AVS and Load Leveling not available anywhere from SET
Discussion in '3rd Gen Tundras (2022+)' started by Carolina Peej, Mar 1, 2025.
  1. Mar 2, 2025 at 9:52 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Load leveling trucks have an adjustable arm that determines ride height. By simply adjusting this arm up to max or close to it, you gain some lift. No more bouncing off the bump stops. It's a simple fix only requiring a 10mm wrench.
  2. Mar 2, 2025 at 9:57 AM
    Breathing Borla
    AZ
    it’s more than just shocks , just fyi
    also you get the load leveling rear system which is awesome
    but as long as your happy that’s all that matters , just pointing out that’s it more than just shocks
    Carolina Peej[OP] likes this.
  3. Mar 2, 2025 at 2:19 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Yes, that's true. I don't tow, so load leveling isn't as critical for me, but I'm sure it's nice to have.
    One advantage of the Eibachs suspension I got is if for some reason I decide to do some off-roading, I can do it without worrying about beating up the fancy and expensive AVS system. If something breaks it'll be easier to fix too.
    The bottom line is that AVS trucks are unicorns, I couldn't even get any Tundra without paying above msrp back in 2022 let alone an AVS Tundra. It seems that it's still very hard to get b AVS now too.
  4. Mar 2, 2025 at 6:34 PM
    Carolina Peej
    Carolina Peej [OP] Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Somehow…
    I got my non hybrid 4x4 Platinum in May of 2022 with the power running boards, 10” HUD, and AVS + Load Leveling… for $65k
    Got 73k miles on it now and still love it.
