1st gen tundra fender flare replacement; Access Cab TRD SR5
Discussion in '1st Gen Tundras (2000-2006)' started by TurdPro1006, May 22, 2021.
  1. May 22, 2021 at 8:49 PM
    TurdPro1006
    TurdPro1006 [OP] New Member
    Landon
    2003 Black Toyota Tundra TRD
    I can't find OEM replacement fender flares for my truck. Could anyone send links or any other help finding them.
  2. May 23, 2021 at 11:50 PM
    evilrb
    evilrb New Member
    Jeremy
  3. May 24, 2021 at 9:13 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    I second PSI. Had them on for a year and they are good quality.
    ThatYeti likes this.
  4. Oct 10, 2021 at 6:51 PM
    ThatYeti
    ThatYeti New Member
    2000 Tundra SR5
    Any chance you have pics to show how much they cover? Hoping to cover up some rust over one wheel arch.
  5. Oct 11, 2021 at 10:50 AM
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    Here you go.
  6. Oct 11, 2021 at 10:53 AM
    ThatYeti
    ThatYeti New Member
    2000 Tundra SR5
    Thank you, is that three inches +/-?
  7. Oct 11, 2021 at 10:54 AM
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    I think it is three inches.
  8. Oct 11, 2021 at 10:56 AM
    ThatYeti
    ThatYeti New Member
    2000 Tundra SR5
    Thanks
  9. Feb 19, 2022 at 3:08 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Didn’t want to start a new thread, but I’m in the same boat. The flares are badly faded on my 2001. I know I can throw some paint or Solution Finish on there to clean them up, but the gasket material is pretty cracked and the whole thing just looks bad. Outside of OEM, are there any bolt-on options like Bushwacker that will make use of the factory clips and not leave me with exposed holes? Aesthetically, I’d be just as happy removing the flares completely if it weren’t for the factory holes beneath….
    Edited to add: This was the other option I was thinking of: https://www.bushwacker.com/extend-a-fender-flares/2001/toyota/tundra
    8288BEE0-F089-4D93-93DA-99A6BE53D7D3.jpgE8A79E33-F635-44E4-B239-36B6CD6D055A.jpgD2487900-F830-4E66-84DC-F3E60AC0C019.jpg
    Anima likes this.
  10. Feb 20, 2022 at 4:53 AM
    Bubbadog
    Bubbadog New Member
    I have EGR fender flares on my 2001 Access Cab.
    Anima likes this.
  11. Feb 20, 2022 at 5:07 AM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Were they a swap for factory? If so, how bad of a chore was it? I appreciate the input.
    Anima likes this.
  12. Feb 20, 2022 at 9:14 PM
    Bubbadog
    Bubbadog New Member
    Yes they were. They were very easy to install. My 2001 AC had the narrow chrome wheel trim pieces from factory.
  13. Feb 28, 2023 at 1:34 PM
    Mhagha
    Mhagha New Member
    I just saw this post if you are still looking, the rubber seal that is cracked on fender flare is sold seperately. I just bought it and its about $20 Dealer. You can also use ceramic clay spray on flares to make them look shiny Or you can plasti dip them . I did one flare with plasti dip Gloss black and It came out awesome. What you do have to watch out for is the rivets that go in body for Front flares. There are 6 on each side with different size rivets!!
    If anyone needs the part #s 75395a-35040 67036 67037
    Anima and Mustanley like this.
  14. May 22, 2023 at 11:27 AM
    ibejammin2
    ibejammin2 New Member
    I am not a huge fan of the OEM bubble rounded flares on my 2000 TRD ... What other options are there out there to get something with a bit sharper lines? anything?
  15. May 22, 2023 at 11:33 AM
    Are you planning to fill the holes in the body panels where the current flares are mounted?
  16. May 22, 2023 at 2:56 PM
    ibejammin2
    Not if I can help it ... Was hoping there was an aftermarket flare option that would cover up the old mounting holes, but i am a novice with the first gen tundra, not familiar if there is anything out there ... If nothing exists, I might just spray the OEM ones with bedliner when i paint my winch bumper..
  17. May 22, 2023 at 3:03 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I'd double check, I think the 03+ flares have OEM holes but the earlier ones may not.
    Look up inside your bedside.
    shifty`[QUOTED] likes this.
  18. May 22, 2023 at 5:07 PM
    Definitely, and good point. I swear there are 3 flare types before the DC came out and added to that. Hell, if anyone knew, I'd expect @BubbaW to have the answer.
    Needless to say, not a ton of aftermarket bolt-ons for these trucks per-se, and folks have been interested in fender flares for what seems like an eon.
    If no stock holes, I would consider going with the version with chrome strips.
  19. May 22, 2023 at 9:40 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Non TRD most often has the little flare strips the thin ones.
    Non TRD can also have on occasion the non body hole flares that have a different shape and are paint matched even on SR5 trucks. @bmf4069 has these.
    TRD has flares with holes in the body to hold them. SR5 is non painted and Limited's have them paint matched.
    TX-TRD1stGEN and shifty`[QUOTED] like this.
  20. May 23, 2023 at 4:15 AM
    bmf4069 Captain wtf
    I'm not even sure what kind I have. I think the trd and limited ones are the same as mine, but mine are painted. Just not body color.
    Nope, just checked the photo page. TRD flares poke out more. Stole these from @TX-TRD1stGEN
  21. Mar 3, 2025 at 11:15 AM
    Anima
    Anima New Member
    2000 TRD Tundra V8 4x4
    I just came across this post looking for solutions on my faded fender flares for 2000 TRD Tundra. Do you have any photos of your plasti dipped ones? Did you take off the flares then paint? Or did you tape up the truck and then paint them?
    If anyone has recommendations for replacements, that would be great too. I came across the Bushwacker ones, but they look kinda pricey.
  22. Mar 4, 2025 at 11:00 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    Somebody needs to manufacture a color matched plastic snap in rectangular plug to hide those holes so people could throw away those stinking fender flares.
    All three of the first gen Tundras I have had came without the flares/holes, I wouldn't want it any other way.
  23. Mar 4, 2025 at 12:28 PM
    You don't need a square fastener to fit into a square hole. Look at the product they sell at BumperPlugs.com, and know you could get similar plastic plugs in bulk from scAmazon or similar, prep, and paint your own, then install into the OEM holes.
    Dook55[QUOTED] likes this.
  24. Mar 4, 2025 at 12:48 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  25. Mar 4, 2025 at 2:01 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    What I would want is something not much larger than the hole itself. The idea is to make the holes disappear rather than make them more noticeable. It's a shame they ruined so many trucks with those flare holes. When I bought 2 of my FGTs new, I had to go to a dealer 500 + miles away to get them without those flares because all Texas dealers forced them on us.
  26. Mar 4, 2025 at 3:17 PM
    I dunno, I've seen a couple pictures of trucks on FB groups doing what I've just described and it actually looks unexpectedly good.
