Condensation? Water Leak
Discussion in '3rd Gen Tundras (2022+)' started by duudethatsrad, Mar 7, 2025.
  1. Mar 7, 2025 at 5:14 PM
    duudethatsrad
    duudethatsrad [OP] New Member
    Just noticed a water leak on the driver rear door side.
    It is water, I didnt see any condensation lines.
  2. Mar 7, 2025 at 5:29 PM
    JDAZ
    JDAZ New Member
    NJ
    2022 Lunar Rock TRD Limited
    Chrome Delete, TRD Pro Grill with BD light bar & OEM switch Beatsonic Amp Undercover armor flex cover
    Muffler weep hole?
  3. Mar 7, 2025 at 5:42 PM
    mbgls63amg
    mbgls63amg New Member
    Joshua
    2010 Toyota Tundra SR5
    I’d definitely say that’s a muffler leak. Mine is doing the same thing. In fact, when it got below freezing here, I looked under my truck and saw an icicle hanging directly from the muffler. lol
  4. Mar 8, 2025 at 2:16 AM
    JDAZ
    JDAZ New Member
    NJ
    There’s a weep hole in the rear of the muffler. It’s by design
  5. Mar 8, 2025 at 4:23 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    What you mean a water leak? Water isn’t used for any fluid in your truck. Aside from possibly the windshield wipers.
    That is called condensation. Water is a byproduct of internal gasoline combustion engines.
  6. Mar 8, 2025 at 7:13 AM
    JDAZ
    JDAZ New Member
    NJ
    Well technically he’s right, as are you, it is a water “leak” from condensation from the exhaust. It is a designed”leak” though.
    Also, just for clarification, the water from the exhaust comes from 2 sources. Condensation in the piping, and it’s a byproduct of the catalytic converter process.
    mbgls63amg likes this.
  7. Mar 8, 2025 at 9:59 AM
    Danman34
    Danman34 New Member
    Danny
    The water comes from the water vapors that are produced as a by product of gasoline combustion. The metal exhaust pipe is cool. Exhaust is warm and full of moisture, hence the condensation that is produced. You can completely remove the cats and still get water out of the exhaust.
  8. Mar 8, 2025 at 10:32 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Speaking of condensation, what is the normal amount that should drip from the AC system when it's hot and humid outside? Let's say when you stop for fuel on a summer roadtrip thru the South.
    My 2023 Tundra seems to drip excessively compared to other vehicles I've owned.
  9. Mar 8, 2025 at 10:44 AM
    Danman34
    Danman34 New Member
    Danny
    There’s no standard amount. It’s all dependent on all the variables. Outside temp. Humidity. Ac setting whether on fresh air, or recirculate and the temp it’s on.
  10. Mar 8, 2025 at 11:15 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks. That's what I figured...too many variables to quantify. I'll assume it's operating normally.
  11. Mar 8, 2025 at 11:35 AM
    Danman34
    Danman34 New Member
    Danny
    I’ve always lived in south Louisiana. Humidity is part of our everyday life. I guess you just don’t pay attention when every single vehicle is dripping water from the ac mostly year round lol.
  12. Mar 8, 2025 at 11:42 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Yeah, I live in dry Colorado, so I was a little shocked when I first saw the puddle under my truck at a gas station in Florida. Then I looked around and saw that every other vehicle at the station had a similar puddle. LOL
  13. Mar 8, 2025 at 3:21 PM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    Needs a bigger hole.
