Will I Regret This Upgrade?
Discussion in '2.5 Gen Tundras (2014-2021)' started by PadreMC, Mar 12, 2025.
  1. Mar 12, 2025 at 2:10 PM
    PadreMC
    PadreMC [OP] New Member
    2021 Tundra 4x4 Limited CrewMax Nightshade Edition MGM
    My 2021 Limited has the TRD Pro Fox suspension with stock 20" wheels. I've read from multiple posts that 295/70R18 tires will fit the TRD Pro without rubbing (may require removing front mud flaps) so I'm considering 295/60R20 tires for my setup as they are just slightly smaller in total diameter. Unfortunately, I can only find e-rated tires in that size.
    First, have any Limited owners run that size of tire with success?
    Second, will I regret moving to an e-rated tire as far as ride quality goes? My truck only sees pavement and does no towing so e-rated tires obviously aren't needed. I just want to fill up those wheel wells and have a wider tire.
  2. Mar 12, 2025 at 2:25 PM
    rheosibal
    rheosibal New Member
    2.5 Platinum OEM+
    Yes, those tires will fit and yes ride quality will diminish with an E-Rated tire.
    Toyo makes a 285/60/R20 in an SL rating which is slightly narrower, but lighter and cheaper than the E-Rated 295/60/R20 equivalent
  3. Mar 12, 2025 at 3:13 PM
    H20ne
    H20ne New Member
    California
    2021 Limited Nightshade CM 4x4
    aFe, TRD, Eibach, RCI
    koditten likes this.
