Opinion on a truck lifted with King 2.5 coilovers and 35s
Discussion in 'Suspension' started by aWoodworker, Mar 14, 2025.
  1. Mar 14, 2025 at 6:50 AM
    aWoodworker
    aWoodworker [OP] New Member
    Jonathan
    I'm looking at a 2017 Tundra CrewMax that has been lifted with King 2.5 coilovers with reservoirs and has 35" Nitto Grappler tires and am hesitating because I typically lean towards stock vehicles. If you look at my other thread I'm searching for a 6-seater truck that will be used for my work and my 4-piece family to pull enclosed trailers and a 21-23' camper, go on roadtrips, and get us up NFS roads, access roads, and the like. Will I wish I'd bought a truck with stock suspension if I get one that's been lifted like this with oversize tires?
  2. Mar 14, 2025 at 6:58 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Towing with 35s will not be fun unless it has been regeared.
    ColoradoTJ likes this.
  3. Mar 14, 2025 at 7:01 AM
    Your use case, family hauler and tow rig leans towards the factory setup, not some lifted brodozer. All of those suspensions and wheel and tire “upgrades” will fight you when loading and unloading the truck and even more so when towing.
    cue the 2nd gen family hauler that tows a double horse trailer daily on 35s crowd to refute this info…..
  4. Mar 14, 2025 at 10:41 AM
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    Different kind of horses for me…
    I’ll regear eventually and possibly to the RAS for the rear, but it works for now. To @KNABORES point, everything a stock truck does, a lifted truck does worse except looks better when doing it. My 2014 has been lifted for five years and I have no regrets.
  5. Mar 14, 2025 at 10:57 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    There's an honest answer! :thumbsup:
  6. Mar 14, 2025 at 11:09 AM
    rcsbguy
    rcsbguy New Member
    I’d do it if it’s maintained well. King 2.5s valved correctly will have a much better ride, towing or not, on street and fireroads.
    You’re going to need airbags either way if you’re towing. So doesn’t matter if it’s stock or lifted.
    You can just swap the 35s to 33s and don’t need a regear. But even towing on 33s, I’d go 5.29s if you’re in a hilly area.
    My lifted truck does everything a stock truck does but way, way better.
  7. Mar 14, 2025 at 11:13 AM
    You do not need airbags to tow
  8. Mar 14, 2025 at 11:18 AM
    22OffRoad
    22OffRoad New Member
    2016 SR5 CM 4x4 TSS
    King Off Road Shocks, 33"s
    Probably a small detail, and maybe one you've already considered, but at some point the King Shocks will need to be rebuilt. Might ask the current owner the last time they were rebuilt or how many miles they have on them.
    At some point during ownership, you'll either need to have a second set of suspension ready to swap out if you need to keep using the truck while the Kings are rebuilt, or plan for a few days of downtime with your truck on jack stands or in a shop while the kings are rebuilt.
    Dealing with the logistics of getting mine rebuilt now, bought the truck (2016 SR5 Crewmax) with the kings installed previously. My rebuild quote is $600.
    DontTazeMeBro likes this.
  9. Mar 14, 2025 at 2:11 PM
    aWoodworker
    Jonathan
    I'm hearing diverse opinions. Might this be because each owner has different expectations? Such as towing speed. I'm not looking to tow 6,000lbs at 80mph regularly. The trailers I'd tow a few times a month and would be no more than 4,500lbs, with a once a year tow of maybe more.
    Knabores - your suggestion is perhaps the most sensible approach for me to take. I'd just have to wait and keep spending a half hour-hour a day searching.
    This wouldn't be a question except front bench Tundras don't come up often, much less with good miles for a good price.
  10. Mar 14, 2025 at 2:18 PM
    rcsbguy
    rcsbguy New Member
    Hook up 4,500lbs on stock springs, that drives so poorly.
  11. Mar 14, 2025 at 2:21 PM
    rcsbguy
    rcsbguy New Member
    Just buy it. Worse case you put it back to stock and get a new alignment. You’ll make money selling the shocks.
    I have Kings and love it. No way would I ever go back to stock, yet drive a stock truck. It’s night and day better. You’ll get diverse opinions from the “must stay stock” people and the “must modify” crowd.
    That being said, a 4 door Tundra isn’t a rare combination with a bench seat. If you believe stock is better than find a nice stock one or increase the search radius.
  12. Mar 14, 2025 at 3:48 PM
    Steps up on stool...pigeon deployed:
    - As others have said, a lifted truck is not as optimal for towing. That being said, you can do some mods to minimize the impact. Using an adjustable front shock, lower the front back down a little. Maybe only go 1.5-1.75" (this is what I did). Keeping rake is a really good idea with the tundra and the traction control. When towing with my 2012 Tundra my front end traction control would go off all the time in corners no matter the speed when the truck was level. Once there was at least .75" of rake, no more problems. Toyota has some of the most sensitive traction control on trucks that I have ever driven.
    Stock with heavy load:
    Front lifted 1.75" towing similar weight:
    -smaller tires...at least drop to a 33" since dropping the front end is a good idea. Re-gearing is expensive and you most likely will never recoup the costs. The driving experience will be a lot nicer though.
    - Performance shocks are a two edged sword. When set up properly they are amazing. My King 2.5's are set up a little stiff when empty but when fully loaded the truck handles amazing.
    with adding heavier tires (52 vs 58 lbs), 265 vs 275, and lifting 1.75" it took my fuel economy down 1-1.5 mpg.
    Having a performance shock does mean added maintenance. You should have a N2 fill kit at a minimum and check pressure every 3-6 months. Rebuilding a king shock is rather easy. It will take you longer to pull them off than rebuild them....or you can pay to ship and rebuild them. I would also look locally for a shock rebuilder.
    Stool pigeon flies away....
  13. Mar 14, 2025 at 3:51 PM
    DontTazeMeBro
    DontTazeMeBro New Member
    2022 Platinum MGM
    came here to say this. The fact I have to have them rebuilt and off the truck for awhile or buy backup shocks is what really stopped me from buying rebuildable shocks
    22OffRoad[QUOTED] likes this.
  14. Mar 14, 2025 at 4:03 PM
    22OffRoad likes this.
  15. Mar 14, 2025 at 10:24 PM
    SD Surfer
    Bruce
    So Cal
    5,500 lbs. on stock springs w/WDH hitch tows beautifully.
    4,500 lbs. ain't that much, if it drives poorly, there's something else going on. 20230409_142813.jpg
  16. Mar 14, 2025 at 11:07 PM
    rcsbguy
    rcsbguy New Member
    Stock springs with no airbags? I’m impressed, my truck sagged like crazy with stock springs
    Edit: WDH, read over that part
  17. Mar 16, 2025 at 3:48 PM
    SD Surfer
    Bruce
    So Cal
    Yeah, that makes all the difference. Behaves SOOO much better.
    rcsbguy[QUOTED] likes this.
