Touch up above back wheel well
Discussion in '3rd Gen Tundras (2022+)' started by tstex, Mar 11, 2025.
  1. Mar 11, 2025 at 9:36 AM
    tstex
    tstex [OP] New Member
    Houston & Colorado County TX
    2024 Silver Tundra TRD
    Hello to all,
    Since I'm not a paint & body auto shop guy, seeking your opinions.
    i bare clipped a wooden pole at my ranch. See pics. No indentations or deformity damage, just loss of about 3/4" paint & prob surrounding clear coat.
    Since this wheel well piece can be taken off by removing 3-4 screws, I was thinking of just undoing screws & taking it somewhere. Would is there any type of rubber mounding or similar btw the wheel well piece and main body of car that by removing would cause more problems?
    The other option would be to neutralize the outer rust, and try touching up myself. Are their kits for this that wk well? Would i need to get Toyota paint or can it be matched?
    Other options?
    Thabk you very muxh,
    tstex
    upload_2025-3-11_11-35-56.jpgupload_2025-3-11_11-35-56.jpgupload_2025-3-11_11-35-56.jpgupload_2025-3-11_11-35-56.jpgupload_2025-3-11_11-35-56.png
  2. Mar 11, 2025 at 9:37 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Battle tested is all!
    ScottieBones likes this.
  3. Mar 11, 2025 at 9:41 AM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    Get a paint pen from Amazon and no one will ever notice. After a while you won’t either. :)
  4. Mar 11, 2025 at 12:14 PM
    tstex
    I cannot find my paint code on my 2024 silver tundra. Do i need to call Toyota w vin#?
  5. Mar 11, 2025 at 12:36 PM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    tstex[OP] likes this.
  6. Mar 11, 2025 at 1:11 PM
    tstex
    Excellent. Thank you Pine.
    i looked and not on door, at least tne drivers door 3-4 stickers / I'll use your link
  7. Mar 11, 2025 at 1:29 PM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    OEM TOYOTA PAINT CODES & NAMES (MY22+TUNDRA)
    040 - Super White/Ice Cap
    089 - Wind Chill Pearl
    1G3 - Magnetic Gray Metallic
    1J9 - Celestial Silver Metallic
    218 - Midnight Black Metallic
    3U5 - Supersonic Red
    4W5 - Solar Octane
    4X4 - Smoked Mesquite
    6V7 - Army Green
    6X3 - Lunar Rock
    8X8 - Blueprint
    tstex[QUOTED][OP] likes this.
  8. Mar 11, 2025 at 6:11 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    This ! ..No worry on rust with paint over plastic.
  9. Mar 12, 2025 at 6:56 AM
    tstex
    When i went to YouTube to get some ideas, they did the paint restoration over real metal and show how to remove the rust first. Didn't think of that, thanks.
  10. Mar 12, 2025 at 7:04 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Toyota has some quality control issues but thankfully rust on plastic isn't one of them yet!
    Tundrastruck91 likes this.
  11. Mar 12, 2025 at 11:39 AM
    tstex
    O1J9 per dealer, so celestial silver metallic. There was no paint code on the driver door, but i should be good to go.
    After i do my touch up, I'll post b4 & afters
    thanks again
    SoCal_Erik and oddhours[QUOTED] like this.
  12. Mar 12, 2025 at 12:06 PM
    Pine_Cone67
    2024 Tundra Limited
    It's there.. white sticker on the B pillar (not the door); second line from the bottom, immediately below the bar code. Now that you know the code, go back and check - you will see it.
  13. Mar 12, 2025 at 12:18 PM
    astrength22
    astrength22 New Member
    2023 Silver Tundra Platinum
    I had similar damage- it’s easy to pull off the whole fender flare and prep+ paint. I found a local auto paint shop that mixed up a color matched rattle can for me for $14.99. Came out as good as new, although my flares are gloss black, not color matched to body.
  14. Mar 12, 2025 at 12:21 PM
    tstex
    I stand corrected. You are 100% right. It's there, but not how it's supppsed to be displayed, but i know it now for sure. Thanks!
    Pine_Cone67[QUOTED] likes this.
  15. Mar 12, 2025 at 12:29 PM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Dammm. Poor truck!!
