Squeaking sound trouble shooting
Discussion in '1st Gen Tundras (2000-2006)' started by meatwizard, Mar 3, 2025.
  1. Mar 3, 2025 at 8:33 AM
    meatwizard
    meatwizard [OP] Ski touring with poop in my diaper
    Montana
    '05 Tundra AC 4x4 V8 Grey
    Hey all!
    I have been hearing a strange squeaking sound that's coming from the engine bay and can be heard through the passenger side footwell. The sound can be heard when the engine is running but is not related to the engine as it begins squeaking as soon as I turn the key to the ACC or battery on position. Please let me know if you guys have ever heard this noise before. Linked below is a video when the truck in turned to the ACC position and the engine is not running.
    https://imgur.com/a/UzNjO2v
  2. Mar 3, 2025 at 8:37 AM
    AZBoatHauler
    So.Arizona
    Blower motor for HVAC.
    KNABORES likes this.
  3. Mar 3, 2025 at 8:39 AM
    Turn the HVAC fan off while it's actively squeaking. Does it stop?
    If it does, pop out the blower motor and look for debris. Our trucks have no cabin filter and often get crap stuck in there. Or it could be the bearing is going bad, or someone swapped in a cheapie motor.
    G_unit3000 likes this.
  4. Mar 3, 2025 at 8:57 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    upload_2025-3-3_9-55-45.pngIt's your blower motor. See the knob on the left? Turn it off. Bet it stops.
    JasonC. and G_unit3000 like this.
  5. Mar 3, 2025 at 9:01 AM
    Just listened with headphones. Sounds almost like the stem of a leaf is dragging against the wall of the squirrel cage or housing.
    Weagle and G_unit3000 like this.
  6. Mar 3, 2025 at 9:56 AM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Another vote for blower motor
  7. Mar 3, 2025 at 6:38 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    If you slow it down to half speed and really tweak the 5k on the audio file I could almost swear it’s a Quercus virginianus leaf.
    Weagle and AZBoatHauler like this.
  8. Mar 3, 2025 at 6:50 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I had one tiny little dried out leaf in there hard to believe that little thing could make such a racket. I assumed it was the motor because it only did it on the highest and next to highest speeds
  9. Mar 3, 2025 at 7:24 PM
    JasonC.[QUOTED], Fragman and Weagle like this.
  10. Mar 4, 2025 at 4:39 PM
    meatwizard
    Montana
    @shifty` Definitely blower motor or something with the HVAC system. The noise cuts out when climate control is turned off so thanks for the tip. I took the blower motor out and it was very clean so I will do a deeper dive when I have the time. I will update with pictures if I find anything.
  11. Mar 4, 2025 at 5:16 PM
    Fragman
    Fragman New Member
    One thing I have noticed when taking the blower motor out to clean. you want to 'look up' and clean out anything above it. Otherwise, you think you cleaned it out, slot it back in there, something dislodges, then you start it up and still hear something.
    Happened to 'a friend of mine'. :). Obviously I would be smart enough to look up before putting it back.
    meatwizard[OP] and shifty` like this.
