2025 Turn signal wiring?
Discussion in '3rd Gen Tundras (2022+)' started by RickyK25, Mar 11, 2025.
  1. Mar 11, 2025 at 9:04 AM
    RickyK25
    RickyK25 [OP] New Member
    Rick
    2025 Tundra Platinum
    Grill Lights, Front Vent Lights
    I have a 2025 platinum tundra. I added new vent lights to the front grill. The white lights are wired switched from the key. My question is the new headlights seem to be all LED Including the turn signal light. There is a gang connector at the headlight. I was wondering, which wire controls the turn signal? I am worried that it might be pulse with modulated. Looking for a schematic and recommendation for which wire to tap into? I do not want to create damage to a module if it’s controlled that way.
  2. Mar 11, 2025 at 9:17 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Everything is led and is all controlled through the ecu. These trucks are sensitive to any kind of voltage variances with anything running through the ecu. Why do you need to tap into the turn signals though?
  3. Mar 11, 2025 at 10:10 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum @RickyK25 .
    You can find wiring diagrams here
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum
    First off, I agree with @Danman34 the Gen 3s are sensitive to electrical variances, not sure about the turn signal circuit.
    Assuming your platinum has LED headlights, he is also right about your platinum having a headlight ECU which IMO would make it even more sensitive..
    Proceed at your own risk..
    That stated the connectors are A53 and A54
    Pin 11 hot for the turn signal
    Pin 12 is ground
    It looks like the front and rear turn signals have different feeds from the combination meter flash circut.
    Perhaps tapping into the rear turn signals would be less of a risk than tapping into the front LED assemblies.
    Good luck..
  4. Mar 11, 2025 at 10:51 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    1lowlife likes this.
  5. Mar 11, 2025 at 11:03 AM
    RickyK25
    Rick
    Thank You! This is a great response and glad to see professional replies!! I added LED front Vent Lights. White light when vehicle is running. (Tundra Vent Light.png Tundra Vent Light.png B+ switched) Amber flash when turn signal is activated. Red wire is for running light. Yellow wire is for amber turn signal flash. This connection to be made to Turn signal lamp.
    I am retired wrench and understand electrical load/controls. Just worried what strategy is used to activate the turn signal.
  6. Mar 11, 2025 at 11:21 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    You can try tapping into the turn signal feed in the A53 / A54 connectors as described above.
    But there are a couple ECUs in that circuit.
    If you had halogen headlights it would be ano brainer, but the LED headlights are a bit more technical.
    Did you find your DRL feed for the white DRLs?
  7. Mar 11, 2025 at 7:06 PM
    RickyK25
    Rick
    I tapped into the driver side power distribution box. There was a terminal that is switched B plus. I’ll have to take a picture of it later
