  1. Mar 10, 2025 at 4:56 PM
    You have to pull the shocks to adjust them? I thought they were adjustable on the truck?
  2. Mar 10, 2025 at 5:12 PM
    Fbrook loner
    Fbrook loner New Member
    Paul
    Fallbrook, CA
    2004 Tundra AC V8 2wd
    Replaced the pcv valve. I'm assuming it was the original one. Pretty dirty/oily. No idea if it'll effect performance. But an inexpensive part, easily accessible, took 10 minutes. Hopefully it doubles my gas mileage and removes the large dent on the passenger side. Fingers crossed.
  3. Mar 10, 2025 at 5:15 PM
    Looks like you’re missing the little foam cozy that goes over it so you won’t burn your hands.
    Fbrook loner[QUOTED] likes this.
  4. Mar 10, 2025 at 5:24 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Solid! I like it. I might have to steal that idea when I get around to doing hammer hangers and shock relocation
    bmf4069 and oscardog86[QUOTED] like this.
  5. Mar 10, 2025 at 5:25 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    I have always adjusted mine on my truck
    455h0le_dachshund likes this.
  6. Mar 10, 2025 at 5:28 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    6112’s arent truck adjustable. I mean, they are if you kive to offend osha, but if you appreciate your hands, its best to oull em off. I really wouldnt recommend adjusting threaded shocks with weight on the truck, either.
    bmf4069 and oscardog86 like this.
  7. Mar 10, 2025 at 5:28 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't fear the preload.
    Unless you max em out or get close to it, you won't notice a hardsher ride.
    bmf4069 and 805Tundra like this.
  8. Mar 10, 2025 at 5:29 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Its hard to get a good measurement under load.
  9. Mar 10, 2025 at 5:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You got eyeballs :p
  10. Mar 10, 2025 at 5:39 PM
    805Tundra
    Ben
    Central Coast
    I wouldn’t call 6112s a truly adjustable coilover. I will always lift the front end up before adjusting so there is no weight on the suspension
    bmf4069 and FirstGenVol like this.
  11. Mar 10, 2025 at 6:15 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    We have notches. Both mine are on low.
  12. Mar 10, 2025 at 6:49 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Some manufacturers will tell you to pull before adjusting. Main reason being, under tension, the collar/lockring/nut/whatever you wanna call it may cut new and/or strip the threads as you torque on it. This is more likely when you're going in the direction of compressing the spring, versus if you were releasing tension from the spring, IIRC.
    Reality is, it's definitely easier to adjust installed depending on whether you're going UP or DOWN. But word to the wise: Always check what your manufacturer recommends before you FA&FO.
    Tlar25, bmf4069, oscardog86 and 2 others like this.
  13. Mar 10, 2025 at 6:56 PM
    Not the same thing as what he's running. His should be adjustable with a spanner wrench. Yours are not.
  14. Mar 10, 2025 at 7:04 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    He's got many videos on Toyota IFS, his latest is also good for stuffing big tires. Watching most of his suspension videos should really help inform what you want aesthetically vs functionally and break down almost all the pros and cons.
    Good luck!
  15. Mar 10, 2025 at 7:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    And make sure the clean the threads, if it's been on the truck, before cranking on it
  16. Mar 10, 2025 at 8:22 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Fox suggests you pull them off the truck. The shock body and threads are aluminum and I’ve heard you can strip them if you don’t take enough load off them.
    I tried adjusting them on the truck with spring compressors and it’s honestly faster off the truck. I think it took 2 hours total for both sides.
  17. Mar 10, 2025 at 8:29 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    On the Kings you just jack up the truck and take off the tores, loosen the collar nut, and spin the collar. All while on the truck. But I misplaced my spanner wrench. :(
    oscardog86 likes this.
  18. Mar 10, 2025 at 8:37 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    @shifty` has it right from my understanding. And when I tried using spring compressors with the coilovers on the truck the shock tower or LCA got in the way. It was actually way easier taking it off the truck and adjusting.
    I’m not sure if ADS is the same way, but I think I’ve made my opinion clear that I’m not impressed with Fox for our trucks. I would look to radflo as a cheaper option (which I haven’t tried yet. Fox might push me to that point) or just splurge on ADS and be done.
    bmf4069, FirstGenVol and shifty` like this.
  19. Mar 11, 2025 at 8:21 AM
    Dolfimus_prime
    Dolfimus_prime New Member
    2006 Black DC
    GX460 brake caliper & rotor upgrade.
    Do you by chance have pics of your wolf box set up?
  20. Mar 11, 2025 at 9:14 AM
    bmf4069 Captain wtf
    Yeah. Thanks for that. I went down a rabbit hole yesterday and watched most of his videos just to realize how fubar my setup is. No wonder I rub on 33s. I need a SAS.
    Tlar25 and Kimosabe like this.
  21. Mar 11, 2025 at 9:21 AM
    I'm starting to think ADS shocks are the best overall option for our trucks. I've never heard a negative review. If money was not a consideration that's what I would pick.
    My ICON c/o's will have to be rebuilt at some point and I'm unsure what I'll do at that time.
  22. Mar 11, 2025 at 9:34 AM
    I just can't justify a highly advanced, purpose built offroad shock setup for my uses. If I'm 100% honest, I offroad very little. I commute, I tow, I use my truck for utility things often. Need something robust due to the towing and utility stuff. But not advanced woops stuff (never use it for that unless there are two speed bumps really close together).
    Tlar25, 805Tundra, bmf4069 and 3 others like this.
  23. Mar 11, 2025 at 9:48 AM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Very nice.
    Where did you order from and what was the total price tag?
  24. Mar 11, 2025 at 9:50 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    5100's an all four corners is perfect for my use. Its an Rv that can go off pavement, not a wheeling rig that I camp out of.
  25. Mar 11, 2025 at 9:53 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Since King is semi local to me, their rebuild prices are pretty fair compared to other rebuilders. Nearly half of what one popular shop in SD quotes. Dropped them off last week. Would love to learn to DIY eventually though.
  26. Mar 11, 2025 at 9:57 AM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    Nice truck. I like the setup. I've got that same paint color. Did you use vinyl wrap on the side mirrors? And I see a grill on your garage wall. Do you have a different grill on the truck? I am just gathering ideas!
    Kimosabe[QUOTED] and oscardog86 like this.
  27. Mar 11, 2025 at 10:05 AM
    notlikejohnny
    notlikejohnny New Member
    Shenandoah Valley, VA
    2005 4WD DC Limited, Phantom Grey
    As an update to the last post back around new years...had the driver side wheel bearing changed and an alignment done by the local 4x4 shop. I had noticed my driverside tire seemed to be wearing on the outside edge faster than the passenger based on my last few tire rotations. Hoped the alignment would have fixed it, but have been monitoring it the last two months, and doesn't seem to have changed. Here are the numbers for y'all's analysis, does this mean they actually increased the camber a degree which would make this issue worse? Mostly highway driving. Thoughts?
    Before:
    Camber: -.1
    Caster: 1.9
    Toe: .01
    Total toe: .12
    Steer ahead: -.05
    After:
    Camber: -.2
    Caster: 1.9
    Toe: .05
    Total toe: .11
    Steer ahead: 0
    Also, now that its finally starting to average above freezing each day here, time to get going on the valve covers. The AT-205 seems to have helped out and slow down the trickle. So thanks @shifty`
    Gathering up the parts necessary and ordering from Serra (25% off for the next 4 days for those looking, free shipping over $75).
    So are these the latest and greatest for my 05 DC?
    VC gaskets - 11213-0F010, 11214-0F010
    Spark plug gaskets x8 - 11193-50010
    Valve cover bolts x18 - 90080-10330 Do we know if this a pack or this is price per bolt?
    FIPG - 00295-00103
    Had also planned on swapping spark plugs and coil packs while in there, but is it necessary if there have been no codes or issues starting? To my knowledge these are originals.
    G_unit3000 likes this.
  28. Mar 11, 2025 at 10:17 AM
    Same
    JakeJake[QUOTED] likes this.
  29. Mar 11, 2025 at 11:50 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Are you lifted with stock UCA? That caster number is low.
  30. Mar 11, 2025 at 11:55 AM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    A bit above 2k. Trailbuilt is where I ordered them from. Took 2.5 weeks, which is fine, but they forgot to ship my center caps. Working on that now.
    G_unit3000[QUOTED] likes this.
