What am I looking at?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundrav82019, Mar 11, 2025.
  1. Mar 11, 2025 at 12:52 PM
    Tundrav82019
    Tundrav82019 [OP] I have all the duckies
    Leo
    2019 Tundra Limited TRD Off Road
    Hello all,
    Late to the game, I recognize this has been spoken about a lot. Trying to get factual information.
    I have a 2019 Tundra crewmax, with tow package, limited, 5.7 L v8.
    I see two layers to the front intercooler and lines, is this a form of a intercooler transmission cooler?
    What am I looking at here?
    I plan to tow a lot, thank you for your time!
  2. Mar 11, 2025 at 1:17 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    1. Engine radiator
    2. A/c condenser
    3. Your truck is not turbocharged, you do not have an intercooler.
    Tundrav82019[OP] likes this.
  3. Mar 11, 2025 at 1:53 PM
    Tundrav82019
    Leo
    So if I’m tracing the lines correctly, the transmission lines seem to line up with the engine radiator, meaning they are integrated now?
  4. Mar 11, 2025 at 1:56 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Last two pics are the power steering fluid cooler.
  5. Mar 11, 2025 at 3:17 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    2019 does not have factory transmission cooler. Found that out when I bought my ‘21
  6. Mar 11, 2025 at 3:22 PM
    Tundrav82019
    Leo
    After some research, seems like they tied it into the radiator and is a fluid to fluid cooler and warmer. I guess in 2019 they changed the shift points for the transmission to help it operate cooler.
    per Toyota mechanic spoke with, if less then a 280 degrees, they are happy. Which is insane in my opinion.
    the fluid they use now can handle up to that temp and the metals they used for transmission I guess changed some. All super weird. By changing the shift points it helped reduce heat in other areas of truck although I can’t find anything on it.
    Tundrastruck91, 00h2itr and Tunrod like this.
  7. Mar 11, 2025 at 3:24 PM
    Tundrav82019
    Leo
    I may track mine and see what the values are.
    Anyone know if a OBD scan II can do this?
  8. Mar 11, 2025 at 3:42 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    yes
  9. Mar 11, 2025 at 3:46 PM
    Tundrav82019
    Leo
    What is the name of that little gauge?
  10. Mar 11, 2025 at 3:48 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  11. Mar 11, 2025 at 3:56 PM
    Tundrav82019
    Leo
    Thank you!
    What typical temps do you see in a daily average?
  12. Mar 11, 2025 at 4:04 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Normally matched 193ish both TF1 and 2 straight and level while towing with a locked up torque convertor. I still see 230 TF2 at the top of our 8 mile uphill run from our campsite where TC won't lock up but pan temp is about 30-35 degrees cooler
  13. Mar 11, 2025 at 4:13 PM
    Tundrav82019
    Leo
    Does this read pan temp or active in the line temp?
  14. Mar 11, 2025 at 4:19 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Not sure ... I assume pan temp and torque convertor discharge temp. When TC locks up TF2 cools to pan temp rapidly.
  15. Mar 11, 2025 at 4:42 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    This is in line with what I'm seeing on my '19 with 5,500 lb. trailer behind me.
    On the flats through the desert she settles in @ 205-210º towing @ 62-65 MPH.
    Climbing grades it'll be in the 220-230º range, and I think the highest spike I've seen was 238º and that was pushing it hard up a particularly nasty grade coming up out of the desert on I-8 east at the Imperial County/San Diego County line.
    Two lanes, steep and curvy, and if you get stuck behind someone struggling in the right lane you're done. You're never gonna' get in the left lane again.
    The spikes cool off right away once cresting the climb.
    For now I can live with monitoring temps and doing drain and fills on severe duty intervals every 30K
  16. Mar 11, 2025 at 4:50 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Or if you got the extra dough and don't mind using up a little bit more real estate on your dash, you can get the Scangauge III that will give you readings and then some
  17. Mar 11, 2025 at 7:41 PM
    Tundrav82019
    Leo
    Thank you all, very helpful information!
  18. Mar 12, 2025 at 2:16 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Also helps to tow in S4 as per the manual to manage temps. Towing in the overdrive gears (5-6) heats up the trans quickly
  19. Mar 12, 2025 at 3:11 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Scangauge 3 here also... So, far it has provided a LOT of info that I probably did not WANT to know, but needed to know for the long term well-being of my '21.
    Yes, as previously stated 5th and 6th are OD gears for our rigs. Something else to point out is that the torque converter will NOT lock up in 4th (only 5 or 6th) when the truck is in 'D'. However, the torque converter WILL lock up in 4th if the truck is in S4. Also, S4 is a the only 1:1 gear, which is why it pulls so nicely and tows much better in S4 than D or S5, S6... The reason that 4th won't lock (obviously programing shift points), but when the TQ would normally lock up due to conditions (parameters) the truck is also reaching parameters that trigger the upshift to 5th. So, again, use S4 when towing VERY liberally. Also, S4 will keep the truck from constantly gear hunting on any grade or inclinel especially when towing.
    The OD gears are meant to reduce workload on the engine. However, the reduced engine workload is absorbed elsewhere (the transmission)!!!
    Many running in S4 and towing at fwy speeds 60-65ish will say that they feel the engine is revving too high (2800-3k). Yeah, you will burn a LITTLE more fuel, but the sacrifice is to the transmission, which is quickly heating up. I read somewhere that you won't get a high temp warning light for your trans temp until it EXCEEDS 250. I've seen non-towing/unloaded temps at the converted EXCEED 230 degrees on a short steep paved incline (more than once) and pan temps in the mid 220s. Just slowing down from hwy speeds 55-60 to make a turn off the hwy, I normally will see converter temps pass 220 (pan temps 208-210), and I live in a place that doesn't exceed 75 degree temps for the highs in the summer. Sitting still in D will drive converter temps above 220 as well (such as in a drive through), shift to P while waiting and the temps immediately drop...
    Short bursts of 4wd will quickly push temps higher and 4lo temps climb almost immediately...
    Just for reference the truck only has about 21k miles on it.
    It's amazing how the gauge and changed my perception of what my transmission is doing internally (temp wise) in my '21.
    I'm runnng a '21 Pro (2nd Tundra) and have NOT towed w/it. I towed considerably w/my '08, and I did NOT monitor w/a gauge, but the gauge did confirm what I "felt" to be right in terms of using S4, etc. over D while towing... I'd be curious to see what the temps were while towing when I was doing it w/my '08, but I'd bet considerably lower....
    So, what's my solution now that I have the info?? Aftermarket transmission cooler is going in. I've had the gauge for a few months, and it was enough for me to decide to install a cooler. So, parts are almost all here (just waiting on few small dealer extras) and I'll be looking to install in a few months.
    Here's a video (it's dry AF), but 12 minutes of watching this will give you an incredible amount of knowledg of how our transmissions work and why the OD gears in our trucks generate SO much heat. This will also explain why S4 ideal for towing, and also a bit about the quality and durability of these transmissions.
    https://youtu.be/YM40HOYtLNc
    From there you must decide if you trust that the high temps we are seeing in our 19-21s, from lack of having an external cooler, will not cause the fluid to degrade to the point where you'll experience pre-mature failure of your transmission. Personally, I don't believe that with those types of temps our transmission fluids are going to be able to retain their protective properties throughout their intended service life, and if the fluid isn't doing it's job then it will be my transmission that suffers...
    This is just my belief, based on my research and personal experience and observations of my own 2 Tundras.
    Sorry for the blast of good and sometimes conflicting information. However, there's plenty of details and specifics about temps guys have seen, conditions, remedies taken, and before and after results, etc. of installing or not installing a 'kit'.
    Crap ton of info in this thread about coolers for our '19-'21s...
    https://www.tundras.com/threads/5-7l-transmission-cooler-kits.60550/
    Another transmission cooler TO DO or NOT TO DO thread....
    Transmission cooler or not Thread
  20. Mar 12, 2025 at 8:17 AM
    yakeng
    yakeng 3URFE Apologist
    Good post. My belief on whether one should be installed or not largely depends on driver behavior. I also monitored mine for a month or so and was surprised to see that I was in the mid 230's just driving unloaded in rush hour traffic. I tow enough and drive offroad a lot in 4WD that it just made more sense to me install a cooler and not be as worried about cooking the fluid.
    There have been a couple of failed transmissions 2019+, whether that is related to temps is unclear, but at least one reported high temps. Overall though, it seems most driver behavior has been OK with the lack of a cooler, at least for now. Time will tell if longevity is decreased on the models without them.
  21. Mar 12, 2025 at 11:34 AM
    Tundrav82019
    Leo
    Awesome information.
    How often do you do a drain and fill of your ATF?
    Also, what transmission cooler do you suggest installing?
  22. Mar 12, 2025 at 12:06 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Same guy who is responsible for Gen 3? Thanks, I'm glad I added coolers to both our Tundra and Sequoia.
  23. Mar 12, 2025 at 1:06 PM
    Tundrav82019
    Leo
    What product did you use for a added cooler?
  24. Mar 12, 2025 at 1:10 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  25. Mar 12, 2025 at 8:09 PM
    Tripleconpanna
    Drain n fill every 60k, but my first one on the '21 will be right at 30k when I do the cooler install... I'll then do another one at 60k (unless the first drain and fill smells burnt or excessively dirty)... if the fluid seems degraded, then I'll do a second one fairly quick after the first to clear out the burnt up fluid.
    Hayden or Setrab seem to be the most popular...
    I have a Setrab w/custom bracket from someone on the forum and then a few OE parts to complete the list (T-stat assembly, hard lines, etc..)
    Quite frankly, as others have pointed out... any quality cooler should do the job :thumbsup:
  26. Mar 12, 2025 at 8:11 PM
    Tripleconpanna
    Most readers will display "1" and "2" which is pan temp and at the converter temp respectively...
  27. Mar 12, 2025 at 8:51 PM
    Gtboosted
    Gtboosted New Member
    Los Angeles
    2020 CSM Tundra 1794
    Heres another option...I got the veepeak Bluetooth obd scanner. Then used the fusion app with the toyota upgrades. All in for $45. You can see a bunch of parameters on your phone or head unit if you have android auto.
    I don't need to monitor all the time so I'm happy with it.
    The $100 in savings went to my budget to piece together my own cooler like the GCS. It was about $700 including the custom bracket. It can be done a cheaper if you use a different cooler and diy the bracket.
    Tripleconpanna likes this.
