Parts ID help needed
Discussion in 'General Tundra Discussion' started by HGSFL, Mar 17, 2025.
  1. Mar 17, 2025 at 7:46 AM
    HGSFL
    HGSFL [OP] New Member
    Larry
    2013 Platinum
    Need help identifying the plastic piece that holds the tailgate latch rod in line (not the retainer clips). Tried searching everywhere with no luck. Any help would be greatly appreciated. its a 2013 model. See attached pic, thanks in advance
  2. Mar 17, 2025 at 8:27 AM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
  3. Mar 17, 2025 at 8:30 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    This site never ceases to amaze me.
  4. Mar 17, 2025 at 8:38 AM
    HGSFL
    Larry
    2013 Platinum
    Thank you Thumper! you are the man! now let me see if i can find it to order it
    Thumper_6119 likes this.
  5. Mar 17, 2025 at 11:29 AM
    Thumper_6119
    Check the link that I posted. It should let you order from there. It is a Toyota dealership. (It should be for a 2013 Platinum, but it might make you fill in the vehicle again).
  6. Mar 17, 2025 at 12:25 PM
    HGSFL
    Larry
    2013 Platinum
    Thanks brother, I was able to order from my local dealer for pick up. should have it in a couple of days. I could not find a parts diagram for the tailgate that showed that part untill you sent that one. Much appreciated
  7. Mar 17, 2025 at 12:35 PM
    Thumper_6119
    You're welcome! I'm happy that I could help!
    Raven67 and Tunrod like this.
  8. Apr 3, 2025 at 6:25 AM
    This is perfect advice. Just a note to say though, 69749 is the parts category (Type: "clip"), 34010 is the part identifier in that category. Put the two together, and you've got the full part number, which you clearly linked.
    You definitely pointed to the right part, but I'd include this. While the post I'm about to link is technically content for 1st gen Tundras, the plastic clippy part numbers inside the following post are also correct for 2nd gen Tundras @HGSFL or whoever else needs it:
    https://www.tundras.com/threads/1st...ir-overhaul-beef-up-lube-you-lazy-sods.94180/
    And the advice inside the post I linked - generally speaking - is applicable to ALL Tundras. Everyone needs to periodically service your tailgate mechanisms to avoid breaking handles and stuck latches. But in the event anyone else needs to update their plastic clips, all the part numbers are in that linked thread.
    I'm running back to the 1st gen world now :rofl:
    Thumper_6119[QUOTED] likes this.
