Oil consumption questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by us18188, Mar 4, 2025.
  1. Mar 4, 2025 at 2:07 PM
    us18188
    us18188 [OP] New Member
    Hello everyone and thank you for letting me join this group! I bought a 2019 Toyota Tundra Platinum Limited with 139k on it. Have never owned one before and have had it for 2 months-ish... I brought it to my local shop the other day and I was down 1qt and a half on oil. I have not towed anything, yet... I was also told by my Toyota Dealer that I should change oil every 10K? I do not smell burning oil but do these trucks burn oil like this?
    Thank you all and just hope I didn't purchase a bad truck.
  2. Mar 4, 2025 at 2:14 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    5k oil changes.
    And how did they determine you were a quart low? If they used the dipstick, that doesn’t tell you if you’re a quart low. It’s just there to let you know you have oil in the motor.
    WILLINH and us18188[OP] like this.
  3. Mar 4, 2025 at 2:16 PM
    AZBoatHauler
    So.Arizona
    This engine has a reputation of not burning a drop of oil. Usually the only reason they are low on oil is a leak or they were under filled.
    WILLINH, Terndrerrr and us18188[OP] like this.
  4. Mar 4, 2025 at 2:17 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Welcome :cheers:
    I wouldn't listen to them about the 10k. Best to just stick with 5k intervals and use synthetic only. In fact, best not to listen to them, they'll likely tell you that you never have to change your transmission fluid. Just start DIYing all of your own maintenance on your truck. Between this forum and YT videos, you'll know the in's and out's of your truck and won't have to rely on the stealer.
    For piece of mind, you should just do your own oil change right now regardless of what the dealer or your local shop told you. You'll sleep better knowing you did it right.
  5. Mar 4, 2025 at 2:23 PM
    Mr Badwrench
    Mr Badwrench New Member
    Is the inside of the exhaust tip oily, like actually oily and not just sooty? I would think if it were burning that much it would be pretty messy.
    us18188[QUOTED][OP] likes this.
  6. Mar 4, 2025 at 2:25 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Did you/they check the oil weeks before? If they're just going off of what they see right now then that doesn't mean much, previous oil change was probably just low.
  7. Mar 4, 2025 at 2:30 PM
    us18188
    This place is amazing. Thank you all! I have no idea how the local shop figured I was a Qt and half low, just what they said they added. It is going to the dealer this Friday to have a couple things done, TPM sensors replaced and such. I love the 5k oil changes. I can sleep better. I am so excited about this truck! Thanks again all of you!
  8. Mar 4, 2025 at 2:34 PM
    TacomaTRD4x402
    Southern California
    Make a proper introduction in the new member thread...and we like pictures :thumbsup:
  9. Mar 5, 2025 at 2:39 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    I'm thinking 10k oil changes can lead to oil consumption. If they said it used 1.5 quarts. You just need to do an oil change you or a trusted shop. Then after you personally check the oil make sure it's topped off. Then check it weekly to see what's going on.
  10. Mar 5, 2025 at 4:36 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Yep.
    I’m about to hit 200k on one of these engines, and I just checked the oil level last night. 4k miles since the last change, and it still reads at the same spot on the dip stick. This particular engine has wet cam towers on both sides, too.
    I stick with 5k changes and 5w30 oil
  11. Mar 5, 2025 at 2:43 PM
    JPinAZ
    JPinAZ New Member
    2020 SR5 4X4
    Good advise. Timing chains do not like 10k oil, change it before it gets low.
