Reset Flex Fuel Alcohol/Ethanol Percentage Level with Bidirectional Scan Tool
Discussion in '2nd Gen Tundras (2007-2013)' started by lowercaseg, Apr 25, 2023.
  1. Mar 7, 2025 at 3:41 AM
    #301
    Timwfm
    Timwfm New Member
    In orlando, If you need help.
  2. Mar 7, 2025 at 1:26 PM
    #302
    Florida AF
    Logan
    North Florida
    I try to avoid Orlando lol... but I just found out I may be going that way soon, if I do and I dont fix it first I will let you know
    Timwfm[QUOTED] likes this.
  3. Mar 7, 2025 at 1:26 PM
    #303
    Florida AF
    Logan
    North Florida
    and thank you!
    Timwfm likes this.
  4. Mar 9, 2025 at 1:03 PM
    #304
    David1
    David1 New Member
    08 tundra crewmax sr5 non jbl
    Head unit, rickford t1650, Jl audio 4/400, Jl audio 1000/1, 2 sundown sld 12's, big 4 1/0 awg, dynamat, sonic barrier 3 in 1 deadening, tow mirrors, akebono brake pads, raybestos s cut rotors,
    Hey guys I have read through alot of these pages. I need to reset my alcohol density on my 2017 tundra flex fuel. I bought the creamer elite T for toyota. I updated it and read the alcohol density. It is 55%.I went back and did the relearn. I put 3 gallons of fuel in it as I did it at the fuel pump. I drove for about 15mins and checked it. It still shows 55%. I read someone had issues because of a idatalink maestro. I have a maestro in mine. It was a plug n play syatem. I also have the remote start x. I thought the maestro would keep me from even seeing any info. So do I need to disconnect the maestro? What makes me scratch my head is. The book for the c reader says by default no reset software is included in this tool. User needs to subscribe to it. I never read anyone say they needed to subscribe to anything to have this work. I don't want to go through the whole process of removing the maestro for this tool not to work anyhow. I went to the "mall" I don't see anything that says toyota ot tundra
    Timwfm likes this.
  5. Mar 9, 2025 at 1:20 PM
    #305
    David1
    David1 New Member
    I think I figured it out. I had to back out a couple pages and I remembered someone saying special function so I went to it. I found relearn alcohol density on that list to. I ran it and a pop up came up saying do the driving test and recheck alcohol density and long ft. Will update after I do the driving part.
    Timwfm likes this.
  6. Mar 9, 2025 at 1:37 PM
    #306
    Timwfm
    Timwfm New Member
    Correct, in the Special function, there an option to reset the alcohol density. Hope it work for you
  7. Mar 9, 2025 at 1:38 PM
    #307
    centex
    centex New Member
    Your head unit should have a way to shut off the obd2 and that’ll stop the comms between maestro and vehicle.
    AZBoatHauler, Timwfm and OldGuy03 like this.
  8. Mar 16, 2025 at 2:22 PM
    #308
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Heads up x431 elite on Amazon has a $40 coupon. $129 after coupon.
  9. Mar 16, 2025 at 4:31 PM
    #309
    Timwfm
    Timwfm New Member
    Link?
  10. Mar 16, 2025 at 4:33 PM
    #310
    Leedaar
    Leedaar New Member
    2016 Tundra CM
  11. Mar 16, 2025 at 4:33 PM
    #311
    Leedaar
    Leedaar New Member
    2016 Tundra CM
  12. Mar 17, 2025 at 4:29 AM
    #312
    Timwfm
    Timwfm New Member
  13. Mar 18, 2025 at 10:21 AM
    #313
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    My truck had a slow start up. Checked battery voltage 12.5 with engine off. 13.5 engine on. Plugged this in last night (engine off), saw my voltage drop from 12.5 to 11.5, now my battery is dead. This drains a lot of power! Lol someone posted on here to have the engine on while plugged in. Good luck! I’ll reset density on my day off and report back.
  14. Mar 18, 2025 at 12:07 PM
    #314
    Florida AF
    Logan
    North Florida
  15. Mar 18, 2025 at 12:35 PM
    #315
    AZBoatHauler
    So.Arizona
    Post here if you have trouble once it arrives. Mine was stuck on European mode and took some messing with settings to get working correctly.
  16. Mar 18, 2025 at 12:50 PM
    #316
    Florida AF
    Logan
    North Florida
    Will do. I was saving up for the D7 but the truck isnt starting any better these days and I am using it more than I expected, so I figured I should stop trying to find someone local to pay and just get the tool. Plus we have toyos in the family so it wont go to waste... plus I had some credits so it was $89 with the coupon... now it just needs to work lol
  17. Mar 19, 2025 at 6:46 PM
    #317
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Update on the CReader Elite x431… it was able to read the alcohol level but I couldn’t find a place to reset. Found out my alcohol level was 0. I will return this and buy one that can reset in the future.
  18. Mar 20, 2025 at 6:10 AM
    #318
    Ericsopa
    Ericsopa Old man and the sea
    That one is the bidirectional scanner. You can reset with it.
    Here's the procedure that I sent to my son for his 2015. I don't have a FFuel, so I couldn't do everything on mine. But give it a try.
  19. Mar 20, 2025 at 7:18 AM
    #319
    Timwfm
    Timwfm New Member
    Nice PDF mike
    OldGuy03 and AZBoatHauler like this.
  20. Mar 20, 2025 at 7:25 AM
    #320
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Thank you!
  21. Mar 20, 2025 at 8:51 AM
    #321
    Florida AF
    Logan
    North Florida
    Here are the pics I took that are "missing" from your PDF. Only issue so far was I didn't look to see how bad it was before I hit the clear button.
    Ericsopa[QUOTED] likes this.
  22. Mar 20, 2025 at 8:52 AM
    #322
    Florida AF
    Logan
    North Florida
    So I didn't see how bad it was but I hit the clear button. I don't have the moment to drive it right now but I started it anyway. Holy cow, back to day 1 if not better. Fired right up and the area doesn't smell like fuel anymore.
    We will see what happens later when I fire it up again and take her out.
  23. Mar 20, 2025 at 8:57 AM
    #323
    AZBoatHauler
    So.Arizona
    :thumbsup:
    Florida AF[QUOTED] and OldGuy03 like this.
  24. Mar 20, 2025 at 3:57 PM
    #324
    Florida AF
    Logan
    North Florida
    Confirmed it has been reset. Confirmed I have no idea what it was before but she is starting better and running as expected.
    Very happy with the purchase.
    OldGuy03 and RobertD like this.
  25. Mar 21, 2025 at 9:19 AM
    #325
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Some tools are worth every penny.
    Florida AF[QUOTED] likes this.
  26. Mar 31, 2025 at 2:41 PM
    #326
    ErSlickEr
    ErSlickEr New Member
    2018 MGM Tundra 4x4 CrewMax 5.7L FFV Limited
    Update:
    The truck ran for two days and then broke down in the parking lot. I had the scanner with me. I tried resetting again three times but it wont start. Had to tow it to the nearest dealership and they diagnosed it to be a faulty pump that needed to be replaced. Got the parts ordered directly and asked dealership to just charge labor and get it replaced. Got my truck from dealership yesterday with new pump installed and everything is working great again.
    Original Post:
    Got this problem on my 2018 Tundra Limited FFV. Fuel Percentage was stuck at 15%. I could not start my truck.
    Got the tool posted in this thread from Amazon:
    LAUNCH Creader Elite Bi-Directional OBD2 Scanner for Toyota Lexus, 2025 Full System Diagnostic Scan Tool
    Performed Fuel Density Learning Value Reset and the truck started immediately.
    Did Post Reset Procedure to Complete Learning of Alcohol Percentage and confirmed Alcohol Fuel Percentage was at 0%.
    Thanks for all the help and guidance.
    PS: What was interesting is I went back and looked at the Carfax of my truck to see if this specific ECU Reset was performed. It appears that they did perform a similar ECU Software Update but it was for the Rear Oxygen Sensors where the software may not detect a malfunctioning sensor.
    The free update to engine ECU was performed on 3/14/2019 at around 57000 miles.
    My assumption is that with that reset, they may have zeroed the Alcohol Fuel Percentage.
    If so, the issue resurfaced on my tundra around 6 years(3/27/2025) or after adding around 43000miles
  27. Apr 3, 2025 at 11:19 AM
    #327
    Florida AF
    Logan
    North Florida
    Does any one have a link or reference sheet for things you can do with these tools besides reset faults/codes? Are these useful for changing truck features like lighting/horns/TPMS etc?
  28. Apr 11, 2025 at 10:38 PM
    #328
    sm_tundra
    sm_tundra New Member
    2018 Tundra Limited
    I doodled around with it and under warnings under customize settings I was able to turn off my seatbelt chimes. Fairly certain I saw where you could change lighting and such like you do with the factory h/u. Has the option to do TPMS program under the Service function menu, whether it works or not is anyone’s guess.
  29. Apr 12, 2025 at 6:43 AM
    #329
    Florida AF
    Logan
    North Florida
    I'll play with it soon thank you!
  30. Apr 15, 2025 at 7:54 AM
    #330
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    I bought the C Reader a week ago and we completed the alcohol % reset last weekend on my 2018, and my sons 2016. Thanks to Ericsopa and Florida AF for the cheat sheet of the screens! Both trucks reset easily and have been so much better starting up this week. After spending money on the fuel pump a couple of years ago and still dealing with the issue I am so glad that this worked. Neither of us added any fuel after the reset, we went for the drive and the process worked fine. I can't wait to see what else the C Reader can do for the Tundras.
    MatD13 and RobertD like this.
