Best Oil for 5.7
Discussion in 'Performance and Tuning' started by apbreaux, Feb 25, 2021.
  1. Apr 25, 2021 at 8:58 PM
    #181
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I had one on my old 6.0 diesel for years without an issue. However, if the oil pressure on the 6.0 fades, the engine will not run.
    I do have one, along with skid plates, to install on my next oil change.
  2. May 6, 2021 at 10:02 AM
    #182
    Old.Ski.Bum
    Old.Ski.Bum New Member
    Paul
    2021 Luna Rock TRD PRO
    For the folks using the Fumoto, did you use a crush washer when installing the Fumoto? I had on on my FJ but I don’t remember if I did! Thanks!
  3. May 6, 2021 at 10:06 AM
    #183
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    If I remember correctly it came with one.
    Neo258 likes this.
  4. May 6, 2021 at 10:27 AM
    #184
    Old.Ski.Bum
    Paul
    Mine came with the valve and the plastic piece, no washer. Thanks!
  5. May 6, 2021 at 10:35 AM
    #185
    AZBoatHauler
    So.Arizona
    I used a standard Toyota blue drain bolt washer when I put mine on.
    I just switched from 0-20 to 5-30 at 55k miles. :anonymous:
    Leo's first and 15whtrd like this.
  6. Jun 8, 2021 at 11:10 PM
    #186
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I just used the leftovers out of four different 5 qt jugs of various weights from various brands, and then some leftover quarts I had in the garage. It only came up to 7 quarts so I just used 1.5 quarts of the oil I just drained out to top it off.
    I pulled the filter and blew it out with an air compressor and stuck it back in.
    You think I'll be good for another 25k miles?
    CopFiveO and NWPirate like this.
  7. Jun 9, 2021 at 1:13 AM
    #187
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I switched to 5w-30 Summer and 0w-30 Winter, Castrol GTX Magnatec at 75,000. Been working like a champ. Changed every 5,000 miles using my EZ Drain Oil Pan plug and Jowett performance oip filter housing with Toyota filters. Oil comes out just a hair darker then it goes in. This was not the case when I bought it used with 69k miles on it. So far the Castrol has cleaned up the valvetrain pretty well and the 5w quiets it down a tad....
  8. Jun 9, 2021 at 7:43 AM
    #188
    crewmaxlmt
    scott
    I heard that if you add a quart of ATF, it will clean the sludge out. Make sure that it is Amsoil though, it's approved for everything.
  9. Jun 9, 2021 at 9:38 AM
    #189
    OnespeedTRD
    Don
    San Diego
    On it!
  10. Jun 10, 2021 at 8:03 AM
    #190
    2mchfun
    Actually, it would probably run for quite a long time. Maybe not the best idea, and some excessive wear would likely occur, but as long as it didn't drop to say around 4.5 quarts I'm almost certain it would continue to run. I personally had a beater once with a blown rear main seal, ran 90w gear oil so it wouldn't leak out so fast to avoid clutch slippage. Ran for a few thousand miles like that until the lobes on the camshaft were nearly gone. Fun experiment!
  11. Jun 10, 2021 at 8:30 AM
    #191
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Castrol Edge full synthetic / 5-30 weight with liquid titanium.
    The stuff does not change viscosity even on hot days of stop and go traffic.
    Guaranteed one year oil changes safely.
    Good pricing on Amazon.
  12. Jun 15, 2021 at 7:29 AM
    #192
    Bammer
    Monroe, CT
    I would only run the engine for an hour, without driving, drain and refill with a full compliment of oil flavor of choice.
  13. Jun 22, 2021 at 5:13 PM
    #193
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    I wonder if you can buy an oil cap that reads “5W-30”?
    mtkey, Abos, jordoncloutier and 2 others like this.
  14. Jun 22, 2021 at 5:27 PM
    #194
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    I like valvoline and exxonmobile
  15. Jun 22, 2021 at 5:30 PM
    #195
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I look at motor oil the same way as lubricating oil for a firearm.
    When asked what the best oil for an AR-15 or M4 was the late, great Pat Rogers answer was simply: “Yes”.
    The point being you keep the machine well lubricated and do it frequently. Most any modern motor oil that meets API standards or brand standards is amazing compared to what you could buy even 20 years ago. Motor oil is largely motor oil if you are changing it every 5K. I would rather change oil every 5K miles with a basic oil that meets Toyota standards than use an expensive extended life oil and run it for 15K miles.
    With this in mind I run Mobil 1 Synthetic usually because I can buy 5qt jugs for a reasonable price, and use a Mobil 1 filter because I like the screw in drain plug in the kit. Then I change the oil approximately every 5K miles +\- 500 miles.
    Quantity has a quality all of its own.
  16. Jul 4, 2021 at 9:34 AM
    #196
    Unclebuck
    Unclebuck New Member
    2018 Crewmax SR5 TRD Offroad
    As an amsoil dealer - I agree with the rationale that any oil that meets the requirements and is changed every 5k will be sufficient. I use amsoil because I make enough profit while still discounting pricing to friends and acquaintances to pay for my tundra and ducati lubricant changes.
    CopFiveO and WILLINH like this.
  17. Oct 19, 2022 at 2:52 AM
    #197
    Cerebus
    Cerebus New Member
    Philip
    2011 Tundra TRD RW/DC 5.7L, Magnetic Grey
    TRD SuperCharged, Rock Sliders, SkidPlate, 5100's Front, Add-a- Leaf rear, Bedliner, ToolBox.
    I have been running Mobil One 0W-30 year-round. Wyoming winters get to -20F, and summers to 100F. My 2011 Tundra 4wd is TRD Supercharged, and I tow a travel or utility trailer at times... hills, higher elevation, 70 to 80mph speed limits, and some off-roading. I get oil analysis by Blackstone labs and change oil at 7,000 mile intervals. The owner's manual does include a statement that covers using a higher viscosity if conditions require.
    CallsignKodiak likes this.
  18. Oct 19, 2022 at 6:06 AM
    #198
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Tried them all and about 2 years ago i was going to pull a large camper. In the middle summer from florida to Pennsylvania. Iran castrol gtx classic 20w50. Smooth quiet no issues to and from. I been running it now over 36k miles changing at 7k. Still getting 14 mpgs with a 275 75 20. 2015 tundra 278k on the clock.
    CallsignKodiak, WVI and Hoff like this.
  19. Oct 22, 2022 at 8:52 PM
    #199
    Robster80
    Robster80 New Member
    I used Pennzoil Ultra 0w20 this last oil change. Engine seems noisier than it did with the Mobil1 AFE. Thinking of going with 0w30 or 5w30 next change to see if theres any difference
  20. Feb 24, 2025 at 2:59 AM
    #200
    59nascar
    59nascar New Member
    Mark
    2016 CM SR5 5.7 4x4 SB
    Aftermarket Wheels, 33x12.5" tires, suspension lift upgrade, aftermarket high flow intake system, exhaust system.
    So does Brutus and Popeye
  21. Mar 7, 2025 at 8:35 AM
    #201
    mtkey
    mtkey New Member
    2019 Voodoo Blue TRD Pro
    Interesting to read through this debate a few years after the flurry of discussion happened. I worked at the Toyota plant in AL for a few years where the 5.7 was built. During final leak test operations, the oil pan was filled with 5W30 through the fill neck and spun through its test cycles, which took ~30 seconds an engine. Simulated idle, a few rev-ups, a sustained run period at ~3000rpm, back to idle, off. Every component that oil is distributed to in real-world operation was pre-oiled during assembly (also with 5W30 to my knowledge), so nothing was dry when the test ran.
    With this knowledge and living where I do in the north AL area, I run Mobil1 5W30. Walmarts by me almost always have the 5qt jugs on sale for $23-$26 a unit; I have yet to see 0W20 on sale. I use a Toyota OEM oil filter and change every 5k miles. Could I go to 6k or 7k? I'm sure I could, but I'm content spending a bit more on oil changes over the life of the truck. I've racked up 20,000 miles on my truck in my 7 months of ownership, largely 100-mile trips for work, but also take many sub-10 minute trips around town (and around the jobsite) during the week. I agree with a previous comment made that any regularly-changed lubricant is better than no lubricant. 5W30 has treated the motor just fine - interestingly, the oil pressure gauge on my 2019 now fluctuates with throttle and oil temp, where it used to sit right in the middle with 0W20 regardless of motor load. I anticipate no issues for the remainder of my ownership.
    Oey12, B.Ross and AZBoatHauler like this.
  22. Mar 8, 2025 at 7:43 AM
    #202
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    The past 3 years have used Royal Purple, I only drive the Tundra on the weekends and barely put 3k miles on it per year.
    I do one oil change a year, I used to drive a supercharged car and liked the way Royal Purple kept the oil temperatures down.20221126_164606.jpg
