FS: New Caltracs Traction Bars
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Ponderosa_Pine, Nov 12, 2024.
Thread Status:
Not open for further replies.
  1. Nov 12, 2024 at 6:27 PM
    Ponderosa_Pine
    Ponderosa_Pine [OP]
    Northwest
    (Sold)
    Ended up not using these on my build. Brand new in box. This is the 8110 version which is for the standard install on a 2007-2016 Tundra (should fit up to 2021): https://calvertracing.com/product/8110-caltracs/
    You pay shipping (likely 25$ or so depending on distance).
    You will be able to return your cores to them for a 200$ core charge refund (effectively making this 200$ cheaper).
    Asking 450$! Venmo preferred.
  2. Nov 12, 2024 at 10:20 PM
    blenton
    blenton New Member
    Hmmm… :monocle:
  3. Nov 12, 2024 at 10:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Perfect for keeping the power to the ground for some get up and go!
    GLWS!
  4. Mar 10, 2025 at 3:26 PM
    RobertD
    Robert
    DFW, Texas
    Did you go with a different traction bar or just go without?
  5. Mar 10, 2025 at 3:36 PM
    Ponderosa_Pine
    Ponderosa_Pine [OP]
    Northwest
    I used the SDHQ kit instead due to wanting offroad articulation, that kit is also easier to install since it can be done without removing parts of the suspension, it is much more expensive though and weighs more.
    Each has its place, the Caltracs are simpler and meant for street/strip.
    HulkSmurf14, Mdl and RobertD[QUOTED] like this.
Thread Status:
