Do you change your own oil in your Tundra?
Discussion in '3rd Gen Tundras (2022+)' started by tstex, Jan 27, 2025.
  1. Mar 3, 2025 at 1:13 PM
    #181
    tstex
    tstex [OP] New Member
    Houston & Colorado County TX
    2024 Silver Tundra TRD
    During my first DIY oil change, i tried w a strap wrench and no go. I ended up having to use a pair of channel locks. I first wanted to see if i could get the filter off b4 i attempted to change the oil.
    I read the oil pan bolt should be torqued to 30lbs/ft, so when I started to unloosen the bolt, I expected to put some real elbow grease into it, BUT, I barely had to turn my wrench b4 it turned like it was barely on. What a bunch of xxxx. The torques were reversed: oil filter was was too tight and the oil pan bolt seemed like it was hand tightened.
  2. Mar 3, 2025 at 1:55 PM
    #182
    Retroboy1989
    Northern Utah
    30 ft lbs is correct
    I think there are some bad washers out there that cause the drain bolt to lose torque.
    I had some previously. My last oil change on my 2012 Tunda, the drain plug was finger tight. It was that way on all three of my cars with that bag of washers. I always torque to 30 ft lbs.
    That's good to know. I dont have any garden hoses to trash. I bought this, works perfectly.
    https://www.amazon.com/dp/B01N2GX8I5
  3. Mar 3, 2025 at 2:24 PM
    #183
    tstex
    Retroboy 1989 said:
    "I think there are some bad washers out there that cause the drain bolt to lose torque.
    Wanted to ask the guys here that change their own oil. On my 2014 Ford F150, I had an oil pan bolt that had a simple rubber-type o-ring. changed my oil 25 times and sold it at 128K. Never had one problem. Has anyone tried or thought of switching to a simple rubber o-ring instead of a multi-layered-multi-colored-blue washer?
    Would Toyota have a fit if they ever saw a rubber o-ring?
    Finally, does anyone know why Toyota changed to the flat washer that has to be changed every time? is it a money grab? Toyota OEM washer was $1.80. If it costs .07 cents to make, then it's a money grab that's now a consumable.
  4. Mar 3, 2025 at 2:33 PM
    #184
    AZBoatHauler
    So.Arizona
    If consumable parts were a money grab for them I don’t think you’d be able to pick up an OEM filter at Walmart for $7. Install a fumoto valve and never deal with a drain plug or washer again.
    Mr Rick likes this.
  5. Mar 3, 2025 at 2:54 PM
    #185
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    "Do you change your own oil..."
    ABSOLUTELY!!! The kid on the dealership's lube rack is not putting his dick beaters on my drain plug, filter, or splash shield bolts only to over tighten, cross thread, strip out or otherwise screw up something... Have always done all my own maintenance or repairs. I do save all receipts and document everything just in case push comes to shove over a possible warranty issue. Warranty issues I seek out the main Master Diagnostic Tech at the service department and make sure it fits in his schedule.
    ScottieBones, Mr Rick and Raven67 like this.
  6. Mar 3, 2025 at 4:42 PM
    #186
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yep. Have since 1986. Over 200 engine oil changes with my own hands. Never a too tight oil filter. Never a stubborn drain bolt (though I've used Fumoto valves now for 15+ years).
    Mr Rick and AZBoatHauler like this.
  7. Mar 3, 2025 at 7:50 PM
    #187
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    64mm is perfect like this one - https://www.oreillyauto.com/detail/c/pennzoil/pennzoil-oil-filter-wrench/pen4/19906
    it fits the filter perfectly and you use your 3/8” drive ratchet. Better than any of the other ones IMO.
    Raven67 likes this.
  8. Mar 4, 2025 at 11:35 AM
    #188
    ArcticEd
    ArcticEd New Member
    Jacksonville
    '24 Plat Hybrid Crewmax 6.5 CSM
    I ended up ordering the Motivix wrench 64.3mm, and I got a Lisle 63600 in case that doesn't work. I'll try them on Friday & we'll see.
    Someone asked if the dealer changes the crush washer - i know they did on mine. I bought a dozen of the washers with the blue coating at the same time I bought a dozen OEM filters. The washer they put on didn't have the blue coating, it was a cheaper version.
    22whatwedo[QUOTED] likes this.
  9. Mar 8, 2025 at 1:19 PM
    #189
    ArcticEd
    ArcticEd New Member
    Jacksonville
