  1. Mar 1, 2025 at 1:58 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    No communication, nothing has shown up. They told me they wouldn't send me tracking but may follow up since they aren't confident in their inventory.
    I see the charge is still pending... We'll see!
  2. Mar 1, 2025 at 2:21 PM
    Weird perspective. Exact same tube.
    KNABORES[QUOTED] likes this.
  3. Mar 1, 2025 at 8:20 PM
    bdbrown528
    bdbrown528 New Member
    2002 Tundra Sr5
    Does anyone have any recommendations for bed bars for our trucks? I had some nice ones on my Taco but those all used the C-Channel to clamp down and these trucks don't have those integrated into the bed.
  4. Mar 2, 2025 at 8:45 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Nothing like a freak rainstorm when your truck has bare steel parts all over it. Someday I'll learn. 20250302_104034.jpg
  5. Mar 2, 2025 at 12:48 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I’ve got a dumb idea. Flat tow a pajero chassis with a popup camper mounted to it. Maybe use airbags for leveling. Short wheelbase, would fit in a 20x30 canopy. I can reverse a wagon, but not 2.
  6. Mar 2, 2025 at 1:41 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Hmm. Uhh say what?
  7. Mar 2, 2025 at 1:42 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    5d chess.
    tpope[QUOTED] likes this.
  8. Mar 2, 2025 at 1:50 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    DEEP!
  9. Mar 2, 2025 at 1:53 PM
    RohdeSoda
    RohdeSoda New Member
    2000 AC 4x4 Tundra
    I'm going to order some of these rolled edge clamps for my OEM CV boots, because I hate the style they come with (with a passion). I'm curious if any one knows the dimensions for the inners and outers? All I can seem to find is the 90-110mm for the larger outer clamp.
    So I'm looking for the dimension of the larger clamp on the inners, and then the dimension for the smaller clamp which should be the same for inners and outers?
  10. Mar 2, 2025 at 1:58 PM
    The dimensions (in mm) should be stamped directly on the clamp. Like this. Make a list of what yours are, and go from there.
  11. Mar 2, 2025 at 2:19 PM
    RohdeSoda
    2000 AC 4x4 Tundra
    Mine are a mess of grease and grime, and if I can avoid lifting the truck and getting dirty to spin the axles and clean them right now I'd like to. If nobody has the numbers I'll make due, but thought they might be handy somewhere.
  12. Mar 2, 2025 at 2:26 PM
    Should wipe off the band pretty easy, I definitely had to wipe mine clean for that photo. First thing to do is confirm you have an OEM axle. If not, it doesn’t matter. There are four clamps per axle. The outers are in that photo I shot. That’s two down, you’re halfway there.
    I’d need to dig back thru pics to see if I have pics of my inner clamps too.
  13. Mar 2, 2025 at 7:13 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Those sizes in my post are what I ordered and also premeasured by wrapping a string around IIRC. Inner 25-40 fit the axle OD outside the groove (larger boots extend beyond the axle groove). Can verify sizes with yours by looking at what is stamped on your OE clamps like @shifty` notes.
    shifty` and FrenchToasty like this.
  14. Mar 3, 2025 at 4:21 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    Saw this clean two tone this morning. Looked good.
    Tlar25, G_unit3000, Weagle and 7 others like this.
  15. Mar 3, 2025 at 4:21 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    $90k for a RC f150 with a Whipple? Dudes smoking meth. :laugh:
  16. Mar 3, 2025 at 4:24 AM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Cardboard spoiler :rofl: keepin in red neck, love it hahaha. What's the device on the roof/back of the cab?
  17. Mar 3, 2025 at 4:26 AM
    Dakillacore
    Georgia
    I think it was a big ass LED light.
    Sirfive and BroHon[QUOTED] like this.
  18. Mar 3, 2025 at 5:06 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    There's a ton of that dealer added black widow package trucks up here. They're all ugly as hell and the owners are exactly the tools that you'd expect to buy them haha. Really expensive package if I'm not mistaken.
  19. Mar 3, 2025 at 5:09 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    There's tons of racks out there. You can mix and match hardware from different brands. Max modular/kb voodoo has racks that you can select the clamp vs toyota rail. RCI, CBI, so many options, but basically any rack if you get the right hardware will work. I'm running some Billie Bars from a full size truck that I cut and re tapped the aluminum extrusions to fit. Depending on what you're planning on planning to put on them make sure your dynamic load rating is much higher than what you actually need.
  20. Mar 3, 2025 at 5:55 AM
    TWO TONE!
  21. Mar 3, 2025 at 10:47 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If you're in TX I know a guy in Columbus, TX that makes custom Toyota racks and bumpers and sliders. He used to call his stuff Derp Werx. But now goes by something more professional
    Weagle likes this.
  22. Mar 3, 2025 at 12:59 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    I'm preparing for a T belt job and will likely also do front crank seal, as I think it's leaking. In preparing for that... Is there one tool that will make removing both the crank pulley and the crank timing gear easy? I know there is a crank pulley holder tool, but I'm thinking I'm gonna need a puller for the crank gear too!
  23. Mar 3, 2025 at 2:49 PM
    bfunke
    bfunke Tundra Curmudgeon
    Damper will require a puller to remove. The timing belt pulley often but not always comes off by hand. If not you can try heat and some blaster. I seem to recall it has two threaded holes on front so you can use a small 2 bolt puller. Be careful not to mar or burr it or it may chew up the new belt. My Dewalt compact 1/2 inch impact was able to remove my crank bolt but the holder is required to properly torque unless you build a DIY bar to bolt to the damper. I hope your cam seals are good because they are a bitch on the VVT engines.
    PNW15 likes this.
  24. Mar 3, 2025 at 3:19 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Thanks for the words of wisdom. Maybe I can get a puller for both.
    This guy uses the same puller for both. And yea, I'll need a pulley holder for removal and reinstall of that.
    I have peeked in at my cam tower seals and they are thankfully not leaking.
    https://youtu.be/2-Px_yMBd6Y?si=hEOEo61cI3o37zRG
  25. Mar 4, 2025 at 5:11 AM
    Dakillacore
    Georgia
    Got a Rock Auto discount code in my email. Paying it forward for asking for one a few days ago.
    Code: 294198931260404775
    5% off.
  26. Mar 4, 2025 at 9:36 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
  27. Mar 4, 2025 at 1:50 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Ya, just finished watching this.
    As if rock warriors weren't expensive enough already.
  28. Mar 4, 2025 at 2:23 PM
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    No kidding. I've seen a set locally for like 600, but they were beat to crap
  29. Mar 4, 2025 at 4:22 PM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
  30. Mar 4, 2025 at 4:29 PM
    AmericanKing06
    New Mexico
    Yeah they are. I was hoarding 3 sets for awhile. Finally decided to sell the two 5 lug sets and I kept the 6 lug set. For 1st gen applications I think TRD PRO wheel would be best to achieve the biggest tire with no/ minimal lift. 17x7 +4 offset, I could be wrong.
    Tlar25 and FrenchToasty like this.
