The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Feb 13, 2025 at 9:13 AM
    #1921
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You won't even JSON-spec. Your feedback cannot be trusted.
  2. Feb 13, 2025 at 9:23 AM
    #1922
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The json-iest of json-spec options :rofl:
    BiggHertz[QUOTED] and RobertD like this.
  3. Feb 13, 2025 at 9:24 AM
    #1923
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :fistbump:
    BiggHertz, Mater and RobertD like this.
  4. Feb 13, 2025 at 9:39 AM
    #1924
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    TRDFerguson[OP] likes this.
  5. Feb 13, 2025 at 10:14 AM
    #1925
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Did you do a backing plate or anything like that under the bed to reinforce where the l-track attaches or is it just bolted to the bed floor?
  6. Feb 13, 2025 at 10:44 AM
    #1926
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Nah, just sheetmetal screws into the bed... jk, jk. They're just through-bolted with stainless machine screws, but there are holes every 6" or so and should be good to hold things down in just about any situation. There isn't a lot of room to work between the bed and frame in a few spots.
    Mater, helidave[QUOTED] and RobertD like this.
  7. Feb 13, 2025 at 3:31 PM
    #1927
    Azblue
    The Dirty T ( ^_^)_且
    I would've just used some drywall screws. I've got a shitload of those in a old coffee can in the garage.
  8. Feb 13, 2025 at 3:32 PM
    #1928
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    you would
  9. Feb 13, 2025 at 6:20 PM
    #1929
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That’s just lazy. At least use some of those plastic anchors that are rated for 5 lbs hanging strength.
    RobertD and Azblue[QUOTED] like this.
  10. Mar 5, 2025 at 7:19 PM
    #1930
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    New box of goodies showed up today. Now I just need a local vendor to call me back on REM polish for the gears and I can get this shit moving!
    1794TX, Azblue, RobertD and 3 others like this.
  11. Mar 5, 2025 at 7:51 PM
    #1931
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    you’re catching up to jimmy with your shelfware collection
  12. Mar 5, 2025 at 7:53 PM
    #1932
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Only because it all has to be installed at once… and not by me.
    Azblue, reywcms and BiggHertz[QUOTED] like this.
  13. Mar 5, 2025 at 8:00 PM
    #1933
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Just here for the reaming
  14. Mar 5, 2025 at 8:04 PM
    #1934
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  15. Apr 6, 2025 at 8:52 PM
    #1935
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Took a couple minutes to add an XLR jack to the blank parking sensor hole on the Ironman bumper, making hooking up the winch controller much easier. Still trying to source a dust cap that will actually fit, so let me know if you have any ideas there. The two I’ve tried on Amazon were a bust.
    Parts list:
    https://www.amazon.com/dp/B07V6TX284
    https://www.amazon.com/dp/B0CDNWQCCC
    I cut the cable in half and soldered the cut end to the jack, unscrewing the unused end to copy the wire positions.
    RainMan_PNW, reywcms, RobertD and 3 others like this.
