Window Switches & Lock Button Illumination on the driver door
Discussion in '3rd Gen Tundras (2022+)' started by PapaDave418, Dec 25, 2024.
  1. Dec 25, 2024 at 12:56 PM
    PapaDave418
    PapaDave418 [OP] A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    This has bugged me for years and thought I’d see if anyone has a work around? When I open the door at night the courtesy and interior lights are on but the door and control panel is dark. Finding the unlock button is challenging sometimes. Once the headlights or running lights are on the door panel controls light up.
    I did a search and I can see other people don’t like it either but haven’t seen a work around?
    I have a 2022 Limit OR with premium and power packages.
    For example my door before sunrise, the light at the bottom is the courtesy light. The camera makes it look brighter than it is, but you can see the control panel is dark.
    sudobash likes this.
  2. Dec 25, 2024 at 1:01 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    What exactly is the problem?
    You can't unlock the doors because it is too dark?
    Don't the doors unlock with the key fob before you get in?
    One would think hitting that unlock switch would be muscle memory after a bit of ownership..
    matth66 likes this.
  3. Dec 25, 2024 at 1:18 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    The control panel on the door doesn’t light up with the courtesy lights. When it’s dark finding that unlock button is difficult in the event I need to. It’s not often but seems like a simple thing if the courtesy lights are on the control panel would be illuminated.
  4. Dec 25, 2024 at 1:47 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Well, you could rewire it to come on with the courtesy lights, but then it would be off when the courtesy lights are off..:eek2::cool:
    OR, push the unlock on the key fob twice and it unlocks all the doors.
    That would probably be easier..
    Here is your manual if you need anything else..:thumbsup:
    OM0C056U.pdf
  5. Dec 25, 2024 at 1:49 PM
    Red Freighter
    Red Freighter Red Freighter
    Fred
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    Hi all, you can program it to unlock all the doors.
    1lowlife and DRP like this.
  6. Dec 25, 2024 at 1:50 PM
    DRP
    DRP Old Member
    Dave
    There is a setting that unlocks all the doors when you grab the outside handle.
    1lowlife likes this.
  7. Dec 25, 2024 at 2:29 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    All great answers, I am aware that hitting the FOB twice unlocks all the doors and of the programming settings for the doors and the handles. My use case is when I am off road with my truck and my keys aren’t on me.
    Merry Christmas to everyone
  8. Dec 25, 2024 at 2:32 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    The old man with the 2014 forgets about touching the handle to unlock....:eek2::cool::thumbsup:
  9. Dec 25, 2024 at 2:41 PM
    tundramh
    tundramh New Member
    OHIO
    Mount a little led in a blank dash button spot on the lower left and grab a 12v wire off of one of the installed buttons. Maybe a blue light to match the footwells if you have those. oh....just read again. Your truck is off. Maybe mount the light above the door pull handle and tap the courtesy light.
    PapaDave418[OP] likes this.
  10. Dec 25, 2024 at 2:46 PM
    Taikowaza
    Taikowaza New Member
    Check Carista it has a bunch of settings that could help. Have found it a useful tool.
    1lowlife and PapaDave418[OP] like this.
  11. Mar 7, 2025 at 10:24 AM
    Bob8765439
    Bob8765439 New Member
    Agreed. These should come on with the courtesy and interior lights. It's rather moronic that they don't. No excuse for this Toyota.
  12. Mar 9, 2025 at 10:21 PM
    JQ4x4
    JQ4x4 New Member
    2023 Toyota Tundra Platinum
    Just noticing this myself. The illuminated lights for lock/unlock when you enter the truck should be lit up and easy to see.
    Soupbean77 likes this.
  13. Mar 10, 2025 at 2:28 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Here’s a very easy and cheap solution maybe… I have a couple handguns with photo-luminescent sights.
    A high quality luminescent will hold and transmit light with low, brief exposure… as when you’d open your door and the overhead courtesy lights come on. Hole punch some luminescent tape and stick the punch out on the switch..IMG_8861.jpgIMG_8862.jpg
    Tundrastruck91 likes this.
