Leveling kit made front too high
Discussion in 'Suspension' started by Fox Mulder, Mar 13, 2025.
  1. Mar 13, 2025 at 3:45 PM
    Fox Mulder
    Fox Mulder [OP] New Member
    2022 Supersonic Red 1794 Hybrid TRD OR
    Hey guys!
    I did post this in Suspension yesterday, and got some ideas from member SilveradoSwap, but was hoping maybe someone would have ideas I could try to fix this. I’m about a week into owning my new to me Tundra, which I upgraded into after having a Tacoma for a long time. I love it so far, but I have noticed that the front sits higher than the back. I’ve done some investigating, and it looks to have a leveling spacer, but I don’t have any idea how tall, or what one. I measured it tonight, and to the flares, it’s 1/2 higher in the front.
    Any ideas what kit this is? It doesn’t look huge, so I’m wondering if there’s some way that it could have been done incorrectly that caused it to be too high. I’d like to either fix it, or swap it out for a lower kit to put a tiny bit of rake back into it. I don’t know of if I want to lift the back, as I’m planning to run this tire for awhile.
    [​IMG][​IMG]
  2. Mar 13, 2025 at 4:55 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Just remove the spacer and run it stock height.
  3. Mar 13, 2025 at 5:17 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    If you're in North Carolina just chill out. You're just fine. Maybe double up on those spacers.
  4. Mar 13, 2025 at 6:11 PM
    Fox Mulder
    I can’t tell for sure, but if this is the RC kit that seems very popular, the strut studs got cut off, so I couldn’t just remove them.
  5. Mar 13, 2025 at 6:12 PM
    Fox Mulder
    I know! It’s only a half inch, but it’s driving me nuts!
  6. Mar 13, 2025 at 6:29 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I looks like an RC spacer, but at 1.75" it should be level with rear. I used that kit myself. I later added a 1/2" rear spacer from Cornfed to give it a slight rake.
    You could always add a half inch to rear, just to level it.
  7. Mar 13, 2025 at 6:37 PM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    I added the 1” Cornfed spacer to the rear with the 1.75” RC front level kit and that was the way to go.
    Raven67 likes this.
  8. Mar 13, 2025 at 6:40 PM
    Raven67
    Kentucky
    Just don't be this guy...
  9. Mar 13, 2025 at 6:41 PM
    Fox Mulder
    I’ve been thinking that’s probably the easiest fix, I’m just a little worried that the stock tires will look too small. What I’ve been wondering about why it’s so high is if maybe the swaybar and control arms were tightened off the ground, so it’s higher than it should be?
  10. Mar 13, 2025 at 6:44 PM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    All the same things I suggested in his original thread. You gonna start another thread until you get the answer you want?
    How about putting 50psi in the rear tires and drop the front to 15psi.
  11. Mar 13, 2025 at 6:55 PM
    Fox Mulder
    Bro, not only did I acknowledge this was a repost from the suspension forum, I also credited you with making suggestions. I’m really confused what about this thread makes you feel like being a dick. No one is requiring you to be a part of this thread, I thought maybe it would be helpful for me to have more than one opinion. Can’t see how it hurts you, but sorry about whatever it was.
  12. Mar 13, 2025 at 7:02 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    And just like that..................it's a Facebook thread. :bananadead:
    atc250r, OldGuy03, Siblue and 4 others like this.
  13. Mar 13, 2025 at 7:07 PM
    SilveradoSwap
    You think thats me being a dick, you sold me short, lmao
  14. Mar 13, 2025 at 7:11 PM
    Fox Mulder
    Seriously man, I just wanted some other opinions, I’m not sure why it had to get derailed. That’s the internet now, everything has to devolve into trash.
  15. Mar 13, 2025 at 7:22 PM
    SilveradoSwap
    Oh ffs, dont get so dramatic, no one derailed your thread.
    Rodtheviking likes this.
  16. Mar 13, 2025 at 7:31 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    I'll break it down for you OP, it's very simple.
    First of all, you're new. So, welcome.
    Because you're new, I don't want to assume.
    Not sure how familiar you are with internet forums. They have rules. Most of them spelled out, some are just common sense and etiquette.
    A single thread CAN contain more than one opinion, idea or thought. Just give it some time, and they will appear.
    It's poor forum etiquette to create multiple threads on the same topic or subject. It's just clutter, and adds to the internet trash you obviously dislike.
    So, if you choose to redeem yourself from being the dick in this situation, ask the mods to merge the threads, or delete this one, that didn't need to be created in the first place.
    Between the two threads you've been given more than enough information to make an informed decision on your next steps.
  17. Mar 13, 2025 at 7:49 PM
    Fox Mulder
    I’ll have it deleted, I didn’t realize asking for more than one persons opinion would be a problem. I didn’t mean to make things a problem for the Tundra forum.
  18. Mar 13, 2025 at 8:03 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Take the spacers out. Close thread.
  19. Mar 13, 2025 at 8:04 PM
    SilveradoSwap
    He cant most likely. If they are RC spacers you have to cut the studs at the top of the shock assembly to install them.
  20. Mar 13, 2025 at 8:08 PM
    Fox Mulder
    Yep, got it. Already asked for the thread to be deleted.
  21. Mar 13, 2025 at 8:14 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I ran this same spacer up front and put 1” Westcott spacers in the rear. That worked great on my Limited.
    Does your 1794 have a rear air suspension? It is does there are some things to make the rear go up by adjusting the little arms that control the levelling.
    KNABORES likes this.
  22. Mar 13, 2025 at 8:14 PM
    Raven67
    Kentucky
    Not all RC spacers require you to cut off studs. Mine didn't, maybe it's a newer version? My spacers bolted onto the top of strut, then spacers bolted to truck. Simple & easy. Personally, as mentioned earlier, I'd just add a little to rear. 20241010_101834.jpg
  23. Mar 13, 2025 at 8:20 PM
    SilveradoSwap
    Would be worth pulling one to check, cant hurt.
  24. Mar 13, 2025 at 9:28 PM
    This
  25. Mar 14, 2025 at 6:45 PM
    se3388
    se3388 New Member
    2025 Tundra I Force Max Platinum Crew Cab, 1997 Toyota T100 SR5 Ext. Cab 4x4, 2014 Tacoma Dbl Cab Short Bed 4x4 TRD Sport
    The Stealerships body shop is installing RCs 1.75 kit on the front of my 25 Platinum Monday. The 1.75 is what they said they have installed the most and it usually comes out level, hope so. Didn't realize these were synthetic.
    Steve..........
  26. Mar 14, 2025 at 8:11 PM
    Fox Mulder
    No air suspension. I may add a spacer to the rear, I’m just concerned it’ll make the stock size tires seem too small. And with just buying the truck, running boards and a tonneau cover, my wife will murder me if I replace these tires for looks, lol.
  27. Mar 14, 2025 at 8:12 PM
    Fox Mulder
    Good luck Steve! Seems like most of the installs work out fine, not sure why mine is higher in the front, and probably won’t get an answer unless I tear it apart.
  28. Mar 14, 2025 at 8:19 PM
    Fox Mulder
    Interesting, I watched the Yota Garage install on a 22, and he cut the studs down to 5/8. Looks like I could buy new top hats if I had to, but at $100 a side, I’d probably be better off replacing the entire strut with some RC M1s for $500 a pair.
  29. Mar 19, 2025 at 12:43 PM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    OP, you have the hybrid => hence, the front is lower than the non-hybrid.
    Your only solution now is to install a spacer on the rear.
  30. Mar 19, 2025 at 9:36 PM
    Fox Mulder
    So, I didn’t know that the front of the hybrid was lower, but if that’s the case, shouldn’t everyone who installs a RC 1.75 have front higher than the back. Not saying I don’t need a rear spacer, or a lower front spacer, but lots of people seem level with this kit. If hybrids are even lower in the front seems like I’d have less of problem, instead of more.
    Sorry if that doesn’t make sense, I had some really nice craft brews tonight, lol.
