  18. Mar 18, 2025 at 8:18 AM
    SnrDisregardo
    Wade
    IL
    This is just googling a 01 Starcraft Blazer that came back.
  19. Mar 18, 2025 at 8:36 AM
    Tundra family
    Home sweet home. I love that I can use the gaucho with the top down, makes it a little easier to be stealthy. I guess some just have 3, it's weird but pretty common from what im finding.
    SnrDisregardo and TaquitoBandito like this.
  20. Mar 18, 2025 at 9:05 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    My dad has one and there's 4
  21. Mar 18, 2025 at 9:34 AM
    astrength22
    astrength22 New Member
    2023 Silver Tundra Platinum
    You did a great job! Your house looks a lot like mine, we could be neighbors lol
    I did this to my covered patio in 2019. Put up a substrate of 1/2” plywood screwed to the joists then opted for 1/4” thick T&G and could toe nail the tongues anywhere since had the plywood under it.
    Having done that, I would never use 1/4” T&G again. Not straight and breaks too easily. I like yours!
    Have since tiled the patio and had the pool decking resurfaced, but the ceiling has held up well. Used quarter round for trim.
  22. Mar 18, 2025 at 9:36 AM
    Tundra family
    Ive never seen one before with 3, but it's definitely designed this way because on the side with 2 the jack mounts are also tie downs but on the other side there are eyelets.
  23. Mar 18, 2025 at 9:56 AM
    AZTundra
    Paul
    Phoenix, AZ
    Looks great! I bet having the plywood underneath made it go a lot quicker for the install. I was thinking of using quarter round as well on 3 of the 4 sides and then using a flat board along the back of the house similar to what was there prior. Glad to hear it’s been holding up well.
    I’m tempted to drop a cable line like you did before the trim goes up.
    Next up is redoing our sprinkler system front and rear. It’s at least 19 years old (was there when we moved in). It sprung a few leaks and when those were patched it leaks it new areas. Landscaper said it’s time to tear it out and redo the lines. After that, I’m going to look into resealing and getting color back to our stamped concrete that covers the patio and around the pool. I’ll be sure to update with pictures as things get underway.
    astrength22[QUOTED] likes this.
  24. Mar 18, 2025 at 10:39 AM
    astrength22
    I ran irrigation lines out back and front, house never had any prior to moving here in 2018! Which is hard to believe in AZ, and there was natural grass in the back. I installed artificial grass in back and front. Put in all new plants/trees and new drip lines. Did the back in 2019, we remodeled (added on) so did the front from scratch last year. So far so good
  25. Mar 18, 2025 at 4:51 PM
    astrength22
    I did all my landscaping projects prior to owning a truck… Lots of borrowing, here’s a few pics of the front. I did everything but the pavers (have a good paver guy!)
  26. Mar 19, 2025 at 7:08 AM
    WAtundra4x4
    Den
    Wet side WA
    I was gone on two one week trips to AZ and CA that had a week at home in between. The day after the last trip we still had a little snow left from the day before but 6 deer were lounging in the back yard. My neighbor texted me the night before we left on the last trip “I heard a tree come down behind your house”. I went out and looked but the green belt is dense and is a down ward slope. While I was back there I noticed some bear scat on the grass. My yard has been taken over by the critters. IMG_9111.jpg
  27. Mar 19, 2025 at 7:13 AM
    Tundra family
    im jealous, only critters I ever see in my yard are the neighbors dogs shittin in it.
  28. Mar 19, 2025 at 7:21 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    All we get are coyotes and some coons...the kind momma chases off the back porch with a broom
  29. Mar 19, 2025 at 8:00 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    We have all kinds of wildlife, deer, raccoons, skunks, turkeys, coyotes, rabbits, fox, mountain lions etc.
    I just spotted this guy last weekend for the first time roaming around with a couple turkeys.
  30. Mar 19, 2025 at 8:09 AM
    Tundra family
    i get woken quite often by peacocks, sounds like a damn scream for help sometimes. :eek2:
