Oil leak
Discussion in 'General Tundra Discussion' started by Fluh01, Mar 15, 2025.
  1. Mar 15, 2025 at 7:34 PM
    Fluh01
    Fluh01 [OP] New Member
    Alan
    2017 tundra 5.7 liter
    I have a 2017 tundra that leaked a small amount of oil and stopped.
    It started again, leaking a little more and stopped again.
    The leak is on drivers side and it’s somewhere between the valve cover and the bottom, I think.
    Pretty sure it’s not the valve cover.
    thanks,Alan
  2. Mar 15, 2025 at 7:43 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Did you check the cam tower?
  3. Mar 15, 2025 at 7:46 PM
    Fluh01
    Alan
    I’m sorry.. I’m too ignorant to know what that is
  4. Mar 15, 2025 at 7:53 PM
    MadMaxCanon
    There's a big thread on the forum about leaking cam tower and where to look. I'll try to find for you.
  5. Mar 15, 2025 at 7:55 PM
    Fluh01
    Alan
    Thank you very much.
    Does the cam tower leak make sense with the on again off again leak.
  6. Mar 15, 2025 at 8:33 PM
    MadMaxCanon
    Kind of. It's typically a slow leak. Maybe it's pooling and dripping sometimes
    The Black Mamba and Fluh01[OP] like this.
  7. Mar 16, 2025 at 4:34 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
  8. Mar 16, 2025 at 5:16 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Pictures would be helpful. Start at the top and work your way down. I agree with @MadMaxCanon that it's more than likely pooling somewhere. Top engine leaks will occur when the oil pump is pushing oil through the head (when the engine is running). Get some pics so we can better assist rather than speculate.
    MadMaxCanon likes this.
  9. Mar 16, 2025 at 6:57 AM
    MadMaxCanon
  10. Mar 16, 2025 at 7:17 AM
    Cjay209
    Cjay209 New Member
    Connor
    2019 white tundra TRD pro
    None
    I can’t figure out what kind of leak this is,it looks like seeping? Should I even worry about seeping?only reason I am bcs I just bought the truck. 2019 tundra trd pro. I bought the vehicle a month ago from a known name brand dealership
  11. Mar 16, 2025 at 7:23 AM
    Fluh01
    Alan
    Folks.. I wholeheartedly apologize.
    The leak is actually on the passenger side.
    getting old is not fun.. sorry!
  12. Mar 16, 2025 at 7:24 AM
    MadMaxCanon
    Could still be cam tower, you got one on each side
    Fluh01[OP] and The Black Mamba like this.
  13. Mar 16, 2025 at 2:10 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  14. Mar 16, 2025 at 4:01 PM
    Fluh01
    Alan
    Really appreciate the responses.
    Mad max, especially.
    I know this took some time to post pictures,etc.
    Good to see people helping people. .lFrom
    what I could see from underneath, it makes sense that it’s the cam thingy.
