Method +35mm Offset Wheels
Discussion in 'Wheels & Tires' started by Desert_Racer, Mar 8, 2025.
  1. Mar 8, 2025 at 2:33 PM
    Desert_Racer
    Desert_Racer [OP] New Member
    I didn’t see a ton of info on these wheels so I figured I’d make a post in case anyone is looking.
    18 Crewmax with Bilstein 6112’s at 1.9” up front, rear is stock height. Head gun and a roller used for putting grip tape on skateboards (like $7 on Amazon) to massage the front of the wheel well with wind deflectors removed, mudflaps removed from the rear of the wheel well. Alignment in spec.
    Method 703 Bead Grip 17” wheels, +35mm offset.
    Toyo Open Country AT3, 285/75R17 C Load
    Zero Rubbing. 99% sure if I left the mudflaps in they would rub. This tire and wheel combo fits like a glove with zero massaging except trimming the tab on the spare tire mount that slips inside one of the lug nut holes to fit inside the method lug nut holes. Basically shaved about 1/16” off.
    I had 275/70 E load BFG KO2s on the stock wheels before. These C load toyos ride like a Buick regal in comparison.
    JackB8675309, mayan, LD_15 and 2 others like this.
  2. Mar 11, 2025 at 10:42 AM
    LD_15
    LD_15 New Member
    Lucas
    San Diego County, CA
    Badass truck! I want the same suspension and tire size setup, eventually!
    Is it fully level or do you have any rake?
    Desert_Racer[OP] likes this.
  3. Mar 11, 2025 at 12:23 PM
    Desert_Racer
    It looks slightly nose high but actually measures out to be roughly 3/4” lower in the front than the rear.
    It’s getting an RCI Arapaho bumper and RXI rock sliders sometime soon (whenever they ship). I’m guessing the weight of those items will make the suspension sag a small amount and look more level.
    LD_15[QUOTED] likes this.
  4. Mar 11, 2025 at 1:20 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    looks sweet. And great offset- More aggressive but not so bad where it slings crap down the truck.
  5. Mar 13, 2025 at 1:34 PM
    Desert_Racer
    I went back to discount today and swapped the C loads out for the E loads. These guys had a hard time breaking the bead, so I guess the Bead Grip deal in these method wheels is legit.
  6. Mar 14, 2025 at 6:06 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Why did you go with the E’s?
  7. Mar 14, 2025 at 8:00 AM
    Desert_Racer
    The Cs were a little squishy at 40 PSI without anything in the back and no trailer. Just wanted to peace of mind.
