Sometimes I hate being a girl…
Discussion in 'New Member Introductions' started by Helpimmagirl, Mar 15, 2025.
  1. Mar 15, 2025 at 1:16 PM
    Helpimmagirl
    Helpimmagirl [OP] New Member
    T
    2010Tundra4.6V8RWD
    4in lift
    Yea I said it! Imma chick or a “Good looking boy,” as my grandpa would say. I share this bc it’s difficult in a mans truck world to be girl… I appreciate those men who treat me with dignity and actually walk or talk me through my own repairs but some just make a joke out of ya. Now that has been said:
    How would one service their u-joints?
    My tundra vibrates on de acceleration and stops as I accelerate. I’m hoping for u joint issues instead of torque converter.
    How can I isolate the problem?
    Tundra Texan and TacomaTRD4x402 like this.
  2. Mar 15, 2025 at 1:24 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.:cool:
    I'll let someone more knowledgeable give you advice.
    Great avatar pic...:thumbsup:
  3. Mar 15, 2025 at 1:27 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  4. Mar 15, 2025 at 1:30 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Welcome, I found watching a bunch of youtube videos helped me solve just about anything on the Tundra.
    Tundra Texan and bulldog93 like this.
  5. Mar 15, 2025 at 1:37 PM
    Welcome.
    First, have you verified that u-joint (s) are bad?
    If DIY- I would mark the driveshaft & differential yoke, remove and swap out u-joints. Reinstall shaft.
    Now if you don't want to go through all that, remove shaft and take to driveline shop and have them press in new joints and balance. Reinstall shaft. This is what I would do.
  6. Mar 15, 2025 at 2:19 PM
    Welcome from NY.
  7. Mar 15, 2025 at 4:07 PM
    Yota303, 1lowlife, koditten and 13 others like this.
  8. Mar 15, 2025 at 4:34 PM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome from Texas!
  9. Mar 15, 2025 at 4:36 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
  10. Mar 15, 2025 at 4:52 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    No worries...
    I've known many Four Wheel Drive Chicks over the Years at Tacoma Territory.
    You're in the right place to figure out your issues.
    Is it a clunking feeling as you accelerate and does it ever stop?
    If it happens through acceleration as well as slowing down yes it's likely your U joints.
    Crawl under your truck and grab the drive shaft before and after your carrier bearing and give them a shake and twist while watching the U joints.
    If you see slop in any of the bearings you've found your problem.
    Installing U joints isnt that difficult,while it may be an issue your first time.
    The internet is your friend....back in my day we didnt have the internet and we had to go to our local parts store and ask questions....
    Consider yourself lucky.
    But yes you can go to your local parts store and smile nicely and they'll be happy to crawl under your truck and let you know if it's your U-joints.
    bulldog93 likes this.
  11. Mar 15, 2025 at 4:55 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Why did you post a pic of @bmf4069 ?1
    bmf4069, 1lowlife, KNABORES and 7 others like this.
  12. Mar 15, 2025 at 5:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Helpimmagirl also check the carrier bearing for excessive play while your looking over the u-joints.
    Tundra Texan likes this.
  13. Mar 15, 2025 at 8:10 PM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD DC 4.7 V8 AT 2WD
    Welcome from NC :hattip:
  14. Mar 15, 2025 at 8:15 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Eh-loha and welcome aboard.
  15. Mar 15, 2025 at 9:52 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Could it be warped brake rotors? Welcome from Northern California.
    RainMan_PNW likes this.
  16. Mar 15, 2025 at 9:55 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    this, you would have to press out your unjoints (you need a hydraulic press for that) two simplest options are take it to a driveline shop as tj mentioned and have them rebuild it or buy a new one from the stealership price should be similar
  17. Mar 15, 2025 at 11:07 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    Also I’m assuming you did the basic trouble shooting like checking your drive shaft for play etc, have you been greasing your zerks regularly? Is your truck lifted? If so could be your pinion angle
  18. Mar 16, 2025 at 12:24 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    You can also use a bench vise and the proper size socket to push the bearing cups out.
    Works like a champ.....
    1lowlife likes this.
  19. Mar 16, 2025 at 12:44 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Welcome from VA. You came to the right place. Keep posting what you’ve done and the members here will narrow it down.
  20. Mar 16, 2025 at 1:19 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Welcome from New Hampshire
  21. Mar 16, 2025 at 5:20 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
