What kind of camper do you have???
Discussion in 'Towing & Hauling' started by Muleycrazy13, Feb 12, 2017.
  1. Jan 14, 2025 at 7:46 PM
    #1201
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Not sure it you know but the mirror glass is released by prying straight up from the bottom of the mirror.
    koditten likes this.
  2. Jan 16, 2025 at 5:21 PM
    #1202
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Good to know, but I didn't need to remove the glass at all. I used weedwacker string to fish the wiring through the mirror's bottom cap, up and through the arm, then back into the inside of the door where the N5 connector is on the drivers side and the M6 connector is on the passenger side. I stopped for the evening, only had about 30 min to mess around with it. VLED's came today so I'll finish up tomorrow.
    Pin 6 on each connector is (+) and Pin 5 on each connector is (-)
    I'll tap into those to feed the puddle lights and use the VLED hardnesses so I can connect/disconnect as required if I ever need to remove the BAP mirrors. And the stock mirrors will retain all functionality.
  3. Jan 16, 2025 at 9:30 PM
    #1203
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When I wired my puddle light up I used the wire that powers the rear cargo light. I have control from the switch to turn them on and off and when I unlock the truck the lights come on. The wire is easy to get to because it’s under the driver’s side kick panel right were your working.
  4. Jan 17, 2025 at 4:47 AM
    #1204
    carn_dogg
    Pat
    Eastern Shore MD
    Oh that's good to know. My platinum came standard with puddle lights so the wiring is already there. No need to manual control of it, I'll just let it come on when I unlock the truck and then the light fades after a certain amount of time if the door hasn't been opened. I won't need to go into the truck, I'm able to use the M6 and N5 connectors that plug directly into the mirror harness at near the tweeter.
    Ruggybuggy[QUOTED] likes this.
  5. Jan 17, 2025 at 5:11 PM
    #1205
    carn_dogg
    Pat
    Eastern Shore MD
    All finished up. They fit well. They work just like the OEM puddle lights. Fading off when they turn off. On right away when you click unlock.
  6. Jan 17, 2025 at 5:42 PM
    #1206
    Tundra family
    Tundra family New Member
    Nice work.
    carn_dogg[QUOTED] likes this.
  7. Jan 17, 2025 at 6:02 PM
    #1207
    Tundra family
    I remember asking about slide ins but don't think I ever actually shared mine.
    2001 StarCraft Starblazer, dry weight was around 1500 lbs before i took out some cabinets that weren't being used and a 12 gal water tank. Yes, I know the straps are kinda janky but it's old and id rather break a strap than have the mounts get ripped out of my camper when I'm on some rough stuff, so that's how I did it. Currently working on replacing the screens and doing a lil restoration/remodel.
  8. Jan 25, 2025 at 9:07 AM
    #1208
    2025 Campsite Ultra
    22.4 feet, 5140 lbs
    2025_forest_river_campsite_ultra_19kb_hdy2450790_impel-capture_close-up_srp.jpg 2025_forest_river_campsite_ultra_19kb_hdy2450790_impel-capture_close-up_living-area-main-1.jpg 2025_forest_river_campsite_ultra_19kb_hdy2450790_impel-capture_close-up_bathroom-1.jpg 2025_forest_river_campsite_ultra_19kb_hdy2450790_impel-capture_close-up_bedroom-1.jpg
  9. Jan 25, 2025 at 9:22 AM
    #1209
    Heavy for a 22’er
    ah, you got that nice bathroom though
  10. Jan 25, 2025 at 6:56 PM
    #1210
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Man I hate this thread sometimes, I get the itch. That is the perfect camper for 2! And it'd fit in my barn for winter storage :D
    Congrats and enjoy :)
  11. Mar 15, 2025 at 4:04 PM
    #1211
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    The day finally came to pick up the new "project", Winnebago Voyage 2730RL bought the trailer back in December but couldn't pick up until today, the project side is this time we are building the off grid battery system from ground up, 960AH of batteries, and everything will be Victron this time, I bought everything minus the batteries from Explorist, they had been terrific in helping out planning out and the components, https://explorist.life/
    She towed better than the 21ft Micro Minnie.
  12. Mar 15, 2025 at 4:49 PM
    #1212
    MattAK
    MattAK Headin' for the hills
    Alaska and Utah
    '19 SR5 DC White
    Valhalla Cat Plates, GCS Cooler, Dobinsons, RAS
    I'm in the middle of installing a full Victron system in my Micro Minnie. Also got most of my parts from Explorist Life minus some of the wiring which I sourced myself since I wanted a lot of extra in case of mistakes (of which there have been plenty so far).
    Tundra Texan likes this.
  13. Mar 15, 2025 at 5:58 PM
    #1213
    Petro
    Petro New Member
    2019 Tundra SR5 TRD OR Crewmax
    21 ft Gulfstream Ameri-lite
    Perfect camper for the two of us, but also has bunks for the grandkids and table also becomes another bed.
  14. Mar 16, 2025 at 7:28 AM
    #1214
    Downytide
    GTA
    That's the way to do it man, Micro Minnie hits that sweet spot, it does 90% of other fancy off road trailer does for 40% of the price, and do it via victron is just the proper way, are you keeping the GoPower solar controller?
    MattAK[QUOTED] likes this.
  15. Mar 16, 2025 at 8:57 AM
    #1215
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Nice tip, I always whack my head on that awning arm as well:rofl:
  16. Mar 16, 2025 at 9:55 AM
    #1216
    MattAK
    Alaska and Utah
    '19 SR5 DC White
    No, I've heard that while it claims to be lithium compatible it can have issues in lithium mode, so I'm bypassing it and putting in a 75|15 Victron for the single roof panel for now until the roof warranty is expired and I feel comfortable installing more panels up there. I'll use a 450W portable panel with a 100|50 Victron controller for the side port and then just run a generator if I have to for now.
  17. Mar 16, 2025 at 11:19 AM
    #1217
    Petro
    Petro New Member
    Lol. Good eye.
    Exactly why I wrap the chair covers there. Wacked my head a couple times before I started doing that.
    Might have been a little alcohol involved also.:drunk:
  18. Mar 16, 2025 at 11:22 AM
    #1218
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    The Wife and I have a Lance Model 1995.
    Very Nice Camper!!
    After much research and being told it's the best brand out there just behind Air Stream we figured we couldnt go wrong.
    So far we've had zero problems with it.
    And without us having any kids it's the perfect size.
    Of course we have two big Boxers which probably take up more space since they insist on sleeping with us in the bed.
    https://www.lancecamper.com/travel-trailers/1995/gallery/
  19. Mar 16, 2025 at 1:48 PM
    #1219
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    It definitely beats the Coleman Pop Up we had previously!!
    Using that thing in the winter Sucked!!
    You'd go through a 10 gallon canister of propane a night and you were still Cold!!
    With the bed being a slide out it was like a meat locker!!
    JMGmanAZ, Tunrod and Tundra family like this.
  20. Mar 16, 2025 at 4:12 PM
    #1220
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    I probably should update my camper situation. Had a 21LT toyhauler and it was fine, but after swapping the sxs from a little(r) unit to the CanAm Maverick, it was just too tight in there. Swapped out the toyhauler for something considerably more comfortable, and we can haul the sxs in our cargo trailer since we have a camping lease and can make two trips.
    Tundra Texan, g6t9ed, _none_ and 3 others like this.
  21. Mar 17, 2025 at 6:55 AM
    #1221
    Downytide
    GTA
    Nice, I was going to say avoid using GoPower solar controller, that thing blew twice on me until we put in an isolator switch.
    MattAK[QUOTED] and JMGmanAZ like this.
  22. Mar 18, 2025 at 8:35 AM
    #1222
    Do you guys know if Camco sewer hoses will fit on a Valterra drain?
  23. Mar 18, 2025 at 8:41 AM
    #1223
    Tundra family
    No, but there are plenty of options for an adapter
  24. Mar 18, 2025 at 8:46 AM
    #1224
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    You'll love the Lance...
    g6t9ed and Tundra Texan[QUOTED] like this.
  25. Mar 18, 2025 at 9:01 AM
    #1225
    I have another hose as well but no idea what brand it is. I am going out tomorrow so I better hit Amazon. They have a Valterra hose that will arrive this afternoon. I can always return it if I need to.
  26. Mar 18, 2025 at 9:10 AM
    #1226
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Our Camco hoses fits this Valtera secondary dump valve.
    bflooks and Tundra family like this.
  27. Mar 18, 2025 at 9:21 AM
    #1227
    I just ordered a Valterra hose since we head out tomorrow. I didn't want to wait until I get home to verify what I have. I know I have a Camco set from my old trailer along with one other hose but I have no idea what that one is. I just noticed last night when I was replacing the crappy camera with a better one that I have a Valterra drain.
  28. Mar 18, 2025 at 3:39 PM
    #1228
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Already Do!!!
    And like I said it sure beats the Hell out of our old pop up!!!
    We took the pop up to Barnwell Mountain in Northeast Texas to go wheeling and froze our Butts OFF!!!!
    Put it up for sale when we got home.
    We'll be leaving the camper at our fishing lease outside of Cleveland Texas.
    Dozens of lakes and 6000 acres to roam around on in the SxS.
    It's Hard As Hell to get on the place!!
    You get put on a list and you have to wait until someone gives up their spot or dies. To make matters worse the people who get off their lease generally will pass their spot off to a relative.
    Not to mention the guy who runs the place has to like you.
    I told him I was up there all the time as a guest with my Buddy so ya might as well make a buck off me.
    He saw the wisdom in that and okayed me.
    Tunrod likes this.
  29. Mar 18, 2025 at 4:14 PM
    #1229
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Here's a good forum for info on Lance's of you need: https://community.lanceowners.org/
    Tundra Texan[QUOTED] likes this.
  30. Mar 18, 2025 at 4:26 PM
    #1230
    Recently removed the top bunk from my 2025 Coachmen Apex Nano 208. Thought I was being ingenious and solving the problem of having two unusable bunks, and creating a second roomy sleeping space in the camper that people would actually want to use. Went online and found this is a very common mod.
