Towing Mirrors for 2022 Tundra, any available?
Discussion in '3rd Gen Tundras (2022+)' started by Old Coyote, May 16, 2022.
  1. Mar 30, 2023 at 8:45 PM
    #61
    mike303
    mike303 New Member
    2023 Platinum hybrid
    2” lift Switch-pro accessory controller Trd skid plate Baja design A-pillar mounted lights Toyota swing out boxes
    Thanks for that. Having tow mirrors are pretty pointless if they don’t work. I miss having them and want to find a replacement. Either that or just need to invest in apology gifts for what I say to the wife while backing the camper up….
    Blufin likes this.
  2. May 7, 2023 at 10:12 AM
    #62
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    So I'm look at these ks69zr and there now over 100 bucks?
  3. May 22, 2023 at 6:04 PM
    #63
    TOYO4EVER
    TOYO4EVER New Member
    2022 Tundra Black Max
    Hey NWTundra22, can you tell me the dealership that installed your mirrors? I have called multiple dealerships and the Toyota Customer Care 800 number and no one was able to help. I've already sunk the money into the mirrors and additional switches and the dealership doesn't know what which harnesses would be necessary. Or could they strip the mirrors' connectors, replace connectors and add two power leads for the extend and puddle light features? Customer Care nor the Regional Tech Service Rep doesn't know how to guide them. Any information you can provide would be greatly appreciated!
  4. Sep 11, 2023 at 5:21 AM
    #64
    Tuecker89
    Tuecker89 New Member
    Tyler
    2022 TUNDRA SR5 TRD
    I have lunar rock color, anyone want to trade my color keyed standard power mirrors , blind signal etc for tow mirrors ?
  5. Sep 11, 2023 at 1:43 PM
    #65
    Adventurer
    Adventurer New Member
    2023 1794 TRD 6.5 Celestial Siver
    My '23 1794 TRD came with tow pkg., but non-tow mirrors. Bummed to find out the cost of swap. Funny part is, it's less than $300 if they order it that way. Toyota has so many restrictions on combinations. No power boards or bed step with TRD option, 6.5 bed not offered on several trims, must have hybrid for a Capstone or TRD Pro etc. etc. I flew 1300 mi. to pick up my truck, because I wanted specific options. Didn't get colors I wanted, or the tow mirrors, or the power bed step. I would have paid for rear air bags too, since I loved them on my Ram dually's. Not available.
  6. Jun 24, 2024 at 7:03 AM
    #66
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
  7. Jun 24, 2024 at 4:20 PM
    #67
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Just ordered these! I’ve mounted them and plan you try them out around town. Towing two trips with them next month. From just seeing them in the driveway they look really good!
  8. Jun 25, 2024 at 6:28 AM
    #68
    teab
    Ty
    Denver
    Are They easy to take off and on? as in you can just pop them on when you need to tow and pull them off after? Or are they more permanently mounted with double sided tape?
  9. Jun 25, 2024 at 8:07 AM
    #69
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Super easy. They have a video on the etrailer link above. You just slip them over the top of the mirror from the front, rotate down, then pull up on the lock on the bottom. Takes like 5 seconds per side.
    I test drove these around last night. They don't bounce around like the strap ones I had before. Worked great on the freeway. I'm really impressed and happy to find these. Tow mirrors were a point of stress towing my TT the last two years!
  10. Jun 25, 2024 at 9:27 AM
    #70
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    I don't see a cut out for the camera on the bottom of the mirror. Does anyone know if there is a hole for the camera?
  11. Jun 25, 2024 at 6:18 PM
    #71
    Rockpig
    Rockpig You did what?
    08 Limited
    Video on etrailer site says works with blind spot detection and cameras.
    Twin2turbo[QUOTED] likes this.
  12. Jun 26, 2024 at 4:31 AM
    #72
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    I just got the trailer mirrors as well, no interference with the cams. There is no "hole" for the cams but there is a cutout and the cams are more inward than these mirror extenders reach.
  13. Feb 7, 2025 at 9:36 AM
    #73
    Tundra 108
    Tundra 108 New Member
    Catt
    2022 Tundra
    6' lift
    just got OEM towing mirrors for my 22 Tundra however the regular mirrors had a female plug the towing ones have a male plug (same type) does anyone know if there is a adaptor that connects male to male plug ?
  14. Feb 7, 2025 at 10:03 AM
    #74
    Hoody
    Hoody Member
    Kommiefornia
    Uh oh. Did you research this forum before buying the oem tow mirrors?
    To my knowledge the oem tow mirrors are not plug and play. Tow mirror equipped trucks come with a completely different harness from the factory. From what I've researched you'd either need to completely replace an interior harness or have a custom wiring job done to get them to function correctly.
  15. Feb 7, 2025 at 10:29 AM
    #75
    Tundra 108
    Catt
    2022 Tundra
    6' lift
    I have seen a video from Ed Martin Toyota where they changed the door wiring harness completely , which is not that difficult , the only thing that I have to figure out is how to connect the mirror extension and perimeter liting buttons . any thoughts ?
  16. Feb 7, 2025 at 11:09 AM
    #76
    teab
    Ty
    Denver
    Looks like you have your answer there homes.
    First step buy the $4743 kit from Ed Martin. Swap the mirrors, pull the door cards, then just take off the doors to swap out the harness's, put in your extension and lighting buttons, put the doors and door cards back on, and fire up techstream to recalibrate the cameras. Easy peezy, shouldn't take more than a weekend.
    Great Youtube video though. @Tundra 108 Maybe Give Ed Martian a call to see if they will just sell you the harness??
    https://www.youtube.com/watch?v=Ux9R4kyBdXs
    https://www.edmartintoyota.com/order-parts.html?path=/search?search_str=TWMF3GT
  17. Feb 7, 2025 at 1:17 PM
    #77
    Hoody
    Hoody Member
    Kommiefornia
    $5k holy crap, plus that's a lot of work. I'd try the $75 snap ons first, they work fine for me.
    Dfrink likes this.
  18. Mar 10, 2025 at 5:02 PM
    #78
    Tundra 108
    Catt
    2022 Tundra
    6' lift
    Hi guys, I successfully swapped the mirrors to the OEM towing mirrors, however i can't get the backup lights to work , more than likely there is a fuse that has to be plugged but i couldn't find the spot ...?! Also , does anybody know how do I connect whit the vehicle to be able to adjust the mirrors settings so I can have a complete 360 view .... ? is this a dealer thing ...?
  19. Mar 11, 2025 at 12:01 PM
    #79
    Retroboy1989
    Northern Utah
    Anyone have any feedback after some use of the etrailer snap on mirrors? Do they scratch the paint?
    I'm not spending $5k and a trip to the dealer for OEMs. It would be nice, but not THAT nice.
    I'd rather install a TRD lift, Wheels and Tires for that $$
  20. Mar 11, 2025 at 12:27 PM
    #80
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I do. See posts 67 & 69 above. I've been using them for over a year now when we tow our travel trailer. They're fantastic! No scratches or blemishes to my mirrors from using them. They have a soft material on the inside and a soft "spring" that works to keep them from being plastic on plastic.
  21. Mar 11, 2025 at 12:52 PM
    #81
    Retroboy1989
    Northern Utah
    This is exactly what I am looking for. They don't look bad for tow mirror extensions from your pictures. Alot of accessory tow mirrors look really dorky, imo.
    I'll order up a set today.
  22. Mar 11, 2025 at 1:08 PM
    #82
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I agree. I had the strap on ones before these, they sucked! Bounced around so much they were worthless. These are nice and firm, look pretty darn good, and are under $100. Functionally, they work fantastic!
  23. Mar 11, 2025 at 11:17 PM
    #83
    Hoody
    Hoody Member
    Kommiefornia
    2nd that. I initially bought some used strap on universal tow mirrors on FB. They were okay but bouncy and I had to strap them so tight they pulled up the end of my oem paint protection film on the mirrors. Then I bought the plastic etrailer ones same as @Dfrink above and they are prefect for my needs at 5-6 times per year for the same price I paid for used lame ones.
    Dfrink[QUOTED] likes this.
