Anyone using a higher viscosity oil in their Tundra?
Discussion in '3rd Gen Tundras (2022+)' started by LionsFan20, Mar 6, 2025.
  1. Mar 6, 2025 at 1:35 PM
    LionsFan20
    LionsFan20 [OP] New Member
    Josh
    24 Tundra
    Just like the title says, anyone using say maybe 5W-30 instead of 0W-20. Just asking, see what people think/use....
    dJunior likes this.
  2. Mar 6, 2025 at 1:37 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Shit, crazy, surprised no one has asked this question before?!!
  3. Mar 6, 2025 at 1:39 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    There's like 100k+ threads about this available to go read through
  4. Mar 6, 2025 at 1:44 PM
    LionsFan20
    Josh
    24 Tundra
    Well to be fair, I was specifically looking at 3rd gen owners.
  5. Mar 6, 2025 at 1:47 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    Ahhh, well then probably only about 10k threads, haha.
    "Oil"and "what size tire fits" threads are the most by far!
    Put it the search feature. You'll find more reading than you'll care to do
  6. Mar 6, 2025 at 1:49 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    And for the record, I'm a 5w-30 user
    OHwendTrd and FrenchToasty like this.
  7. Mar 6, 2025 at 4:05 PM
    Zebjones24!
    Zebjones24! New Member
    2024 Red Tundra trd
    I hate the way people treat you on this forum just for asking a question! Like you got time to read through all these threads. Plus it’s a pain to search. Sorry for the reaction.
  8. Mar 6, 2025 at 5:23 PM
    Retroboy1989
    Northern Utah
    I poked around and didn't see any specific to third Gen. (Because they are drown out by the 1.5 million threads about this in the 5.7).
    On the 5.7, it was confirmed that the same engine called for 5w30 in other markets. The 2012 owners manual even suggests running a heavier weight if you are working the truck hard.
    I am also curious what folks have to say about 5w30 in 22+ v6.
    Carolina Peej and Kerplunk like this.
  9. Mar 6, 2025 at 5:55 PM
    Retroboy1989
    Northern Utah
    From the 2012 5.7 manual:
    "An oil with a higher viscosity (one with a higher
    value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions."
    The 3rd Gen manual doesnt make the same comments that the second gen did about 0w20 being recommended, but that 5w20 was acceptable for an oil change.
    I'm mostly convinced it's all epa nonsense and 5w30 would serve better.
    There is the question of warranty though...
  10. Mar 6, 2025 at 6:21 PM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    When you search you also have the option of using advanced search and filtering only on the 22+ forum. I only use 0w20 because that’s what Toyo recommends.
  11. Mar 6, 2025 at 6:23 PM
    JDAZ
    JDAZ New Member
    I use 0W-30
  12. Mar 6, 2025 at 6:32 PM
    bailey bulldog
    bailey bulldog New Member
    I'm going to try some euro 5w-30 in about 800 miles.
    Rodtheviking and Tundra family like this.
  13. Mar 6, 2025 at 6:45 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    It's a Josh thing.
  14. Mar 6, 2025 at 7:10 PM
    turbohardtop
    turbohardtop New Member
    I think if you are going to push the engine hard with towing or adding boost, it would be good to run thicker oil. For example, stock GTR runs on 5w40 while built engine, 15w50 oil is recommended.
  15. Mar 6, 2025 at 7:37 PM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    "Euro" oil in a "Japanese" truck???
    Retired...finally likes this.
  16. Mar 7, 2025 at 3:24 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Euro rates oils have a higher standard. They are typically thicker rated even in the 0W20 flavors. Our oils are thinner to keep the fuel economy nazis happy. I can guarantee you that the same engine in other countries will say to use 5, 10W30,40 or even 50.
  17. Mar 7, 2025 at 3:30 AM
    Tundra family
    Tundra family New Member
    Not to mention we can only discuss so many things before we end up talking in circles. It doesn't hurt anyone to just answer a simple a question and let the thread disappear into history.
  18. Mar 7, 2025 at 3:33 AM
    Tundra family
    I ran 5w30 on the last 2, on the next one I'm going back to 0w20 and adding half a qt of Lucas. My truck works pretty hard with a 1400lb camper on it full time.
  19. Mar 7, 2025 at 6:41 AM
    LionsFan20
    Josh
    24 Tundra
    I think this the way I will go as well.
  20. Mar 7, 2025 at 7:29 AM
    DRP
    DRP Old Member
    Dave
    I went straight STP on my last change. Seems to be ok. Does take a while to pour in 7.7 quarts though......
  21. Mar 7, 2025 at 7:41 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I used 5/30 for a bit before the engine recall...no noticeable difference. Only used it because its what I had on hand from previous cars
  22. Mar 7, 2025 at 7:46 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Lucas is nothing magical. All you’re doing is thickening the oil. Run the 5W30 if that’s the case.
    aj350925 likes this.
  23. Mar 7, 2025 at 7:55 AM
    Tundra family
    I have a couple quarts laying around that I got for dirt cheap, might as well use it. What I want to do is a sludge flush but I don't really trust the additives like that
  24. Mar 7, 2025 at 11:44 AM
    dJunior
    dJunior New Member
    CT
    I will be switching to 5W-30 after my last freebie Toyota oil change- there was a page from the international LC 300 manual posted that show these engines can run 0w-20 to 10W-30
    Amazing how many mfg do that for international stuff.
    I'd likely run Penzoil Ultimate Platnium and a synthetic blend Purolator filter.
    Also this video is pretty ineteresting- says that these light oils are truly just CAFE stuff and not for engine longevity:
    https://www.youtube.com/live/mr07y1H3U7c?si=ceczbwMp-BWg7jDx
  25. Mar 7, 2025 at 4:56 PM
    Retroboy1989
    Northern Utah
    I'm sure Toyota designed this engine with the plan to run 0w20. It would be great to talk with a Toyota engine engineer about oil and learn if it's all about economy or if 0w20 does protect as well as 5w30.
  26. Mar 7, 2025 at 5:30 PM
    Pine_Cone67
    2024 Tundra Limited
    With all the engine drama we have going on it seems like last thing we need is to trust forum experts who think oil viscosity listed for our truck is just for EPA compliance. You believe what you want; I’m sticking to the oil spec listed in the manual and the only revision I’m willing to introduce is more frequent oil change intervals (every 5,000 miles).
    kirkb, Tundra family, Kap1 and 2 others like this.
  27. Mar 7, 2025 at 7:17 PM
    LionsFan20
    Josh
    24 Tundra
    But as dJunior said this motor is said to be running 10W-30 in other parts of the world….why would that be?
  28. Mar 7, 2025 at 10:24 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    Cause America! American Tundra's can only be run on 0w-20. Because the manual says so. The manual for American market Tundras is like the Bible. And Toyota engineers are Gods. And we must obey the Gods or we will face the their wraith and the world as we know it will face destruction unlike anything we've ever known. Or at least your engine will. But remember, those same Gods also developed the 3.4 twin turbo engine that will probably blow up anyway. So, you know, there's that. But, anyway, appease the fanboys Gods!
    OR, be like me and laugh in the face of the EPA, the Gods, the oil fill cap, and the manual fanboys everywhere, and watch that beautiful, smooth, thick, liquid gold come pouring out of that 5w-30 container 8.5 times every 5k miles!
  29. Mar 8, 2025 at 9:59 AM
    Retroboy1989
    Northern Utah
    7.7 times?
  30. Mar 8, 2025 at 10:06 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    5w30 is water, too. Diesel-grade 15w40 conditioned overnight in cold garage with no heating is what every engine likes. Some BMW punks go to 20w50, but that's a waste of money.
