  1. Mar 6, 2025 at 2:01 AM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    Anyone running the new Konig Hyper Trail wheel. I believe they also manufacture wheels for FN too. Flow Forged with a max load of 2500 at only 24 lbs.
    I like that they have their version of the bead grip. The knurled bead seats on Konig HyperTrail wheels firmly lock onto your tires.
    Wheel specs
    Wheel Diameter (in.):17
    Wheel Width (in.):8.5
    Bolt Pattern / PCD:6X139.7
    Offset (mm):-6
    Wheel Centerbore (mm):106.1
    Wheel Finish:SATIN BRONZE
    Max Load:2500
    Wheel Weight (lbs.):24.04
    Construction:FLOW FORMED
    Tlar25, shifty` and KNABORES like this.
  2. Mar 6, 2025 at 4:56 AM
    Dakillacore
    Georgia
    The headlight/side marker set has finally shipped. I plan on doing that LED projector light modification to it when it comes in. The LED's will come in on Monday and the Headlight set on Tuesday.
    Unfortunately, the LED's that JDM Driveway suggested are discontinued. I tried googling them and using image search and still nothing other than some Alibaba links/Ebay. Hopefully the one's that I picked up will be good.
  3. Mar 6, 2025 at 5:30 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I browsed those (projectors?). let us know how they work out :thumbsup:
    My lights pretty much suck, good thing I don't drive when it's dark much.
    Dakillacore[QUOTED] likes this.
  4. Mar 6, 2025 at 5:32 AM
    Dakillacore
    Georgia
    I got you.
    The reviews seemed alright. The biggest con is that the high beams just throw light instead of projecting a beam. But, with LEDS like this I doubt that I will even need the high beams.
  5. Mar 6, 2025 at 5:44 AM
    shifty` Oh, I have felt Cobain's sarcoma
    The ones you pictured appear nearly identical to the Braveway bulbs I got, and the CO projectors others got.
  6. Mar 6, 2025 at 6:26 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If you have the ones that don't have built in resistors and also led fog lights without resistors, you may need to buy a set to plug into headlights. I just needed one. Otherwise the brights will come on instead of the fog lights.
    My Amazon led fogs with the CoLight LED headlights is actually better than their bright beams (without fogs). Someday I'll figure out how to manipulate the relay for fogs anytime for an 03-06.
    https://www.amazon.com/Xprite-Headl...919-4fd1-9d31-f6d6f5af4b08&pd_rd_i=B07SGCHF5B
    tpope likes this.
  7. Mar 6, 2025 at 6:54 AM
    Dakillacore
    Georgia
    I just had to do some digging to see if it had resistors and it looks like it does, but there are some reviews that bring up the high beam/fog light issue that you said. So, I just put in the order for that part you linked. Thanks for that very much. You probably just saved be from a few choice cuss words and inexplicable anger. :cheers:
  8. Mar 6, 2025 at 8:35 AM
    I didn't need to use resistors on my '06. Fogs, high beams, all work OK.
  9. Mar 6, 2025 at 9:36 AM
    Dakillacore
    Georgia
    That's good news. I'll try it by itself first and if it works then I'll just return the resistor pack.
    455h0le_dachshund likes this.
  10. Mar 6, 2025 at 1:37 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Look at who I ran into. @butt_weiner
  11. Mar 6, 2025 at 2:46 PM
    asspoodle
  12. Mar 6, 2025 at 2:54 PM
    Dakillacore
    Georgia
    Man, I do love that damned TOYOTA grille. At first it was iffy, but the more that I see it the more I like it. It's added on my "to-buy" list.
  13. Mar 6, 2025 at 3:14 PM
    Rearend_hotdog
  14. Mar 6, 2025 at 3:16 PM
    Just so you know, if you tag who ever, post it, then go back and erase and add whatever you want @azz_dog_lover
  15. Mar 6, 2025 at 3:19 PM
    @dog_azz_lover
  16. Mar 6, 2025 at 3:22 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  17. Mar 6, 2025 at 3:25 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It's perfect for black trucks. But also looks great paint matched if you got the coin or the skills. The black grill on non-black trucks is ok sometimes,. Other times it looks gross
  18. Mar 6, 2025 at 4:01 PM
    Dakillacore
    Georgia
    You're right. The truck color really does dictate how good it looks.
  19. Mar 6, 2025 at 4:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  20. Mar 6, 2025 at 5:25 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    FrenchToasty and khooiii like this.
  21. Mar 6, 2025 at 5:37 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    this. My nova, all the love & care to get it running great to leave me stranded twice. I broke down, but as soon as i got it started again after the 4th or 5th jump; i lost my shit. It was raining, and i burnt through a whole pair of 245/60r16’s over a coupla minutes of flat foot burnout, rev limiter wailing. I have started & driven it since, but havent registered it. I mighta been sobbing. I realized i wasnt about that life of having a street legal racecar. I wasnt gonna wanna climb through a roll cage everyday.
    I was never going to be ‘icyhot’. Still haunts me. Not in a self harm kinda way, but evertime i look in the mirror, i remember when i killed that dream.
    but i can still be stuntman mike. Just keep the deathproof fast stuff to motorcycles.
  22. Mar 6, 2025 at 7:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No Banjo, no Diddy.
  23. Mar 6, 2025 at 7:36 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    #safefromdiddy
    bmf4069 likes this.
  24. Mar 6, 2025 at 7:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I still like your dirt circle track idea for the nova. Personally I think it deserves to be restored into a street able racecar. But a dirt race car is still super cool and beats sitting there lifeless. I would just hate to see it turned into a golfball after a handful of races.
    Someday, I want to build a dirt track race truck. Elvira would be perfect with a bigger engine and a manual
    The Black Mamba likes this.
  25. Mar 6, 2025 at 7:52 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's Reverend Hotdog, to you. :burp:
    bmf4069[QUOTED] and FrenchToasty like this.
  26. Mar 6, 2025 at 7:59 PM
    Sweet set of FJ wheels for sale cheap
  27. Mar 6, 2025 at 7:59 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :eek: anthracite!! Super rare version of the fj trail teams. Personally, I prefer the black ones. But I'm black and proud. :D
  28. Mar 6, 2025 at 8:22 PM
    More
    Tlar25 and Dakillacore like this.
  29. Mar 6, 2025 at 9:02 PM
    Hotdog water
  30. Mar 6, 2025 at 9:11 PM
    Looking at some seats for Donut. I'd like to get some 1st/2nd gen SHO seats with the adjustable bolsters, but I seriously doubt I'd find some. Recaros and Corbeaus are way too pricey at around $1200 a piece, and Sparcos are $450 a piece. Plus shipping on those. I may just settle for these:
