EDIT: I TOOK THE PLUNGE! So I test drove a ‘25 Limited…
Discussion in '3rd Gen Tundras (2022+)' started by WindyPorchrocker, Mar 1, 2025.
  1. Mar 1, 2025 at 1:00 PM
    WindyPorchrocker
    WindyPorchrocker [OP] New Member
    Kevin
    2025 Tundra Limited TRD Off Road
    None
    So… I test drove a brand new 2025 Tundra Limited with Nightshade package. Beautiful truck. But not sure how I feel about it to be honest. It literally had 1 mile on the odometer.
    My immediate concerns:
    1. Burning smell- I assumed this was something burning off the exhaust after it warmed up, but it was a little concerning. Not enough to really scare me away though..
    2. I punched it at a light and smoke poured out of the tailpipe! WTF! Is this normal? I literally could not justify being worried about that while driving off the lot if I had purchased it
    3. Wind noise in the cabin going 60MPH was far noisier than my 2021 Nissan Titan Platinum
    I’ve always believed in naturally aspirated engines being the way to go as they have less moving parts, and less maintenance overall. Not sure how I feel about this powertrain yet.
    Definitely hesitant on pulling the trigger, idk if Toyota has their shit together with this new Gen yet…
    May wait and try out a 2026 refresh…
    PWRGENgasturbine likes this.
  2. Mar 1, 2025 at 1:06 PM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
  3. Mar 1, 2025 at 1:07 PM
    WindyPorchrocker
    Kevin
    None
    Why did you post a link to my own thread? Lol… I hadn’t test drove it when I wrote that…
  4. Mar 1, 2025 at 1:59 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I think his point was you could have just updated your other thread, instead of starting a new thread.
    FYI, the burning smell is absolutely normal for a brand new engine. Are you sure it was smoke or condensation you saw? If it was actually dark smoke, that would concern me.
    The bottom line is, you didn't have a good test drive experience. So, don't buy the truck.
    jpink, GODZILLA, bulldog93 and 11 others like this.
  5. Mar 1, 2025 at 2:11 PM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Complete doubt it was smoke. When its cold and you get on the gas a ton of condensation comes out the exhaust. It is a very high flow exhaust system to accommodate the turbos. Note the size of the exhaust pipe! I highly doubt it was smoke.
  6. Mar 1, 2025 at 3:05 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    1 mile on it? Come on, it's a brand new truck, sure it will smell a bit while things heat up & burn off. Smoke from tail pipe? I'd say condensation or again, newness burning off. Just keep your Titan & be happy then.
  7. Mar 1, 2025 at 3:46 PM
    WindyPorchrocker
    Kevin
    None
    Apologies, I guess I’m used to reading forums and not really posting in them, so still getting used to the etiquette :)
    what about the wind noise on your 3rd gen’s? My Titan is super quiet. Do the higher trims over the limited come with added insulation?
  8. Mar 1, 2025 at 4:06 PM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    My 23 Limited TRD OR is quiet. Maybe take another one out for a test drive and see if it's the same.
  9. Mar 1, 2025 at 4:49 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Same for my '24 same trim, no wind noise. I don't believe it's trim specific as SOME upper trim owners have noted it as well. It's not an across the board problem.
    Same advice. Go for another test drive.
    If you still don't get any warm fuzzies, don't buy one.
  10. Mar 1, 2025 at 4:53 PM
    WindyPorchrocker
    Kevin
    None
    I like it- thanks Fam. Going to check a different dealer tomorrow.
  11. Mar 1, 2025 at 4:54 PM
    plinyyounger
    plinyyounger New Member
    Ken
    Idaho
    2025 Tundra limited
    3-2 lift, KO3’s, Fuel wheels, tint.
    You should buy something else.
  12. Mar 1, 2025 at 4:56 PM
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    My 2024 is more quiet than the 2018 was.
    Tundrastruck91 likes this.
  13. Mar 1, 2025 at 4:59 PM
    WindyPorchrocker
    Kevin
    None
    I’ve read that some have traced the wind noise to the door seal. They added 3M tape behind the seal in spots to thicken it between the body and door and it reduced wind noise. Maybe the one I drove had this issue, it almost seemed like a window was cracked but I checked and they all were closed. I’ll drive another one. It’s also windy as heck in my area today, but my current car was much quieter driving to and from the dealer
  14. Mar 1, 2025 at 5:39 PM
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    How many opinions do you need? Seems your extremely skeptical, the truck isn’t for you and that’s ok too.
    Blufin likes this.
  15. Mar 1, 2025 at 8:57 PM
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    I purchased a 2025 limited 4x4 in late November and have been extremely happy with the Tundra. Smell is normal for a new truck and dissipates in a couple hundred miles. Mine is also very quiet, more so than my previous Sequoia Platinum, even with BFG KO3 tires. I’d recommend test driving another one and see if you have a similar experience.
  16. Mar 1, 2025 at 8:58 PM
    WindyPorchrocker
    Kevin
    None
    I think I’m going to- in talks with another dealer. Appreciate the advice
    Raven67 and MAC25Tundra like this.
  17. Mar 7, 2025 at 4:34 PM
    WindyPorchrocker
    Kevin
    None
    So, I went to another dealer and drove another tundra which did not have the dreaded wind noise, and I took the plunge and bought it! 2025 Tundra Limited with TRD Off Road package and a slew of other options. Got a heck of a deal on it. She’s a beaut and drives like a dream. Let the honeymoon phase and accessories frenzy begin!
  18. Mar 7, 2025 at 4:44 PM
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    Sweet… love that color and especially with the blacked out badging and wheels
    WindyPorchrocker[OP] likes this.
  19. Mar 7, 2025 at 4:50 PM
    WindyPorchrocker
    Kevin
    None
    Totally agree, saw it and was like damn that’s a vibe right there. All black on the dark blue it’s slick.
    bulldog93 likes this.
  20. Mar 7, 2025 at 5:25 PM
    lapoolboy
    lapoolboy New Member
    Careful with washing....it's a swirl and scratch magnet. Congrats!
  21. Mar 7, 2025 at 7:06 PM
    BlackNBlu
    Rich
    MN
    Congrats!
    <----You have good taste sir.
  22. Mar 8, 2025 at 7:22 PM
    Retroboy1989
    Northern Utah
    Mine had a burning smell for the first two weeks.
  23. Mar 8, 2025 at 7:26 PM
    WindyPorchrocker
    Kevin
    None
    Yeah it has the burning smell but it’s not bad, seems to be going away. It also blew some smoke from the tail pipe when I stepped on it but hasn’t done it since. For those insistent it’s condensation- it most definitely was not
  24. Mar 9, 2025 at 4:59 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    The burning smell is a preservative put on the exhaust to prevent rust because they don't now how long or what region it may reside in before it sells.
    It's similar or maybe the same preservative that goes on heat exchanges for furnaces.
    Congrats on the new Rig man, Blueprint is a bad ass color and with the blacked out badges even better.
  25. Mar 9, 2025 at 8:59 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I am a road noise Nazi during test drives due to hyper acousity from hearing damage. One thing I have learned is check the tire pressures always because all vehicles particularly lot queens can have very random tire pressures. And always check which model tire is on a vehicle because some tire companies just make loud tires.
    MTRock likes this.
  26. Mar 9, 2025 at 9:07 AM
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
  27. Mar 9, 2025 at 9:56 AM
    GoHuskers
    Nebraska
    Congrats OP. That's a beautiful truck. Owned mine since 6/24 and still in the honeymoon every time I get to drive it
  28. Mar 10, 2025 at 3:31 PM
    WindyPorchrocker
    Kevin
    None
    I’ve only had it for a short period but there is nothing about it I don’t love. I’ll report back after she gets some miles on her but it’s a well made great driving truck. Not sure where all the hate comes from- it seems like Toyota made a great product in the tundra. Miles ahead of the Titan I drove previously and the F150 I came from before that
  29. Mar 10, 2025 at 4:07 PM
    Retroboy1989
    Northern Utah
    My experience as well.
  30. Mar 10, 2025 at 10:28 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Same, a year and a half in, not one complaint.
