Need advice on g43 holster
Discussion in 'Guns & Hunting' started by 455h0le_dachshund, Mar 2, 2025.
  1. Mar 2, 2025 at 10:39 PM
    455h0le_dachshund
    455h0le_dachshund [OP] Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Hey gang. I've got a Glock 43 (non-x) that I would like to find a holster for. I was surprised when the shop I bought it from didn't have any for em and neither does Glock's website.
    I don't know what brands are any good and I'm not looking to break the bank. I'd like something concealable, but I don't know what style or placement would suit me best, as I'm a husky 6' 270lbs. Obviously comfort is a high priority.
    Also I'm left handed.
    Thanks for any pointers, fellas.
    Bought2Pull likes this.
  2. Mar 3, 2025 at 12:17 AM
    Tundra family
    Tundra family New Member
  3. Mar 3, 2025 at 12:23 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Here ya go...
    https://www.tacticalholsters.com/product/phenom-speed/
    They also make them w/magazine 'sidecars' for an extra mag which would have 2 smaller belt clips and a wide 'footprint'.... but based on where you'd probably be carrying it (position wise), I'd stick w/a stand alone holster.
    I have the first one I sent the link on w/no mag carrier, and that wide clip paired w/the 43 (i have a 43x) is a great combo as it keeps the weapon secure (even clipped to a pair of basketball shorts). When clipped to an actual belt the platform is rock solid :thumbsup:
    You'll probably want the pistol sitting at your left kidney for comfort and ease of draw :quickdraw:
  4. Mar 3, 2025 at 12:24 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    As a big guy you will most likely hate any belt style holster. If I was you I would buy a cheap iwb style if you think that might be what you want and try it out before spending the big bucks on a really nice one
    455h0le_dachshund[OP] likes this.
  5. Mar 3, 2025 at 1:03 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    What's the deal with the moclaw?
    Oh that's the clip you mentioned
  6. Mar 3, 2025 at 1:15 AM
    Tripleconpanna
    No it's different the moclaw locks the holster closer to your body, not necessary w/that pistol
  7. Mar 3, 2025 at 1:19 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    I personally hate all iwb holsters I carry a small gun a sig 938 I made my own kydex holster and carry in my front pocket the holster has a shark fin on it that catches on your pocket to separate your gun from the holster when you draw.
  8. Mar 3, 2025 at 3:28 AM
    red61cj5
    red61cj5 New Member
    wv
    2017 Limited DC Inferno
    Fobus, cheap and good enough for most occasions.
  9. Mar 3, 2025 at 3:41 AM
    Tundra family
    ColoradoTJ likes this.
  10. Mar 3, 2025 at 4:01 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yeah if I open carry, I'll definitely use a holster with a latch like officers use, or like my taser holster, at work. I might look for something similar to this for my 1911.20250303_055341.jpg
  11. Mar 3, 2025 at 5:19 AM
    JimBeam
    JimBeam Moderator Staff Member
    2015 Limited
    Most 43x holsters should fit the 43.
    Dont buy cheap holsters
  12. Mar 3, 2025 at 5:33 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    ^^ this. Also, the belt is almost as critical as the holster it needs to be rigid enough to support the firearm, but breaks in enough to be comfortable. I personally carry the Tier 1 Concealed - axis elite and Kore essentials belt. I've considered trying the Safariland incog holster as well (this one I believe is designed to carry appendix and strong side). Tier 1 Concealed (promo code social10), Trex Arms, QVO tactical, Safariland, ANR Designs, TXC holsters, are all pretty damn good holsters. I'd wait for the next holiday cause most of them will run sales. If you're just looking for an outside waistband strong side holster I swear cabalas has a ton of those. Also, you might go through a few holsters till you figure out what you like. You got my # holler if you got more questions lol.
    equin and 455h0le_dachshund[OP] like this.
  13. Mar 3, 2025 at 5:56 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If my clothes/pockets allow I like to carry my G43 as well as other guns that size in a desantis nemesis pocket holster. I’m also a thinner guy so I find it easier for that to look less conspicuous than some other options. Also on the G43 note I highly recommend the MagGuts mag modified mag that makes it an 8+1 without adding barely any length to the mag. Picture of that mag in the gun attached.upload_2025-3-3_8-49-6.jpg
  14. Mar 3, 2025 at 6:43 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
  15. Mar 3, 2025 at 6:51 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Nice. I also been meaning to buy some extended mags
    Silver17[QUOTED] likes this.
  16. Mar 3, 2025 at 7:00 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
  17. Mar 3, 2025 at 10:29 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    OHwendTrd[QUOTED] likes this.
  18. Mar 3, 2025 at 11:28 AM
    JC’sTundra
    JC’sTundra New Member
    JC
    ‘09 Sequoia SR5 Nautical Blue Metallic
    No mods (YET!)
  19. Mar 3, 2025 at 11:43 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Which one do you recommend?
  20. Mar 3, 2025 at 12:26 PM
    JC’sTundra
    JC
    No mods (YET!)
    I believe it’s the “Lighttuck” (iwb)and the “Prodraw” (owb) that I own. Got them about 5-6 years ago when I bought the 365 so my memory is a little fuzzy. I carry the Lighttuck just about every day though. Just have to tighten the screw on the belt clip a little bit every 4-5 months. God forbid a put a drop of loctite on it.
  21. Mar 3, 2025 at 5:59 PM
    Silver17
    Eastern PA
    The beauty of the MagGuts mag is it extends the capacity by 2 rounds while adding less height than 1 round as far as maintaining concealment. It’s like a magic trick. 8 round MagGuts next to the standard 6 round Glock mag.
  22. Mar 3, 2025 at 8:53 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Thanks for posting that.
    I just ordered 1 for my wife's G42 and 1 for my LCP...
  23. Mar 5, 2025 at 2:45 AM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    OP is 6 feet tall and 270 yet arming himself with a single stack Euro Pellet (9x19) handgun? :monocle:
    Just giving you a hard time man. I started out carrying something insanely small (NAA Mini in .22 Mag) but later went to full-sized weapons. Packed a 1911 in .45 ACP last night.
    Glock is the most popular handgun and everyone makes holsters for them. Leather, Kydex, nylon, you name it.
    I carry different weapons in these holsters.
    Andrews' Leather Monarch shoulder holster
    Mitch Rosen Express Line thumb break
    High Noon Holsters OWB kydex
    Desantis Nemesis nylon pocket holster
    Trying out a US-marked "Tanker" holster for any large handgun. Find it on Amazon, $40.00. Might open carry in it this summer when mowing. Might.
    We The People Holsters IWB (also trying out)
    Andrews' Leather McDaniel II crossdraw with thumb break on order
    I urge you to carry a reload. I like Alien Gear Holsters mag carriers.
    Carry pepper spray. I prefer Sabre Red Mark 6 container clipped to pocket.
    Read Massad Ayoob's book Deadly Force: Understanding Your Right to Self Defense if you want to keep out of prison.
    Good luck!
  24. Mar 5, 2025 at 2:52 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I can't imagine I'd be comfortable trying to conceal carry my 1911. I do plan to start looking for a holster for it next, but it won't be concealed for daily carry. It'll be more for shooting at targets or as a side arm when hunting. But for now, I'd like something for my Glock that's concealable for everyday carry, especially because I plan to travel from Texas to Arizona and back, for Tundras to Sedona, in about a month and a half. I know AZ has constitutional carry (like Texas has now), but NM has the castle doctrine (like Texas used to have). I'll be traveling alone for about 3/4 of the trip, so I don't want to take any chances. Last time I brought my 1911, but it stayed in the truck console, in a sold case. If shit goes down in the desert, I'd rather have my gun easier to access to defend myself.
  25. Mar 5, 2025 at 3:03 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    You say that now but that's exactly what I used to think. I think it's a normal progression for concealed carriers. They start out thinking "gotta have something small so no one will see it." Um, not true. Larger weapon is easier to handle and put rounds on target with. Good belt and holster and you forget it's there. Personal fitness matters though: carry is better if one is slim or fit. People notice very little. Half the time people don't notice when I'm open carrying!
    Friend of mine is 5'2" and the first gun he ever carried was a Springfield Armory 1911A1 (full size) IWB, strong side.
    I carry my 1911 in the shoulder holster, which is where it goes in winter. Pocket carry or belt carry doesn't work well wearing a heavy coat.
    Summer I carry a Kahr CW .45 in the thumb break which is a small handgun. .45 ACP yes but the weapon is the same height and length as a J-frame .38 Special.
    You'll find something that works for you. Practice your draws! Learn how to do a one-handed reholster. Carry a powerful flashlight on weak side, which is where that pepper spray needs to go also, along with that reload. I like the Streamlight Protac 2LX. $40.00 flashlight and 550 lumens with strobe function.
    What does castle doctrine have to do with carry? I may be missing something here.
  26. Mar 5, 2025 at 3:18 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I don't have a concealed carry license and NM doesn't have constitutional carry. So because the castle doctrine includes my truck as an extension of my castle, I can keep my gun in my truck, in NM. However if it's concealed ... Well I'm not looking to break the law. But you get the idea.
  27. Mar 5, 2025 at 3:30 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Bad idea dog. Do not leave guns in your car. Great way to arm a thief and car break-in's are getting way common everywhere.
    I get you "gotta do what you gotta do" but can you open carry? Yes you can!
    www.handgunlaw.us
    (click on the state of NM), go a bit beyond 1/2 page down. Open carry common there.
    I know it's a bit unnerving to open carry, certainly at first (been there, done that) but I don't leave a gun in my car unless going someplace with pat down or metal detector.
    Disclaimer: been carrying a gun since 1996, so 29 years experience, and yet one of the most common nightmares I used to have was "getting in trouble carrying a gun someplace I wasn't supposed to."
    I once backed out of a high school football game when I saw the metal detector wands getting used at the ticket booth. I went back to the car, dumped the shotgun, AR, both handguns, most of the ammo, frag grenade, and phased plasma rifle in 40 watt range. Just kidding, I only had pepper spray on me at that time. :) Dumped the pepper spray, enjoyed the game. Some of my students were on the football team. Helps your clout when new teachers go to all the games!
  28. Mar 5, 2025 at 3:46 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Not leaving it in the truck. I meant I can have it in my truck with me, without a license. The castle doctrine also would allow me to take it to my hotel room.
    Just didn't want to open carry without a license, if they didn't have constitutional carry.
    It looks like you still need a permit to carry there. Which I do not have, because I don't need one in Texas.
    Bought2Pull[QUOTED] likes this.
  29. Mar 5, 2025 at 3:58 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Look into it further, certainly. Some states say "open carry" but only if one has a CCW there (which is silly).
    It's nearly 7 AM here and I've been up all night......I could be misreading things!
    Do you see how silly carry laws are? No criminal is having this discussion! They are not looking up any laws. No carry ban ever stopped a criminal. Those only scare or jam up the guy that would never harm anyone.
    Looks like I'll be driving to GA in a couple of weeks. I can carry there but not sure about the wife. I'd rather her be armed too but she'll probably stick to pepper spray and me lug the artillery.
  30. Mar 5, 2025 at 4:01 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yeah a quick Google search said you only need a permit to conceal carry in NM. So I edited my post haha.
    Plus I'm simply passing thru NM. I'll be staying a night in Amarillo, then a few days/nights around Seonda, AZ and a night in El Paso, before heading back to Houston.
