Engine code P0351
Discussion in '2nd Gen Tundras (2007-2013)' started by Frankroofdoctor, Mar 2, 2025.
  1. Mar 2, 2025 at 7:01 PM
    Frankroofdoctor
    Frankroofdoctor [OP] New Member
    Hello everyone my name is Frank and I have been working on my 2011 Toyota Tundra 5.7 pickup since last week and after replacing Ignition coil # 1 cylinder, spark plug, pcm, the injector, cleared all codes with scanner and reprogramed the computer with scanner and bench testing the vvt cylinoid. The compression is 130 on cylinder 1 and I am still coming up with a misfire cylinder 1 code.
    I've checked all wiring, I have spark, fuel and compression.
    I am stuck and I don't understand what else I can do?
    The truck still runs and the motor runs a bit rough.
    I would appreciate all suggestions at this point and Help.
    Thank you
  2. Mar 2, 2025 at 10:05 PM
    rcsbguy
    rcsbguy New Member
    130 PSI is very low for a 5.7L. Whats your spread on compression from all the cylinders?
    Did you swap out coil packs with OEM or aftermarket?
