End links wrong bushings ordered?
Discussion in '1st Gen Tundras (2000-2006)' started by Khunter0211, Mar 6, 2025.
  1. Mar 6, 2025 at 11:25 AM
    Khunter0211
    Khunter0211 [OP] New Member
    '05 DC Limited V8/4WD
    I’m Trying to install new end links. I ordered OEM end links and bushings. But I’m not sure if I got the right bushings. I ordered four 48817-0C010.
    Based on the attached image, they sent me type B ( Circled in blue) with the washer built into the bushing. Do I need to return these and get type A (Circled in red) with metal washers and bushing separate?
  2. Mar 6, 2025 at 12:10 PM
    Dakillacore
    Georgia
    Here is a larger Diagram from the Toyota system that I use and the torque specs for you.
    On the bushing, I'm not too qualified to answer this question, but from my little bit of research I think that this may be the correct bushing part number. Call the parts department to verify before ordering as I am not 100% sure.
    48817-30010
  3. Mar 6, 2025 at 1:36 PM
    Khunter0211
    Thank you, I did call and they said either will work. But they did say to check what the old one looks like to verify. The old one is aftermarket and not OEM but they did have washers.
    After a second call to Toyota. Based on my vin they said I bought the right bushing.
