22 TRD Pro / Heritage Grille Camera Mount Bracket
Discussion in '3rd Gen Tundras (2022+)' started by Brums, Apr 30, 2022.
  1. Feb 7, 2023 at 9:45 AM
    #421
    saleen079
    saleen079 New Member
    22 Tundra Limited TRD
    Lots of DIY stuff
    That would be great! Thanks.
  2. Feb 7, 2023 at 9:53 AM
    #422
    steelers559792
    steelers559792 New Member
    I didn’t hear anything but I would probably need someone to press for me to be sure because it’s in the passenger side by the battery. Did I do anything wrong in the wiring
  3. Feb 7, 2023 at 12:09 PM
    #423
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I don't have the wiring diagram for cali raised switches, otherwise I'd be able to help a bit more. If the relay doesn't click, then it's not wired correctly somewhere.
  4. Feb 11, 2023 at 6:01 AM
    #424
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    Where did you get the "tundra" in-lay on the front of your truck? And what color is it exactly?
    Thanks!
  5. Feb 11, 2023 at 6:41 AM
    #425
    steelers559792
    Different question. Does anyone’s Ali express light bar actually work. Wired mine to be on and skipped the switch and still wouldn’t turn on.
  6. Feb 11, 2023 at 9:44 AM
    #426
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    @eddiefromcali how did you attach the ABS tabs to the grill frame? Looks great!
  7. Feb 11, 2023 at 9:56 AM
    #427
    eddiefromcali
    Eddie
    100% Stock
    Self tappers
  8. Feb 11, 2023 at 10:23 AM
    #428
    KClav
    KClav MGM Limited
    Appreciate it. I think I’ll give it a try.
  9. Feb 11, 2023 at 3:34 PM
    #429
    saleen079
    Lots of DIY stuff
    chance12[QUOTED] likes this.
  10. Mar 18, 2023 at 6:26 PM
    #430
    Cheddafry
    Cheddafry New Member
    2022 Tundra Limited Crewmax
    For those of you who have upgraded from a TRD Off road (honeycomb) to the Heritage/PRO grille, would anyone be willing to sell the OEM camera mounting bracket from the honeycomb grille? Or happen to have a picture of that part number? i searched and can not find anything online.
  11. Mar 18, 2023 at 6:34 PM
    #431
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    I've got ones I designed .. 3D printed .. for sale if you're interested. $25 shipped .. check my thread below!
    https://www.tundras.com/threads/for-sale-trd-pro-or-sport-grill-camera-brackets.113612/
    Brums[OP] likes this.
  12. Sep 11, 2023 at 11:01 AM
    #432
    myerswoodshop
    myerswoodshop New Member
    2022 Toyota Tundra Platinum
    Yaboy likes this.
  13. Sep 18, 2023 at 7:40 PM
    #433
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Any tips. I’m stuck at the block…
  14. Sep 18, 2023 at 7:44 PM
    #434
    Ipaddick
    Ipaddick New Member
    Canada
    Anyone know how to disconnect th block heater? I can’t get the front off because of it.
    Yaboy likes this.
  15. Sep 18, 2023 at 8:48 PM
    #435
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    The disconnect is in the passenger wheel well you’ll need to open it up to unhook. Trace the block heater cord from the front to the wheel well not the block
  16. Nov 6, 2023 at 1:40 PM
    #436
    Bailey1794
    Bailey1794 New Member
    Houston
    2023 Smoked Mesquite Hybrid 1794 Tundra
    Diode Dynamics Ambassador & Talons Garage Affiliate (See Below for discounts) Use code Bailey for Diode Dynamic free shipping Current Build & Pics Instagram.com/Bailey1794 Discounts & Affiliate links below https://linktr.ee/bailey_1794?fbclid=PAZXh0bgNhZW0CMTEAAaYH-pwfNz76E_oAQekLat2ZdcSY0VrV7a8O3_UxaU15mlBifUGV3lGaU4s_aem_Aamyw5XakyTlp6h_WyGSA8wBSO-cFzK1Z0t3EQBBaXEgDCnQI49fSwGFqQNWOCNd5OxDNGhVrMYRcfs_DEuuCXSy
    Silly question but what screws did you use to mount it to the grill? My markers arrived but I didn't want to hack job it lol
    Is there a special part number I need for it or is there a screw I just jack from the old grill.
    ryanwgregg likes this.
  17. Nov 6, 2023 at 1:55 PM
    #437
    Bailey1794
    Houston
    You the Goat!!!
    ryanwgregg[QUOTED] likes this.
  18. Dec 28, 2024 at 2:37 PM
    #438
    Hammertimerrrr
    Hammertimerrrr New Member
    2024 MGM Limited OR
    Reviving old thread…
    is there any calibration needed for the camera? Given the camera sits lower on the grill of the pro grill vs TRD off-road I imagine the angle is different, or does the modified bracket (I have the one that came with the Rave kit) take care of that somehow?
  19. Dec 28, 2024 at 3:38 PM
    #439
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Seems to depend on the truck. Some have had issues, others have not. Kind of a crap shoot. I think most haven't had any issues, myself included.
  20. Dec 28, 2024 at 4:03 PM
    #440
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    If you have the right camera bracket it’s good to go.
    Hammertimerrrr likes this.
  21. Dec 28, 2024 at 5:11 PM
    #441
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    When I swapped out my grille the “heritage” grille included a bracket for the camera and I had no issues whatsoever.
  22. Dec 29, 2024 at 8:50 AM
    #442
    LB-1889
    LB-1889 New Member
    I used the Westcot bracket and had no issues with it. Only problem I had was I didn’t have a torx screw driver small enough to move the camera from one bracket to the other.
    Yaboy likes this.
  23. Dec 29, 2024 at 7:14 PM
    #443
    Raven67
    Kentucky
    I ran into the same issue, and I ended up using one of those tiny glasses screwdrivers & it worked great. Those screws are so tiny they aren't super tight.
  24. Feb 24, 2025 at 5:31 PM
    #444
    elukianic
    elukianic New Member
    Eugene
    Does anyone know the screw size I need to attach the light bar bracket (diode dynamics light bar mount) to trd pro grill? it looks to be the same hole diameter as where camera bracket goes. I have found some pictures online but doesn't say screw size. Here are pictures for reference.
    476251278_28533597996286289_328876105490_fc95d1c8dc213addfeb512192509810e2c91a9bc.jpg
    476463228_28533599082952847_825374827050_63b5be5cade314432a067f8416e1e0ac5dfad7f8.jpg
  25. Mar 4, 2025 at 3:20 AM
    #445
    Brums
    Brums [OP] New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    Assuming that the DD light bar bracket attaches to the factory mounting points on the TRD grille, it should take the same looking screws that are in the rest of your grille,
    90167-50063
    can be found on Amazon, here is a 30 pack for $12
    https://www.amazon.com/dp/B07MVZK78V/
