Parts interchangeability: door handles and fuel filler door?
Discussion in '1st Gen Tundras (2000-2006)' started by Bought2Pull, Mar 16, 2025.
  1. Mar 16, 2025 at 10:10 PM
    Bought2Pull
    Bought2Pull [OP] New Member
    Greg
    WV
    2006 Tundra 4 door
    Looking for OEM replacement outside door handles and a fuel filler door to fit my 2006 Tundra double cab.
    Are front and rear outside door handles the same?
    Will all door handles and fuel filler doors across the various models (Standard cab, Access, Double cab) fit?
  2. Mar 17, 2025 at 3:26 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    NO
    No. At least with the key fuel door vs non key, they have different filler knock housings. You can search on here and see where others wanted to and "tried" to make it work. It can be made to work with modification / fabrication, but they are not the same.
  3. Mar 17, 2025 at 9:50 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Didn't think about the key part. Midnight thinking fails again!
  4. Mar 17, 2025 at 9:58 AM
    Well, not only that, but the bedsides between a double cab and the access/regular cab are different, so I would assume the gas door may be also.
    Earlier years have keyed doors; later cabs don't.
    Door handles on access/reg cab are flush mount, double cab stick out. Rear door handles on double cab don't have key holes, IIRC.
    So many differences.
  5. Mar 17, 2025 at 9:59 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    OK then, better to find out now than find out later!
