Seems like a feature, not a problem
Discussion in '3rd Gen Tundras (2022+)' started by 22whatwedo, Mar 2, 2025.
  1. Mar 2, 2025 at 7:15 AM
    22whatwedo
    22whatwedo [OP] New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Did this to me all the way home from Denver yesterday afternoon. I will see if it does it today as last night I was too tired to mess with anything. Might unhook the battery if it stays, and see if there are any codes. Otherwise I am going to call the dealer who did my engine swap and ask them, however the great thing was that auto start stop didn’t work
  2. Mar 2, 2025 at 7:20 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Definitely a feature.
    Time to take a micro-fiber cloth to your dash, brother. :cool:
  3. Mar 3, 2025 at 7:54 PM
    22whatwedo
    The Open Road
    I unhooked the battery for about 15 minutes. Didn’t clear it. Ran my scanner and I have code P0C2B15 - Auxiliary Transmission fluid pump control module feedback signal circuit short to battery or open.
    Will need to research that, running out of time tonight. Anyone have any ideas?
  4. Mar 3, 2025 at 7:56 PM
    22whatwedo
    The Open Road
    I know, right? :facepalm:Truck gets pretty piggy in the winter. Should have used this nice weekend to detail it.
  5. Mar 4, 2025 at 5:52 AM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    I've seen this pop-up on my dash except it did not have the "take to dealer" language - just the initial malfunction language. It went away in a just as fast as it appeared, so I ignored it. I did have the button pushed to disengage the function. I've not seen it since. I thought it was related to the battery as I had not driven in weeks and it sat in the cold. What did you find out?
    AZBoatHauler likes this.
  6. Mar 4, 2025 at 6:53 AM
    scarecrow87
    scarecrow87 New Member
    Shane
    Silver 2023 Tundra SR5 TRD
    I use the gel/goo in a can stuff; microfiber cloth can leave permanent streaks!
  7. Mar 4, 2025 at 7:07 AM
    Breathing Borla
    Northern Illinois
    Matt2015Tundra likes this.
  8. Mar 4, 2025 at 5:57 PM
    22whatwedo
    The Open Road
    I sent a text to the service advisor where the engine was replaced, she didn’t answer me yet . I might clear the code and see if it comes back.
  9. Mar 5, 2025 at 2:08 AM
    Observer
    Observer New Member
    I just use a swifter. works pretty well for the dust. As far as the stop/start i noticed it a couple of times and equated it to placing the truck in park in the garage when i didn't have the start/stop disabled . the tuck would shut off by itself then i would push the start button to shut the truck off and up would pop the message. Since installing the auto disable start/stop on the truck i haven't seen it since.
    Raven67 likes this.
  10. Mar 5, 2025 at 7:51 PM
    22whatwedo
    The Open Road
    My buddy changing the windshield today cleared the code when they calibrated the sensors. Nothing has come back. He felt like it probably had low voltage some reason. I am going to keep an eye on the battery now.
    Raven67 likes this.
