  1. Mar 6, 2025 at 11:48 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
  2. Mar 6, 2025 at 11:50 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Looks Awesome, but, I would rather not spend $1500 on a HU...it was my plan when they were found for like $500+ but I'll be happy enough with the factory...mostly because it's too late :duh:
    Tripleconpanna, BR73 and JMGmanAZ like this.
  3. Mar 6, 2025 at 11:59 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    This Dasaita was around $650
  4. Mar 6, 2025 at 12:37 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    For those that go to aftermarket, what about the vehicle menu you have on the factory units? Still possible to get there and set things like maintenance reminders and whatnot?
  5. Mar 6, 2025 at 1:30 PM
    centex
    centex New Member
    I know my Sony with the maestro rr doesn’t let me use the factory menus.
  6. Mar 6, 2025 at 2:46 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Thank you, sir. I'll have one when they drop.
    Tripleconpanna and RobertD like this.
  7. Mar 6, 2025 at 2:52 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Not available on my jvc 10”. Can still access menu for door setting and light settings. No maintenance reminder though.
    I keep my own log so if im uncertain boit when the last time something was done, i just look at my log book.
    HulkSmurf14 and 00h2itr[QUOTED] like this.
  8. Mar 6, 2025 at 3:31 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    My Pioneer w/ Maestro RR lets me get to several of the settings
    HulkSmurf14 likes this.
  9. Mar 6, 2025 at 3:35 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    What gives. I dont think this is because I go off-road occassionally... installed may 2022 and have put 30k miles on them
    all 4 have these cracks along 60% of the shoulder blocks.
    Florida AF and HulkSmurf14 like this.
  10. Mar 6, 2025 at 3:38 PM
    Tundra family
    Tundra family New Member
    Chunking, might need to check the toe
  11. Mar 6, 2025 at 3:40 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    will do, but also more of the cracks. the chunking i can attribute to off roading. all 4 are like this though, even the rears.
  12. Mar 6, 2025 at 5:11 PM
    SAGE63
    San Diego County
    I assume you do rotate your tires. So all tires should have this
    Tripleconpanna and HulkSmurf14 like this.
  13. Mar 6, 2025 at 5:30 PM
    HulkSmurf14
    2014 Tundra Limited
    You will lose the OE Maintenance reminders with aftermarket...at least, ones illustrated with icons...your CEL will flash for oil changes, but nothing else...
    00h2itr[QUOTED] likes this.
  14. Mar 6, 2025 at 5:56 PM
    justcuz
    justcuz 2.5 Gen Member
  15. Mar 6, 2025 at 7:08 PM
    rbgqxk
    rbgqxk New Member
    1. Swapped out chrome pieces for cement pieces.
    2. Discovered Toyota randomly has two different tab systems for their emblems.
    3. Bought an "OEM" and "radar compatible" emblem with the correct tabs on eBay and quickly learned that I was swindled when the PCS light started coming on.
    Any suggestions on the best place to buy a legit OEM emblem? I believe the part number that I need is 90975-02159. New grille requires the tab pattern with a single screw rather than the pair of self-destructing grippy washers that came on my 2019 SR5.
  16. Mar 6, 2025 at 7:12 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    x2
    Well the above plus a wireless CarPlay dongle, and I've been more than happy w/the setup... :fistbump:
    HulkSmurf14 and 00h2itr like this.
  17. Mar 6, 2025 at 7:15 PM
    Tripleconpanna
    Brand??
  18. Mar 6, 2025 at 8:54 PM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    What head units support front and rear cameras? I'm picking my 2021 SR5 DCLB up tomorrow and a head unit with front camera support would be nice. Better audio is a plus, what's a good moderate range speaker upgrade? I'm not into crazy good audio but wouldn't mind upgrading. Also any tips for sound dampening?
  19. Mar 6, 2025 at 8:56 PM
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    Is the new Tundra gonna have the JBL system?
    I have front and rear facing cameras in my 07 using the kenwood excelon DMX908s headunit.
    Front camera is mounted in the front bumper right above where my license plate used to be, and the rear I used a factory tail gate handle replacement from mastertailgaters.com because my truck didn't come with a backup camera.
    You should be able to retain the factory backup cam with most new radios if using the proper harnesses.
    Also added the vehicle gauges feature with the maestro rr module.
    Congrats btw!!
  20. Mar 6, 2025 at 9:10 PM
    TheMuffinMan
    Idaho
    2021 DCLB SR5
    Pretty sure it's not JBL. Thanks!
  21. Mar 6, 2025 at 9:13 PM
    Black Beauty 5.7
    Cannon
    Depending on how much your wanting to spend, there's tons of options for speakers and amplifiers.
    I went crazy and replaced everything with an audiofrog GB series 3 way, audiocontrol D-6.1200 and LC-1.1500 amplifers as well as two 10" alpine S2 subwoofers in a foxacoustics under the backseat ported box.
    If you have any idea on how much you might be willing to spend on the system, I could try to give you some recommendations :)
  22. Mar 6, 2025 at 9:45 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :popcorn:
    French Avocado and RobertD like this.
  23. Mar 7, 2025 at 2:25 AM
    Bergy24
    Bergy24 New Member
    I have this setup too and agree that its enough. The amp/sub made a huge difference and I am very happy with the results.
  24. Mar 7, 2025 at 3:20 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    They saw what I was buying from them, and then just ripped it off. Simple as that.
  25. Mar 7, 2025 at 3:50 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
  26. Mar 7, 2025 at 4:41 AM
    Tundra family
    Thanks for this heads-up, guess it's time to upgrade the sway bars.
    Edit: 31% off and free shipping :yes:
    Definitely appreciate the heads up.
  27. Mar 7, 2025 at 4:45 AM
    TimmyT
    TimmyT New Member
    Timothy
    Dothan, AL
    16 Tundra Limited, Crewmax
    Leveling Kit
    yeah, I was non-JBL. If you’ve got JBL it’s a much bigger ordeal.
    ZPhilip[QUOTED] likes this.
  28. Mar 7, 2025 at 4:52 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    you're welcome
  29. Mar 7, 2025 at 5:26 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Yeah, the OEM Audio+ setup in my non JBL ‘16 is great. They sell a kit for the JBL trucks, but it’s very different.
  30. Mar 7, 2025 at 5:38 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    He does sell a supplemental amp that pairs with the JBL setup that really helps too.
    HulkSmurf14 and Ebrperk like this.
