Diff & Transfer Case Oil Change
Discussion in '3rd Gen Tundras (2022+)' started by carbinefreak, Jun 3, 2024.
  1. Jun 3, 2024 at 4:13 PM
    carbinefreak
    carbinefreak [OP] New Member
    Approaching 30k on my 23' limited and need to do the diff's and transfer case oil changes. Are there any tips for doing these? The rear looks normal but I haven't had a chance to crawl under the front and take a look where the front diff and transfer case drain/fill plugs are.
  2. Jun 3, 2024 at 4:52 PM
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    All 3 are very simple. No tricks just make sure the fill plugs open first.
    carbinefreak[OP] likes this.
  3. Jun 3, 2024 at 5:19 PM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    Haven't done my transfer yet, but the diffs are pretty easy, and yeah, open the fill plug first JIC. Depending on the oil you use, Amsoil and some others come in squeezable quart bottles which are excellent. They make fill up a breeze without having to use a pump.
  4. Jun 3, 2024 at 6:01 PM
    umrex
    umrex New Member
    Should I be using Toyota ATF WS for the transfer case only? Any better aftermarket substitutes?
  5. Jun 3, 2024 at 6:07 PM
    carbinefreak
    I picked up a full load of Redline 75w90 for the diffs and D-6 for the transfer case. I'm planning on doing it soon...
    raylo, Kap1 and umrex[QUOTED] like this.
  6. Jun 22, 2024 at 2:32 PM
    carbinefreak
    Update after doing both Diffs and transfer:
    Front diff had a lot more metal in it, the plugs are a 10mm Allen/Hex key on the drivers side. I needed to pump this one, so make sure you have a transfer pump.
    Rear Diff is a 24mm, with the spare out I was able to get a funnel and 10mm hose into the fill hole and gravity feed it. It wasn't too bad just a ton of gear oil.
    Transfer case is a 3/8" square ratchet head on the rear side of the housing, I would recommend a short extension. The T-Case was hot and the ATF came flying out much faster than expected. The ATF that came out was super dark at 30k. I was able to fill this with a funnel and ~6" section of 10mm hose.
    Tundrastruck91 and pwpblue like this.
  7. Jun 23, 2024 at 6:34 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    What ATF dose the xfer case use?
  8. Jun 23, 2024 at 6:54 AM
    carbinefreak
    Toyota WS, I ended up using Redline D6.
  9. Jun 23, 2024 at 7:18 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I’ve got a case of Amsoil SS blue cap atf that’s WS speced.
  10. Jun 23, 2024 at 7:58 AM
    bfunke
    bfunke Tundra Curmudgeon
    Might look at Lexus drain plugs as they are less likely to strip.
    303Gen3 and coldcanuk like this.
  11. Jun 24, 2024 at 12:54 PM
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
    https://www.kaon.com.au/front-diff-tool-and-24mm-drain-plug-to-suit-toyota
    I bought that for my wife’s GX460. It converts the front diff drain plug to a 24mm. The tool it comes with fits the 10mm hole, then you use a 24mm socket, so it avoids stripping it. The tool is just slightly bigger than 10mm, so it gets a good grip.
    Granted, this is for a GX, but it may fit the Tundras. I did use the tool itself on a 2.5 gen Tundra, and it works well.
    303Gen3 and BabyMoose like this.
  12. Jun 25, 2024 at 10:59 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    how many bottles/bags for the rear diff?
  13. Jun 26, 2024 at 9:35 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    Exactly... what are the capacities for these 3? I know we can look them up, but this thread would be a good place to record them.
  14. Jun 26, 2024 at 9:44 AM
    raylo
    Frederick, MD
    OK, I looked it up.
    Transfer case: 2.17 qt. (2.05 L, 1.80 Imp.qt.)
    Front diff: 1.4 qt. (1.29 L, 1.1 Imp.qt.)
    Rear diff: Without rear differential lock system 5.7 qt. (5.42 L, 4.8 Imp.qt.). With rear differential lock system5.6 qt. (5.34 L, 4.7 Imp.qt.)
  15. Jun 26, 2024 at 9:55 AM
    TundraTT
    TundraTT Full Send
  16. Jun 26, 2024 at 10:01 AM
    raylo
    Frederick, MD
    Tundrastruck91 likes this.
  17. Jun 26, 2024 at 10:01 AM
    eddiefromcali
    Eddie
    100% Stock
    Amsoil
    Transfer case: 4.4 pints or 2.2 quarts
    Front diff: 2.7 pints or 1.35 quarts
    Rear diff:
    Without rear differential lock system 11.4 pints or 5.7 quarts
    With rear differential lock system 11.2 pints or 5.6 quarts
    Theyre close enough that it wont matter. You need to round up on the bottles anyways.
  18. Jun 26, 2024 at 10:03 AM
    mass-hole
    mass-hole New Member
    Other Toyota's have been notorious for frozen drain plugs on the front diff. The one on my GX was a large hex and I rounded that thing out trying to get it out at just 70k miles. I ended up using my dremel with a cutting bit to shape the hex into a 1/2" drive square and then put my 1/2" impact driver on it.
  19. Jun 26, 2024 at 10:03 AM
    TundraTT
    TundraTT Full Send
    I used the wrong converter, those are all the same measurements. Carry on :p
    eddiefromcali and raylo like this.
  20. Jun 26, 2024 at 10:15 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Don't forget, rear diff on hybrid is larger, holds 6qt+.
  21. Jul 19, 2024 at 3:56 PM
    2020tundratoyota
    2020tundratoyota New Member
    Does anyone know the thread specs on the transfer case plugs? I wanna ditch the 10mm Allen plugs for hex head plugs.
  22. Mar 15, 2025 at 8:04 PM
    bailey bulldog
    bailey bulldog New Member
    Did you ever find anything that would work instead of the hex?
  23. Mar 16, 2025 at 1:07 PM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
