  1. Mar 9, 2025 at 8:40 AM
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    Look around fellas, bronze is the new black. I don’t hate it, I’m on the same train.
    DrRansom, mgm16trdpro, woods and 9 others like this.
  2. Mar 9, 2025 at 8:50 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Your not wrong. I do see a lot more bronze than I ever did.
    i still dont like black rims. Black rims are sport pkg upgrades for minivans. :puke:
    Mullen[QUOTED] likes this.
  3. Mar 9, 2025 at 10:35 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I hope so. I got a set of deflectors for the vents under the seats off etsy to help the passenger area out, they didn't fit so I'll have to modify them. I'm hoping to improve the kid's heating and cooling between the two.
  4. Mar 9, 2025 at 11:07 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    HulkSmurf14 and ZPhilip[QUOTED] like this.
  5. Mar 9, 2025 at 12:22 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    VLEDS tail light conversion installed this morning. Pretty straight forward, can't wait until this evening to check them out !
    woods, OHwendTrd, Tundra234 and 2 others like this.
  6. Mar 9, 2025 at 1:16 PM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Replaced the Serpentine belt, pulley, and tensioner with the new kit from RockAuto. Great quality parts and the fit was perfect. The tensioner is pinned to spring back once you easily guid ethe belt in place.
    PXL_20250309_161609599.jpg PXL_20250309_161647483.jpg PXL_20250309_170833557.jpg PXL_20250309_171233823.jpg PXL_20250309_171243266.jpg PXL_20250208_185046471.jpg PXL_20250208_184746876.jpg
  7. Mar 9, 2025 at 4:02 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    reywcms and HulkSmurf14 like this.
  8. Mar 9, 2025 at 4:16 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    :eek2:
  9. Mar 9, 2025 at 5:25 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    I don't see that Dayco kit on Rock Auto just a kit made by Continental
  10. Mar 9, 2025 at 7:37 PM
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    Apologies for not getting back to you sooner! Unfortunately the notifications on this forum never seem to get to me on time lol
    If your not looking for crazy performance, I'd highly recommend the kenwood excelon KFC-xp6902c component speakers.
    Comes with two super nice 6x9 speakers, speaker brackets that bolt right in to the weird toyota bolt pattern in the door, as well as two 2.5" full range speakers for the dash that also bolt right in, all for the price of $230.
    https://www.crutchfield.com/p_113XP6902C/Kenwood-Excelon-KFC-XP6902C.html?tp=105
    Those 6x9s are somewhat power hungry so you'll want to look at adding an aftermarket amplifier, but once they get the power they want they output tons of midbass (will get to this later)
    Since you have a 2021, it still has a factory amplifier even though it's the non-jbl version so you will have to bypass it in order to add your own amplifier. With the non-JBL tundras, the radio powers the 3 dash speakers (left, right, and center. the center is not a true center channel speaker, rather a dual voice coil speaker receiving inputs from both left and right speakers.) The amplifier is there solely to power the front and rear door speakers.
    If it were my truck and I was trying to keep it "budget friendly" I would be looking at an all-in-one amplifier. I wouldn't even consider doing anything crazy to the rear, and would solely focus all of my attention (and money) on the front speakers only. If you REALLY want to replace the rear speakers, kenwood sells some relatively cheap coaxial speakers that bolt right into place with the correct adapters (must unplug the factory tweeter from the door panel)
    https://www.crutchfield.com/p_113KFCX183/Kenwood-Excelon-KFC-X183C.html?tp=105
    Instead of letting my amplifier power both front and rear speakers with a passive crossover between the front midbass and fullrange, I would instead run two of my ampilifer channels to the front midbass and the other two channels to my front full range dash speakers for a "full active" system. This will not only get me the most output, but also more detail in the music as well as fine tune control between midrange and tweeter.
    In order to do just that, I would have to run new wires from my amplifier to my new dash speakers (which is very straight forward and simple to do since you'll already be running RCA's to my new radio anyway)
    I also understand you said you don't want a subwoofer, but I'd highly recommend adding one even if it's nothing exceptional like any of the truck style kicker boxes. You don't realize what your missing out on in music until you get your first subwoofer, and there is plenty of room behind the back seat of the crewmax's to fit them (just make sure you get speaker grilles, otherwise they will slap the back of the seat causing damage to the speakers)
    My "budget" choice. Kicker also sells a single 10" box that is cheaper with less power handling
    https://www.crutchfield.com/p_20648TT122/Kicker-48TCWRT122.html?tp=112
    With all the things in mind I stated above, that would mean I'd start looking into 5 channel amplifiers. The first amplifier that came to mind would be the Kenwood XR901-5 ($580) just to get the full kenwood excelon setup. It outputs 60 watts for the 4 channel side of things, and 400-600 watts for my subwoofer(s).
    https://www.crutchfield.com/p_113XR9015/Kenwood-Excelon-XR901-5.html?tp=115
    If 400-600 watts is too much power and I want to save some money, then I'd step down to the Kenwood X803-5 ($400) which is 50 watts for the 4 channels and 300-500 for the subwoofer(s).
    https://www.crutchfield.com/p_113X8035/Kenwood-Excelon-X803-5.html?tp=115
    Now if I wanted the absolute best sound possible with the ability to control and tune every speaker separately (I do :)), then I'd be looking for a 5 channel with built in dsp. The audiocontrol D-5.1300 ($900) would be my first choice as it's got great power output with 100 watts per channel for my kenwood midbass and full range, 300-500 watts for my subwoofer(s), as well as a built in dsp with very intuitive software to setup and adjust (It was my first every dsp amplifier that I installed) that lets me fine tune everything independently.
    https://www.crutchfield.com/p_161D51300/AudioControl-D-5-1300.html?tp=115
    Hoping this information helps give you an idea on what to look for/expect.
    This is mostly the things that I would have focused on and/or looked at first, you can obviously pick things that you think might better fit your needs instead ;)
  11. Mar 9, 2025 at 8:01 PM
    20manny1996
    20manny1996 New Member
    Manuel (Manny)
    2017 Limited Super White CrewMax
    Replaced my JBL DSP 4086 amplifier with the meatier JL Audio VX800/i8 and mounted the sub knob on the center console.
    Also painted the insert from my new color matched (super white) platinum grille.
    Unfortunately ran out of time this weekend :( but I will be putting this bad boy on next weekend :cool:
  12. Mar 9, 2025 at 9:43 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Got my C4 Hybrid installed
  13. Mar 9, 2025 at 10:03 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Got some dirt/mud/lake bed time with the boys this weekend. The wife got to mash the throttle while I took the pics.
  14. Mar 9, 2025 at 11:07 PM
    SAGE63
    San Diego County
    French Avocado and HulkSmurf14 like this.
  15. Mar 10, 2025 at 5:05 AM
    Norfolk757
    Tom
    Norfolk, VA
    HulkSmurf14 likes this.
  16. Mar 10, 2025 at 5:34 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    The brighter the better imo. But ymmv. To each his/her own.
  17. Mar 10, 2025 at 7:16 AM
    brevard828
    brevard828 New Member
    2021 Limited TRD Off Road
    Took the rig and kiddos down to the Auger Hole in Pisgah National Forest this weekend.
  18. Mar 10, 2025 at 7:23 AM
    brevard828
    B
    est upgrades for towing were firestone airbags and the TRD swaybar. I have Dobinsons leafs now but before they were just stock. With the airbags and TRD sway i didnt use WDH or sway control. Towed the camper and dump trailer like a dream.
  19. Mar 10, 2025 at 7:32 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    How much room is there for our large trucks? Pinstripe tight? Or ample space? I'm not terribly far from there and itching to get out a bit.
  20. Mar 10, 2025 at 7:39 AM
    Florida AF
    Logan
    North Florida
    this... this is amazing..... Is it true offroad or can us non crazy people drive it... heading over to the googs now...
  21. Mar 10, 2025 at 7:43 AM
    brevard828
    The road is surprisingly clear especially after the hurricane. There are a few spots that will pinstripe but nothing major. Im not one to pinstripe my vehicle and i was happy with the minimal new beauty marks. Definitely worth the drive. Theres a sweet flat open camping spot with firepit. from the parking lot its a solid hour down there. 25% grades and tight switch backs.
    mgm16trdpro, _none_, equin and 3 others like this.
  22. Mar 10, 2025 at 7:52 AM
    brevard828
    Its nothing insane. but definitely 4low and 1st gear stuff. just super steep in places. no mud pits or anything. You enter it in Gorgeous State Park off of white water road. The gate is open all year. Just be warned when you get into the bottom there is zero cell service on verizon or At&T
    Upon entry to the road there are 3 substantial gravel roller/humps to test ground clearance. if you make it over those without scrubbing youre good to go!
  23. Mar 10, 2025 at 7:52 AM
    Florida AF
    Logan
    North Florida
    Just watched parts of an F150 driving through there and it appears I will not be able to make that trip in my truck.. which seems odd with it being a MTB trail area... hrm... i will keep looking, those pictures you posted are awesome.
    brevard828 likes this.
  24. Mar 10, 2025 at 7:54 AM
    Florida AF
    Logan
    North Florida
    I am 2wd but can air up and down. no winch or recovery. I will have a satellite communicator before I make my trip up that way or west again. I may DM you before I make any decision as we get closer.
    bulldog93 and brevard828[QUOTED] like this.
  25. Mar 10, 2025 at 7:58 AM
    brevard828
    Yea of course. i live in brevard if you need a wheeling buddy. im taking my friend in his parkinglot princess Raptor down there in a couple weeks.
  26. Mar 10, 2025 at 7:59 AM
    Florida AF
    Logan
    North Florida
    I laughed a little to hard at this... Have fun and post more pics lol!
    brevard828[QUOTED] likes this.
  27. Mar 10, 2025 at 8:13 AM
    Tundra family
    Tundra family New Member
    So many options with bags, do you have a recommendation? I don't really think I'd need the onboard compressor
    Edit: this is what I'm looking at
    https://www.amazon.com/Firestone-W2...=&hvlocphy=9030104&hvtargid=pla-2281435178058
    Tunrod likes this.
  28. Mar 10, 2025 at 8:34 AM
    00h2itr
    00h2itr New Member
    Carolina's
    I wonder if the 3 of us can coordinate a trip.
    I've been considering the Georgia Traverse too.
    I backpack in/near Gorges on the FHT, so I'm somewhat familiar with the area. Plenty of camping gear as well.
  29. Mar 10, 2025 at 8:38 AM
    Florida AF
    Logan
    North Florida
    That would be awesome. Full disclosure, I am a ways out from something like that. With the baby now, I like to go to places where the truck is safe (I need to drive it home) and I can manage the little one. So we try to go to easy hikes and waterfalls when we travel. I am going to GA/SC next month so I am seeing how far this place is from where I will be. I am a sucker for waterfalls.
    Tripleconpanna and brevard828 like this.
  30. Mar 10, 2025 at 8:45 AM
    Here you go lol.
    Jego, Ace96, French Avocado and 5 others like this.
