Tailgate Badge Removal
Discussion in '3rd Gen Tundras (2022+)' started by YeOldeRusty, Mar 10, 2025.
  1. Mar 10, 2025 at 12:27 PM
    YeOldeRusty
    YeOldeRusty [OP] New Member
    Mac
    2022 Silver CrewMax Limited
    Hi all,
    I just picked up a new to me 2022 Tundra this weekend. After driving my 2009 Tacoma for the last 11 years, I'm excited to get started building this Tundra out how I like.
    Everything is bone stock on the truck except for these added letters to the Tundra badge on the tailgate. For some reason the previous owner added these chrome diamond letters and nothing else. Needless to say, I'm not a fan of them so I'd like to remove them. What's the best way to go about getting them off without damaging the paint underneath? Heat gun, acetone, etc?
    Thanks
  2. Mar 10, 2025 at 1:00 PM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    I've always just used a hair dryer and gentle prying, but on my Tundra a buddy handed me some braided fishing line. I blew him off at first, but damn that stuff cut through like butter. then I used straight rubbing alcohol to remove the mounting tape residue. The few bucks is well worth it, and you only need a couple feet of it.
  3. Mar 10, 2025 at 1:18 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Heat and dental floss for me in the past, clean up residue with wd-40 and a rag. Easy work.
  4. Mar 10, 2025 at 1:24 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You'll need a hair dryer, a small plastic trim removal tool, and some fishing line. I don't like using a heat gun on trucks as I don't trust that I won't boil the clear coat :anonymous:
    I would get it all hot, pick up a corner with the trim tool, and then start flossing away with the fishing line! It'll get a little tricky thanks to the embossed nature, but you can do it!
    1lowlife and RobertD like this.
  5. Mar 10, 2025 at 2:06 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I think the recessed nature of those letters is going to make any method difficult.
    Good luck
    1lowlife likes this.
  6. Mar 10, 2025 at 2:18 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Is it actually diamond plate aluminum?
    I’d try steam. Works well with adhesives.
    Roborob70 likes this.
  7. Mar 10, 2025 at 2:45 PM
    YeOldeRusty
    Mac
    Nope just some cheap, stick-on pieces. It's quite literally the only modification the previous owner made to the truck. I should have gotten the dealer to remove them, but I picked the truck up in Florida and had to drive back to Tennessee. Didn't feel like waiting around.
  8. Mar 10, 2025 at 2:59 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    You’re better off removing on your own. Good luck what ever method you decide
  9. Mar 10, 2025 at 3:03 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I recently removed my carbon fiber inserts that were on my 2014 for 9 years after getting my black bumpershellz.
    They looked a lot like what you have there..
    As @memario1214 suggested I got under it with a dash removal tool and they peeled right off, most of them in one piece.
    Amazon.com: Tresalto Auto Trim Removal Tool Kit - 5-Piece No Scratch Pry Tool Set for Car Panel and Dashboard Removal - Includes Door Panel Tool, Push Rivets, Car Clips - Essential for Interior Trim Work - Blue : Automotive
    I then used Goof Off to gently remove any residue.
    I've used it on my truck paint before with no problems.
    I'm going to agree with @Matt2015Tundra I don't think you could get fishing line under that recessed area.
    I don't think you'll need to anyway.
    Peel up an edge and it should come right off.
    I wouldn't bother heating it unless you have problems.
    Kinda bummed me out removing it.
    It was my first mod to the truck, but it didn't match the black..
    Replaced it with this..
    Matt2015Tundra, OldGuy03 and oddhours like this.
  10. Mar 10, 2025 at 3:07 PM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    biggest thing, take your time...
    Soupbean77, Xcumminsguy and 1lowlife like this.
  11. Mar 10, 2025 at 5:27 PM
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    I added these stickers early on. Sat on the truck for a few months and ended up not liking them. They peel off fine without any floss, heat. Just need to get one of the corners started. Try fingernails first and last resort a plastic trim tool. Once you can get grip it is easy.
    Got mine from cali raised (matte with red.yellow.orange stripe). They can be re-applied from what I can tell. If anybody wants them you’re welcome to have them. I’m in Md. Can ship if you pay.
  12. Mar 10, 2025 at 6:09 PM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    The fishing line or dental floss will cut the letters themselves off, but you’ll still have the adhesive and possibly foam adhesive still stuck to the panel. I’ve used an el cheapo heat gun from Harbor Freight and also have a nicer Stanley gun. Doesn’t really matter, just use the lower heat setting and take your time and be patient. May want to invest in some light duty thin rubber palmed gloves… will be much easier on your hands. Get a bottle of Meguiar’s Scratch and Swirl Remover to remove any paint smudges or fine scratches.
